2000 gmc safari idling rough
Postby mikee2174 [OP] » August 10th 2012, 6:40am
hello, my name is tiffany, ( im doing this from my other half) we are having problems with our 2000 gmc safari its a 4.3 liter vortec. over the last week its been idling rough, cutting out, almost dying on him a couple of times. he uses it for work and goes over 300 mile day in it. we have changed the idle air control vavle, the throttle postion sensor. we know it has a vacuum leak, but are haveing a hard time finding a diagram for it. we think its the one going to the fuel pressure regulator. can any give us hand in figuring it out please.
mikee2174
Years of Membership: mikee2174 has been a member for 4 full yearsmikee2174 has been a member for 4 full yearsmikee2174 has been a member for 4 full yearsmikee2174 has been a member for 4 full years
Alias (AKA): mike
Year: 2000
Extra Info: 4.3 liter vortec
  • 2000 rough idle now long start time
    by paulbot » April 4th 2017, 11:53pm in Engines
    April 18th 2017, 4:18am
  • rough idle
    by edlps » February 28th 2017, 6:01am in Engines
    Last post by Astro Pop View the latest post
    February 28th 2017, 8:30am
    52
    April 23rd 2017, 6:43pm
Re: 2000 gmc safari idling rough
Postby Sailing_Faith » August 10th 2012, 10:41pm
It sounds like it may well be the vacuum leak as you mention you suspect.
There are two places I have read these vans frequently develop leaks, the hose that connects to the air conditioner control, and the hose that leads to the accumulator (ball that holds vacuum).
Search for vacuum hose replacement, you will find a thread with pictures telling you what to look for.
Good luck!
Sailing_Faith
Firing on 8 Cylinders (L1)
Years of Membership: Sailing_Faith has been a member for 4 full yearsSailing_Faith has been a member for 4 full yearsSailing_Faith has been a member for 4 full yearsSailing_Faith has been a member for 4 full years
Topics: 32
Alias (AKA): s/v Faith
Year: 1997
Postby ccookie66 » August 10th 2012, 10:49pm
Here is a good way to test for vacuum leaks...take carb cleaner and spray along the vacuum lines. If the idle changes, mark the spot on the hose where it changed the idle. If there is a leak, it will suck in the carb cleaner and make the idle go up or down. But I would defiantly make sure you fix the vacuum leak before you take apart the upper intake plenum, its quite the job getting to the pressure regulator, when it could be a vacuum leak all along.
One more thing, is the van running rich at all?
The Astro is always a turn key away from adventure.
ccookie66
Firing on 5 Cylinders (L2)
Years of Membership: ccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full years
Topics: 134
Images: 45
Alias (AKA): Cameron
Year: 1992
Extra Info: 4.3L V6 TBI Shorty
Postby Sailing_Faith » August 10th 2012, 11:22pm
Three more points (I posted above);
Here is a thread with a diagram.
Also,
Using carb cleaner as recommended above is a good tool, but it can really break down rubber (like the vacuum hoses, and radiator hoses). I have stopped using it because of that. :cheers:
AND,
While looking for the post on the diagram to try to help you... I went and looked at my van and found two of my vacuum hoses were falling apart! Thanks to your question I found and changed mine, and probably fixed a minor annoying miss that I only noticed after long hwy running! :banana:
Having now put over 7000 miles on my van in the month I have had it I am still sorting through this myself. :driving:
Sailing_Faith
Topics: 32
Year: 1997
It is currently April 23rd 2017, 6:43pm
Jakstro
Date: Apr 17 '17
Time: 5:42am
Attached by: nonhog
nonhog
Date: Apr 14 '17
Time: 11:06pm
sadglad
Comments: 9
Date: Apr 12 '17
Time: 8:42pm
kristuphir
Date: Apr 08 '17
Time: 8:10am
stanvalp
Comments: 64
Date: Apr 08 '17
Time: 3:19am
Users browsing this forum: Google Adsense [Bot] and 4 guests
