Ignition coil arcing
Postby astrometalvan [OP] » November 16th 2012, 6:33pm
Astro the metalvan hasn't run in about 3 weeks. Thought I had a bad fuel pump. I got the dog house off to check fuel pressure at the port near the back of the intake. While i had the doghouse off, I cranked on it a little and heard electrical arcing. I looked and saw the spark jumping from the coil to the mounting bracket. Hoping I had a bad coil wire boot, I turned the coil wire around 180 ( coil end into dist and dist end into coil ) and plugged it back in and it's doing the same thing. The arc looks like its coming from the bottom of the wire boot and jumping about 1/2 inch to some exposed metal. Do I need a coil?
2000 Astro LT AWD 4.3L W 4L60E GT4 G80
96 Astro LT 2wd 4.3L W 4L60E
92 S10 2wd reg/short 2.8 R T-5
93 S10 Ex cab/short 4.3L Z 700R-4
88 SeaRay Seville 21' cuddy Mercruiser MCM205 4.3L/4BBL-98Alpha1
91 S10 Reg/short 4.3L Z MY2 GT5
astrometalvan
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: astrometalvan has been a member for 4 full yearsastrometalvan has been a member for 4 full yearsastrometalvan has been a member for 4 full yearsastrometalvan has been a member for 4 full years
Topics: 16
Images: 6
Alias (AKA): baddad71
Year: 1996
Extra Info: LT 4.3 W
  • New Intake MF / Ignition Distrub / Fuel Pump ~ Less Power
    by ormoto » Yesterday, 12:52am in Engines
    Last post by ormoto View the latest post
    Yesterday, 12:52am
    49
    February 27th 2017, 4:49pm
Re: Ignition coil arcing
Postby Astronomical1987 » November 16th 2012, 7:40pm
Cant say for sure but something similar happened on an old Caddy I used to have. Ended up being a bad wire. Even though I couldnt see it, there was some cracking on the boot, enough to allow the spark to escape and create the arch. Of course there could be an issue with the coil, where the wire connects to it.
2003 Chevy Astro LT
1990 Olds Cutlass Supreme International Coupe
2006 Caddy CTS Sport
Astronomical1987
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Astronomical1987 has been a member for 4 full yearsAstronomical1987 has been a member for 4 full yearsAstronomical1987 has been a member for 4 full yearsAstronomical1987 has been a member for 4 full years
Alias (AKA): 96SafariAWD
Year: 2003
Extra Info: LT 4.3L 82k
Postby astrometalvan [OP] » November 16th 2012, 7:43pm
It arcs the same after switching the coil wire around.
astrometalvan
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 16
Images: 6
Year: 1996
Postby Astronomical1987 » November 16th 2012, 8:09pm
Could be a grounding issue at the coil. Also, double check that the wire is correct for the year. I believe 96 was the first year for a newer style boot. Although an older style may fit, it wont fit correctly. If it is a universal type wire, than that is almost certainly the issue. Although unlikely, incorrect gap on the plugs can cause arcing issues, but I dont think its all that common.
2003 Chevy Astro LT
Astronomical1987
Fueling (1/2 tank)
Fueling (1/2 tank)
Year: 2003
Postby Ragenme » November 16th 2012, 8:28pm
Try wrapping it with a little electrical tape. See if it stops. Coil could have a hair line crack.
ragenme If you can't fix it with a hammer then its probably a electrical problem!
Ragenme
Years of Membership: Ragenme has been a member for 4 full yearsRagenme has been a member for 4 full yearsRagenme has been a member for 4 full yearsRagenme has been a member for 4 full years
Topics: 16
Images: 23
Alias (AKA): Ragenme
Year: 1998
Extra Info: SLX 4.3 V6 RWD
Postby astrometalvan [OP] » November 16th 2012, 10:06pm
I haven't changed the wires since we got the van. I was thinking crack in coil also.
I thought about the tape idea too. The wire and boots look too good on both ends.
Hearing someone else say it kinda backs up my suspicions. I'll try the tape thing.
how long can ET last in a harsh florida winter. I'm freezing my *** off, it got down to 54 this morning....hehe
astrometalvan
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 16
Images: 6
Year: 1996
Postby astrometalvan [OP] » November 16th 2012, 10:21pm
I used a pic from parts store online catalog to show where mine is arcing.
this is where it arcs
astro coil.jpg (32.37 KiB) Viewed 9060 times
astrometalvan
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 16
Images: 6
Year: 1996
Postby astrometalvan [OP] » November 16th 2012, 10:32pm
Astronomical1987 wrote:Could be a grounding issue at the coil.
Yes. its grounding at the coil.
tape didn't work. I think the crack is too far down the molded cylinder that the boot slips over.
the arc goes under the tape.
astrometalvan
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 16
Images: 6
Year: 1996
Postby astrometalvan [OP] » November 16th 2012, 10:34pm
:confused: Maybe liquid electrical tape? :shrug:
astrometalvan
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 16
Images: 6
Year: 1996
Postby chevymaherchevymaher is online! » November 16th 2012, 10:59pm
Cover it with silicon and jam the boot on.
Topics: 81
Year: 1994
Postby Astronomical1987 » November 16th 2012, 11:15pm
chevymaher wrote:Cover it with silicon and jam the boot on.
