Had problems starting the van out of nowhere, so I took it to the mechanic. They told me it was the distributor, and they could replace it for $250. I took It home, and replaced both the cap and rotor myself.
It seemed this was the problem, as the cap was in terrible shape, and the rotor was utterly black and in dismal shape. Once I replaced these parts, and had everything back together, I tried multiple times to repeat the starting issue, but it started up just fine every time.
Today, I was at a stoplight, when it just died. I threw it into park, and tried several times to start it back up. Finally after about 5 minutes, it started back up and I went on to work. After work, which was roughly 4 hours, it started up and I went to pick up dinner from a fast food place nearby. While ordering, it died again. No shuddering or anything, just went off like I'd turned off the key. We pushed it out to the parking lot, and I tried to start it up again, but to no avail. I waited 30 minutes, still nothing. So I left it there and got a ride home.
My father in law thinks it sounds like the fuel filter is clogged. Wanted to get some insight from the community. It might be prudent to note that it has been roughly 30 degrees in the day and low 20s at night. I usually let it run 10 Minutes before I drive it.
If you need to know anything let me know, and I'll try to answer quickly.
