How does my spark plug look
Postby Clayboy [OP] » June 12th 2012, 12:31am
My van is running very rough, P0300 code. Cleared it out, came back P0301, cleared it out again, P0303.
The engine only has 40k miles on it. It has sat for some time. I replaced the Distributor Cap and Rotor, they needed it.
Fuel pump and filter were also replace.
Im using the torque app on my tablet with a OBD tool and have been trying to monitor the engine to see whats wrong.
Clayboy
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Clayboy has been a member for 1 full year
Year: 1999
Extra Info: LT 4.3L V6 RWD
Re: How does my spark plug look
Postby Clayboy [OP] » June 12th 2012, 12:36am
Also according to the Torque app the engines Timing Advance was running between 17 and 22 degrees.
Engine temp was about 150'F.
Vacuum is -7.88 psi, does anyone know what vacuum at idle should be?
Clayboy
Fueling (1/2 tank)
Fueling (1/2 tank)
Year: 1999
Postby chevymaherchevymaher is online! » June 12th 2012, 12:48am
Preignition from running to lean.
Sure looks like metal sticking to the plug in the picture.
Firing on 3 Cylinders (L7)
Topics: 50
Images: 92
Year: 1994
Postby Clayboy [OP] » June 12th 2012, 12:55am
All 6 plugs are a little white like that. As far as around the edge of the plug, its black gunk, powder, wipes right off, not metal to the best of my knowledge.
Clayboy
Fueling (1/2 tank)
Fueling (1/2 tank)
Year: 1999
Postby chevymaherchevymaher is online! » June 12th 2012, 1:08am
That is good. No metal. Whitish grey is a good color. Metal is bad. Disregard last transmission.
Here is a read the plugs chart.
I still lean toward it being to lean.White is lean. Which does make them miss. Tan is the perfect mixture. White is getting to lean. But that the way these vans were designed to run as lean as possible. And if they go any leaner they miss. I would be checking the O2 sensors. One wrong will make it run leaner than it supposed to. Which was to lean in the first place.
Gotta do what you gotta do with a computer. If it were a carb. One size larger jet on the primary side. 2 Bucks problem solved run smooth as a kitten tan plugs.
Topics: 50
Images: 92
Year: 1994
Postby Clayboy [OP] » June 12th 2012, 1:19am
How many O2 sensors are on the van?
The OBD app picks up 3 sensors, one at .27 V, one at .87 V, and one at .7 V
Also the Fuel trim values are miles apart from each other,
Fuel Trim Bank One Long Term: 21.09%
Fuel Trim Bank Two Long Term: -7.03%
Clayboy
Fueling (1/2 tank)
Fueling (1/2 tank)
Year: 1999
Postby chevymaherchevymaher is online! » June 12th 2012, 1:36am
I have the old model I got one. I think you do have three. One in each exhaust before the cat, and one after. For some reason the bank 2 is pulling the gas out. Leaning it out. Seeing as cylinders missing are 1 and 3. I would assume bank 2 is the drivers side. Pull that O2 sensor coming from that exhaust manifold and test it. There a video on how to do it. I will find it and post again.
Topics: 50
Images: 92
Year: 1994
Postby chevymaherchevymaher is online! » June 12th 2012, 1:38am
There it is. I would actually test them all while your at it.
viewtopic.php?f=24&t=11812
Topics: 50
Images: 92
Year: 1994
Postby Clayboy [OP] » June 12th 2012, 1:50am
Chevymaher,
Thank you for the help. I hope I can figure this out. You are a great resource on this site.
I hope to test those tomorrow and report back.
Clayboy
Fueling (1/2 tank)
Fueling (1/2 tank)
Year: 1999
Postby AWDASTROVAN1999 » June 12th 2012, 3:00am
That video is no longer avail..
AWDASTROVAN1999
Years of Membership: AWDASTROVAN1999 has been a member for 2 full yearsAWDASTROVAN1999 has been a member for 2 full years
Topics: 9
Images: 2
Postby paintdrying » June 12th 2012, 3:44am
their is the visual inspection
paintdrying
Years of Membership: paintdrying has been a member for 2 full yearspaintdrying has been a member for 2 full years
Topics: 94
Extra Info: 108 000
Postby chevymaherchevymaher is online! » June 12th 2012, 9:47am
Here is a couple more. One to use with a program. With live data.
Second is like the deleted one.
It is a shame the first one is gone. It was a 2 part and it was great.
Topics: 50
Images: 92
Year: 1994
It is currently June 19th 2013, 5:55am
Attached by: chevymaher
Date: Today
Time: 12:03am
Attached by: Duckstar
DuckstarDuckstar is online!
Date: Jun 17 '13
Time: 9:33pm
deleteitall
Comments: 0
Date: Jun 07 '13
Time: 8:41pm
Date: Jun 06 '13
Time: 11:33pm
Date: Jun 02 '13
Time: 1:16pm
Users browsing this forum: Bing [Bot], magpie-crawler [Crawler] and 7 guests
