backfiring through exhaust
Postby markmitch [OP] » January 6th 2013, 10:18pm
OK my Astro is a 1989 RS with 4.3 and 700R4 it had 189,000 miles on it when I bought it and it was burning oil badly and the trans shifted slow. So after I owned it a couple months I pulled the stock engine and trans out and installed a 80,000 mile 95 astro 4.3 and a rebuilt 700r4 trans. I reused the TBI system but rebuilt the TBI unit and had the injectors cleaned and flow tested by witchdoctor. plugs, wires, cap, rotor, air cleaner, pcv valve,oil & fuel filter&oil filter were all replaced new. I also replaced the water pump. Other then the intake swap the insides were never touched. Now the problems. It starts great and idles fine but as soon as you touch the gas it backfires and has very little power. The timing is on the money. It backfires through the exhaust only and there is no smell of raw fuel. Feel free to send me your thoughts on what to check.
By the way I drove it `18 miles home like this and it got worse as it warmed up. Sometimes if I shut it off and attempt to restart it does not like to start.
Firing on 1 Cylinder (L4)
Years of Membership: markmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full yearsmarkmitch has been a member for 8 full years
Topics: 430
Images: 5
Alias (AKA): Mitch
Year: 1989
Extra Info: RS 350 TBI
  • 95 intermittent bogging/backfiring/power loss
    by Big_kid » February 5th 2017, 7:20pm in Engines
    Last post by CoasterCoaster is online! View the latest post
    February 21st 2017, 2:10pm
  • 1991 Astro - Misfiring/Backfiring Mainly When Cold
    by Fortran » January 7th 2017, 1:56am in Engines
    January 10th 2017, 11:45pm
    February 27th 2017, 4:46pm
Re: backfiring through exhaust
Postby chevymaherchevymaher is online! » January 6th 2013, 11:15pm
If the engine ran fine before the switch, it isnt a valve or timing chain issue.
The EGR was working on your engine so it probably okay. I would check to see if it getting proper vacuum signal, and not a metered or delayed vacuum.
I would look and see if the injectors are spraying a mist. Rebuilt or not. It always what you don't check.
It sounds like the timing to far retarded. It only takes a second. Loosen it and move it around see if that improves things. It a gen 1 OBD1 it don't got to be where it supposed to, to work at all. Mine miles off from factory and a screamer. It sure isnt at factory settings.
Topics: 81
Year: 1994
Postby chevymaherchevymaher is online! » January 7th 2013, 2:23am
90 starter
Topics: 81
Year: 1994
It is currently February 27th 2017, 4:46pm
MmusicmanMmusicman is online!
Comments: 89
Date: 51 minutes ago
Time: 3:54pm
AstroNuts
Comments: 89
Date: Feb 24 '17
Time: 4:56am
AstroNuts
Comments: 89
Date: Feb 23 '17
Time: 5:19am
sixsixsixsix is online!
Comments: 22
Date: Feb 22 '17
Time: 4:37am
Attached by: 97cargocrawler
97cargocrawler
Comments: 89
Date: Feb 21 '17
Time: 6:29pm
