Help with engine noise - video
Postby drue [OP] » July 21st 2012, 7:44pm
Hello all. I took some video today of this engine noise I've been having. It is intermittent, can go weeks without hearing it. When it is happening it can be at different volumes. I'm about to take a bit of a trip and I want to know if it's something critical to fix. I have a feeling it has something to do with the AC compressor but I'm no mechanic. Mine is a 93' Safari. The AC does not work but the heat does.
Here's the video
Thank you so much for taking the time.
Drue
drue
Years of Membership: drue has been a member for 1 full year
Alias (AKA): drue
Year: 1993
Re: Help with engine noise - video
Postby sabreuk » July 21st 2012, 8:13pm
sounds like ac compressor clutch pack is on its way out bud.
we had a couple of our huskys do that and the front of the ac compressors gets realy realy hot then turns a blue colour then ours went molten red and set the airfilter piping on fire.
its the bearings in the clutch that go which is what that noise sounds like. i would either get a new clutch pack if you can or change the ac compressor its only gona get worse until it gets to the point like ours did.
on the intermitent thing i bet its making that noise when you have the ac turned on and it goes when you just use the normal heat settings. when you put ac on on the switch thats what sends the signal to the compressor to engage the clutch and pump the ac off the compressor. unless its got that bad now that it doesnt need to be on load to strain it.
4.3 v6 vortec 1995 cargo chevy astro with air con and rear wheel drive, 50,000 miles on the clock.
sabreuk
Years of Membership: sabreuk has been a member for 1 full year
Alias (AKA): craig
Year: 1995
Extra Info: 4.3v6 vortec rwd
Postby Jasen » July 21st 2012, 8:24pm
Take the serp belt off and spin all the pulleys by hand, see if any make noise or have excessive resistance
http://the-99percent.blogspot.com/
I'm a Journeyman woodworker,
Every projects a journey man.
Firing on 4 Cylinders (L7)
Years of Membership: Jasen has been a member for 3 full yearsJasen has been a member for 3 full yearsJasen has been a member for 3 full years
Topics: 249
Images: 68
Year: 1997
Postby kenk » July 21st 2012, 8:57pm
it also sounds like the idler pulley bearing is shot and it rubbing against its mount, like suggested, take the belt off and turn by hand
kenk
Topics: 9
Year: 1990
Postby drue [OP] » July 21st 2012, 11:46pm
Thanks so much for taking the time to look and listen. Using the old technique my father taught me I used a screwdriver to listen to where I think the noise is coming from. It is definitely coming from and is loudest when I held the screw driver at the green arrow. I could still hear it but It was less when I held it at the yellow arrow.
https://www.dropbox.com/s/p28x7pco69jnrmf/noise.jpg
Is this the AC compressor bearings?
My main concern is will I be ok for a couple of hundred miles or is this a cancel a trip situation?
My AC settings are as follows to try and not have it run. Should I set it differently or does it matter?
https://www.dropbox.com/s/sds3igv9np3y8zr/settings.JPG
drue
Alias (AKA): drue
Year: 1993
Postby Lumpy » August 21st 2012, 9:39pm
"Heat" or "Vent" should keep the compressor off. If the compressor does come on, you should be able to hear it. Idle should drop for a moment.
Firing on 2 Cylinders (L4)
Topics: 116
Year: 1989
Extra Info: 9 in. lift Camo
Postby chevymaher » August 21st 2012, 9:56pm
I just went through this myself. The bearings in the compressor clutch are going out.
Not the compressor itself. It don't matter whether you run the air conditioning or not.
Mine lasted years like that I just oiled it. But when it went out. It was as was posted in a previous post. It got red hot. Locked up and the belt smoked. My air was not on when it finished it's term in office.
This was just last week.
Firing on 2 Cylinders (L7)
Topics: 50
Images: 92
Year: 1994
It is currently May 26th 2013, 8:30am
Attached by: aztec1987
aztec1987
Date: Today
Time: 1:02am
cowboydan
Date: May 24 '13
Time: 12:22am
Attached by: SilverBullet1997
SilverBullet1997
Comments: 21
Date: May 21 '13
Time: 4:49pm
kumisukka
Comments: 0
Date: May 20 '13
Time: 2:20pm
Attached by: chevymaher
Comments: 20
Date: May 20 '13
Time: 1:37am