I was thinking the same thing! Some tune up grease may go a long way in this case. At the end of the day the coil is only $35, which might just be some cheap insurance!
2003 Chevy Astro LT
Astronomical1987
Fueling (1/2 tank)
Fueling (1/2 tank)
Year: 2003
Postby Ragenme » November 16th 2012, 11:21pm
Plus you already have it apart! Getting the dog house off is half the fight!
Ragenme
Topics: 16
Images: 23
Year: 1998
Postby astrometalvan [OP] » November 16th 2012, 11:28pm
I'm headed to Autozone...
gonna order a coil ...
it's at the warehouse, so the store will have it by 9:00 am ...
I REALLY hope it's just the bad coil and not the fuel pump too.
I think astro is 1/2 full o gas.
astrometalvan
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 16
Images: 6
Year: 1996
Postby astrometalvan [OP] » November 16th 2012, 11:31pm
oh, my liquid tape stopped being liquid a long time ago.. just arubber chunk at the bottom of the can now.
dont have any silly cone stuff either.
new coil is next
astrometalvan
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 16
Images: 6
Year: 1996
Postby astrometalvan [OP] » November 17th 2012, 6:58pm
:banana: YAY ignition coil was the problem!!!
I put the new coil on and it fired up as soon as I cranked it enough to refill the fuel system,( i removed the fuel filter and blew through it to make sure it was clear.) and its idling good and drives like it should. :driving:
Now I'm wondering how many of my hard starting and driveability issues can be traced back to the bad coil... :shrug:
BTW: I did check out a fuel system pressure tester kit from Autozone and found out for sure that my fuel pump is right at 60 psi when running. :thumbup:
astrometalvan
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 16
Images: 6
Year: 1996
Postby xit » November 17th 2012, 8:29pm
Good for you & thanks for posting after you fixed it so we all can benefit from your solution. :rockon:
Possibly Natures most perfect food, good beef jerky and cold beer......
xit
Years of Membership: xit has been a member for 5 full yearsxit has been a member for 5 full yearsxit has been a member for 5 full yearsxit has been a member for 5 full yearsxit has been a member for 5 full years
Topics: 50
Images: 4
Year: 1994
Extra Info: Conversion
Postby astrometalvan [OP] » November 26th 2012, 4:45pm
My son drove the Astro to Tampa (110 miles ) to stay with his uncle for Thanksgiving and had no starting or driveability issues.
astrometalvan
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 16
Images: 6
Year: 1996
Postby dejure » January 20th 2013, 10:12pm
BUT, if the distributor gear is worn, the coil voltage will be GREATLY increased, to try to arc across the gap when the system fires between two terminals, instead of at the proper terminal. Too, the higher voltage the coil is forced to put out will likely wear out the coil quicker. when the dialectic fails and the coil starts arcing internally.
Remember also, electricity wants the shortest path to ground. As such, if your distributor gear is worn such that the coil fires when the rotor is between two terminals, the arc will be drawn to the cylinder which offers the shortest path (wire) to ground [via a plug or crappy wire]. Instant random misfire.
If your coil is bad, make sure the distributor gear is not worn before you replace it.
dejure
Years of Membership: dejure has been a member for 6 full yearsdejure has been a member for 6 full yearsdejure has been a member for 6 full yearsdejure has been a member for 6 full yearsdejure has been a member for 6 full yearsdejure has been a member for 6 full years
Extra Info: Com 4.3L 2Whl
Postby esmartuek » January 21st 2013, 6:10am
I was thinking along the same lines, dejure.
If the electricity is being drawn to cross air (which has an enormous amount of resistance, mind you) than something in the path to the spark plug must not have been functioning. Honestly, I would've taken this entire scenario as an excuse to replace the entire ignition system from the Coil to the Plugs. (coil, bracket, wires, distributor cap, rotor, and spark plugs) That way you are sure exactly the age of the entire system.
On top of replacing them, buying a can of dielectric grease and using that instead of trusting the factory grease that's already put in the boots, because the factory stuff gets old really fast. Maybe replacing any wire-spreaders, as well to ensure that all wires are clear of any metal contact or crossings.
All of these measures can keep a healthy spark and prevent this scenario from occurring.
esmartuek
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: esmartuek has been a member for 6 full yearsesmartuek has been a member for 6 full yearsesmartuek has been a member for 6 full yearsesmartuek has been a member for 6 full yearsesmartuek has been a member for 6 full yearsesmartuek has been a member for 6 full years
Topics: 5
Alias (AKA): Esmartuek
Year: 1998
Extra Info: 4.3L V6 AWD
Postby astrometalvan [OP] » January 22nd 2013, 5:15pm
you guys think of expensive stuff....I replaced the coil and it runs again, good enough for a $550 van with 200K on it.
astrometalvan
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 16
Images: 6
Year: 1996
It is currently February 27th 2017, 4:49pm
MmusicmanMmusicman is online!
Comments: 89
Date: 54 minutes ago
Time: 3:54pm
AstroNuts
Comments: 89
Date: Feb 24 '17
Time: 4:56am
AstroNuts
Comments: 89
Date: Feb 23 '17
Time: 5:19am
sixsixsixsix is online!
Comments: 22
Date: Feb 22 '17
Time: 4:37am
Attached by: 97cargocrawler
97cargocrawler
Comments: 89
Date: Feb 21 '17
Time: 6:29pm
