high idle,low idle, ticking
Postby markykarky96 [OP] » June 7th 2012, 6:02pm
hello, this is my first post to this website, but i need help. i have a 1998 chevy astro v6 RWD and im having a couple of problems. my first problem is that when i start the van for the first time of the day, it starts fast, but you hear the motor turning over and it knocks only until it fully starts. once its started, the idle on the van is horrendous. it very high and my oil gauge goes 3/4 of the way up and the dash is vibrating super loud and when you let go of the brake to idle out of the garage, it goes very fast because the vans idle is way up there. once i get driving for a while, the idle goes down(in about 10-15 min. when warm outside)to about 1/3 or less. i feel like the van is idling too low and it is constantly shaking/vibrating more than normal. also i am always hearing a ticking coming from the van near/around the motor area towards the back of the motor. i have replaced the distributor cap and rotor, spark plugs, wires, idle air control valve, air filter, changed oil(and used Lucas lubricant that goes in oil), new gear box, power steering pump, Pittman arm, whole front end, rebuilt the differential, brakes power boost, cleaned injectors(original ones probably need to be replaced) new belt(2years old) and i only use shell gasoline in my van. i have no clue what the problem can be and im just so confused. if you have any information just let me know and it would be very appreciated. thank you!
markykarky96
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: markykarky96 has been a member for 4 full yearsmarkykarky96 has been a member for 4 full yearsmarkykarky96 has been a member for 4 full yearsmarkykarky96 has been a member for 4 full years
Topics: 30
Images: 4
Alias (AKA): marky
Year: 1998
Extra Info: 4.3L rwd conversion
  • Low idle 550 rpm
    by ezbeinsteezy » January 10th 2017, 5:36pm in Engines
    January 14th 2017, 2:41pm
  • 98 4.3 wont idle?
    by Echo » January 19th 2017, 10:52pm in Engines
    Last post by Echo View the latest post
    January 20th 2017, 1:55am
    9
    64
    April 23rd 2017, 6:54pm
Re: high idle,low idle, ticking
Postby paintdrying » June 7th 2012, 7:29pm
You could check the operation of the egr. You could also check for a vacuum leak. Is the throttle cable moving freely?
paintdrying
Topics: 94
Extra Info: 108 000
  • High Idle
    by kenk » December 29th 2012, 7:47pm in Engines
    December 31st 2012, 9:01am
    15Replies
    187Replies
  • high idle
    by mtrhead79 » December 4th 2014, 3:09am in Engines
    Last post by mtrhead79 View the latest post
  • high idle
    by SGTG » April 27th 2015, 12:21am in Engines
    April 28th 2015, 12:06am
  • high idle
    by SGTG » April 27th 2015, 12:22am in Engines
    Last post by SGTG View the latest post
    July 13th 2015, 12:05am
  • Low Idle and Stalling. 89 V6
    by ll0stryker0ll » June 26th 2013, 12:39am in Engines
    Last post by palochino View the latest post
    July 4th 2013, 6:55am
It is currently April 23rd 2017, 6:54pm
Jakstro
Date: Apr 17 '17
Time: 5:42am
Attached by: nonhog
nonhog
Date: Apr 14 '17
Time: 11:06pm
sadglad
Comments: 9
Date: Apr 12 '17
Time: 8:42pm
kristuphir
Date: Apr 08 '17
Time: 8:10am
stanvalp
Comments: 64
Date: Apr 08 '17
Time: 3:19am
