No fuel pressure at schrader valve, new fuel pump
Postby morganbilt [OP] » October 3rd 2012, 3:23am
Hello, I am new to this forum. Brought here by desperation.
I just replaced the fuel pump in my 2000 chevy astro van.
The van started up perfectly and ran for about a week, then it went out and left me stranded on the side of the highway. I got it towed, and now I am stuck.
When you turn the key you can hear the pump cycle,
There is spark that was checked, and if you spray in starter fluid it will start for a second and conk out.
Engine just keeps turning over like there is no fuel.
So I took off the dog house and checked the schrader valve and no pressure.
Could the fuel pump be turning on and still giving no pressure?
Is it possible that the oil pressure switch is limiting the fuel? or would that cut the power to the fuel pump?
Also I replaced the fuel filter, and still no start or pressure?
Thanks for your information,
R.E: desprate
morganbilt
Years of Membership: morganbilt has been a member for 4 full yearsmorganbilt has been a member for 4 full yearsmorganbilt has been a member for 4 full yearsmorganbilt has been a member for 4 full years
Year: 2000
Re: No fuel pressure at schrader valve, new fuel pump
Postby jkilbert » October 3rd 2012, 9:33am
It can. My dad put a new pump in his k1500 p/u."...2 days later it died. Had to put a second one in.
jkilbert
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: jkilbert has been a member for 5 full yearsjkilbert has been a member for 5 full yearsjkilbert has been a member for 5 full yearsjkilbert has been a member for 5 full yearsjkilbert has been a member for 5 full years
Images: 5
Alias (AKA): jkilbert
Year: 2000
Postby chevymaher » October 3rd 2012, 11:53am
There were a couple other threads with this issue also.
Check the fuel pump relay. It the easiest.
Then a not so easy. The plug which plugs into the fuel pump in the tank. One member that plug was wasted, actually melted.
Or as mentioned in the previous post the pump itself could be defective.
Topics: 79
Year: 1994
Postby Mr_Bowtie » October 3rd 2012, 3:11pm
Did you change the whole fuel pump assembly? Or rebuild it?
If you can hear the pump prime when you turn the key forward then I would be dropping the tank to see if something is blocking the strainer or the pump came loose from the assembly in the tank some how.
If the pump is priming the relay should be fine.
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
Postby morganbilt [OP] » October 3rd 2012, 10:23pm
Thanks for the replys,
I did a full install with a new pump.
The relay is fine because it is getting power and cycling.
I was hoping it was something else, everything is pointing to dropping the tank again.
It is strange that it is cycling through, and 0 pressure after the pump.
morganbilt
Year: 2000
Postby Mr_Bowtie » October 3rd 2012, 10:48pm
Drop the tank and inspect the pump assembly. Something came loose...like the pump or hose or blockage?
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Postby Leeann_93 » October 3rd 2012, 11:35pm
The oil pressure switch is out of the equation starting with the '99 model year.
It is quite possible you got a bad pump or that the electrical connector was arcing/melting and that's what toasted your first pump.
What brand of pump did you install?
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 26
Year: 2002
Extra Info: LS 4.3L AWD
Postby morganbilt [OP] » October 4th 2012, 12:43am
I put in a canadian model, always trying to save some money. Then to read all the post saying to buy Nothing but AC delco, or maybe Delphi, probably why they are all around $300.00
I will have to take the tank apart tomorrow, and see if I can see anything amiss.
I know its the cheesy way out but I might end up cutting a hole in the floor board.(half/***)
But right now can afford a new pump until payday the 15th.
One thing to add is that it is still cycling, when the last pump went out, It would not cycle. I got away for a couple of months banging the tank and it would run for a couple of weeks, then go out/ repeat until it just completely quit.
So my question is if it is still powering up, why no pressure?
what would make the sound of powering up?
morganbilt
Year: 2000
Postby chevymaher » October 4th 2012, 12:49am
On of the lines in the tank split open or fell off.
Topics: 79
Year: 1994
Postby Mr_Bowtie » October 4th 2012, 11:39pm
If the pump is bad and your tight on money plus you just got a whole new fuel pump assembly.......then I would just buy the AC Delco repair/rebuild kit. I used it on my van last winter to the tune of $49 shipped off eBay. :rockon:
I know a couple people with holes in the floor of their Vans.......I hear they come in handy..... :whistle:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
It is currently January 23rd 2017, 9:33am
Attached by: shredzorv2
shredzorv2
Comments: 36
Time: 11:09pm
Ingmire
Date: Jan 18 '17
Time: 1:09am
Driftedone
Comments: 13
Date: Jan 10 '17
Time: 7:12am
Echo
Comments: 17
Date: Jan 09 '17
Time: 6:50pm
shredzorv2
Comments: 36
Date: Jan 01 '17
Time: 2:12am
Users browsing this forum: Bing [Bot], Google [Bot], Yandex [Bot] and 4 guests
cron
