How to test the Ignition Module
Postby ccookie66 [OP] » July 11th 2012, 1:55pm
I have determined that the problem in my van is electrical. I'm thinking that the Ignition Module had failed. Is there any way to test it? I don't have any meter things...all I have is a test light.
1160Image
The Astro is always a turn key away from adventure.
ccookie66
Firing on 5 Cylinders (L2)
Years of Membership: ccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full years
Topics: 135
Images: 47
Alias (AKA): Cameron
Year: 1992
Extra Info: 4.3L V6 TBI Shorty
Re: How to test the Ignition Module
Postby chevymaher » July 11th 2012, 1:57pm
Take it to the auto parts place. They can test it.
Topics: 84
Year: 1994
Postby ccookie66 [OP] » July 11th 2012, 7:27pm
Thanks for the reply. I don't think it is bad, because the van will fire when I spray gas directly into the intake. So if it was bad, it would not fire at all.
1160Image
ccookie66
Topics: 135
Images: 47
Year: 1992
Postby Matrixx » July 13th 2012, 10:22am
Hi ccookie66
You are correct, it wouldn't fire with a bad module spraying gas into it. Check the fuel supply (plugged filter - bad (or plugged injectors) or a bad pump) would be the first places I would check from what you have just posted.
Keep us updated, thanks ccookie66.:)
Matrixx
Years of Membership: Matrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full years
Postby ccookie66 [OP] » July 13th 2012, 12:46pm
Matrixx wrote:Hi ccookie66
Yup, I actually think its the injectors, because I have a brand new fuel pump on it, and a brand new fuel filter, both from NAPA. I'm going to change the lines (They are very rusted, and there are sliced parts on it, where after market rubber hose replace the metal lines) and then check the fuel pressure. If it has the right pressure, then I'm going to pull the injectors and check them out. My question is, how do you know the injectors are bad? I heard one way is when they spray, it will just dribble out instead of a cone shaped spray.
1160Image
ccookie66
Topics: 135
Images: 47
Year: 1992
Postby paintdrying » July 13th 2012, 12:57pm
If they are dribbling then that is it for them. Rebuilt injectors are not to expensive. You want a nice cone pattern spray. Injectors can screw up in other ways that are not so noticable, such as not spraying the proper amount at the proper fuel pressure.
I replaced a dribbling injector with one from a jy. Did you say something about blowing a fuse for the fuel pump? Also, how many pounds of pressure on that pump?
paintdrying
Topics: 94
Extra Info: 108 000
Postby ccookie66 [OP] » July 13th 2012, 1:00pm
paintdrying wrote:If they are dribbling then that is it for them. Rebuilt injectors are not to expensive. You want a nice cone pattern spray. Injectors can screw up in other ways that are not so noticable, such as not spraying the proper amount at the proper fuel pressure.
Yeah, fuse ECU B I think. (Not sure if that one is for the fuel pump, but after it blew I had to hot wire the relay to get the pump to work) I'm not sure how many pounds of pressure I have, still waiting for the gauge to arrive.
1160Image
ccookie66
Topics: 135
Images: 47
Year: 1992
It is currently June 27th 2017, 4:51pm
Rookie162
Date: Jun 13 '17
Time: 11:28pm
astrometalvan
Date: Jun 10 '17
Time: 5:10pm
Attached by: xit
xitxit is online!
Date: Jun 07 '17
Time: 3:17pm
Attached by: Astro Pop
Astro Pop
Date: Jun 06 '17
Time: 6:17am
astrometalvan
Date: Jun 06 '17
Time: 1:14am
