Hard to start warm, but not cold or hot
Postby RussTypeS [OP] » January 6th 2009, 5:54pm
So the van starts fine cold (sitting overnight), and it starts fine hot (like after filling up with fuel), but if I let it sit for say 1-6 hours it's hard to start. When I try to start it usually it will catch right away then stumble out. When I try to start it again it will turn over for maybe 10 seconds before it catches and then runs fine. I've found that if I give it a tiny bit of throttle when I suspect it will be hard to start it will catch the first time, run rough for a second, then idle normal. I should also mention that "normal" is a little rough and has been for a while (at least 50k miles). Not rough enough to bother me, and it was still rough after I changed plugs, wires, cap, & rotor (which have not been done recently, but I don't suspect that is the problem).
I searched around a bit but I can't find anyone with this same problem. I have a few ideas but I'm not really familiar with CPI so I may be way off, what do you guys think?
RussTypeS
Years of Membership: RussTypeS has been a member for 8 full yearsRussTypeS has been a member for 8 full yearsRussTypeS has been a member for 8 full yearsRussTypeS has been a member for 8 full yearsRussTypeS has been a member for 8 full yearsRussTypeS has been a member for 8 full yearsRussTypeS has been a member for 8 full yearsRussTypeS has been a member for 8 full years
  • Won't start in cold, & bog at full throttle
    by cybrvanr » January 3rd 2017, 7:59pm in Engines
    Last post by Leeann_93Leeann_93 is online! View the latest post
    January 10th 2017, 11:44pm
  • PO300 code. Hard start and doesn't want too idle
    by Dmoney » December 19th 2016, 5:44am in Engines
    Last post by Dmoney View the latest post
    December 19th 2016, 7:09am
    9
    64
    May 23rd 2017, 9:49pm
Re: Hard to start warm, but not cold or hot
Postby Leeann_93Leeann_93 is online! » January 6th 2009, 8:17pm
What year is your van? You say CPI, so 92-95?
Have you ever looked at/cleaned your EGR valve? How about your IAC?
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby RussTypeS [OP] » January 6th 2009, 8:21pm
Sorry, should have included that info in the original post. It's a 95 with 212k on the clock. I haven't checked either of those but it sounds like I should give them a look. Thanks!
RussTypeS
Postby astro355 » January 6th 2009, 9:11pm
Check/clean the back of the throttle plate on the throttle body.
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full years
Year: 1989
Extra Info: 355 V8 700R4
Postby RussTypeS [OP] » January 23rd 2009, 7:21pm
Took the EGR off, no problems but I cleaned it out anyway. The IAC was pretty gunked up so I cleaned it out as well, also cleaned the back of the throttle plate and the IAT while I was in there. None of this seemed to make any difference, any other ideas?
RussTypeS
Postby astro355 » January 23rd 2009, 8:07pm
When was the last time the air filter was changed/checked?
Did you check fuel pressure?
What is the condition of the electrical system? Battery, alternator, wires, corrosion on terminals?
astro355
Year: 1989
Postby RussTypeS [OP] » January 23rd 2009, 8:15pm
Checked the air filter last night when I had it off to clean the IAC and EGR, looked fine. No corrosion on the battery, but it's not like it has trouble turning over it just wont catch. Everything electrical is in good shape.
I haven't checked the fuel pressure, but I suppose that's next on my list. I don't have a fuel pressure gauge that can handle efi pressures, what should I look for at the parts store? How does the gauge connect?
RussTypeS
Postby astro355 » January 23rd 2009, 8:21pm
The gauge connects to the schader valve. Its universal for GMs.
And actually, you would have to check for corrosion IN the terminals for the battery and the starter. Any corrosion there will produce a volt drop that maybe enough to not let your van start. Corrosion creates resistance in an electric circuit, as does heat. The more heat you have in an electrical circuit, the more voltage required to operate said circuit. So, whey you think about all of the different circuits that require voltage during startup, you could very easily not have enough voltage to fire one circuit, say the injectors.
Yeah, cause even if you have adequate fuel pressure, the injectors may not be firing. Maybe before you get that fuel pressure gauge, trying shooting some propane down the intake when you have this no start condition. Have another person turn it over while you operate the propane, if it fires, then you would know that you weren't getting fuel in the cylinders.
astro355
Year: 1989
Postby Leeann_93Leeann_93 is online! » January 23rd 2009, 8:25pm
You need a fuel injection pressure test kit - it'll need to do at least 65 psi. It connects to a schrader valve on the fuel pressure line as it goes into the intake manifold.
Most parts places have them for about $30 and Harbor Freight has a kit for about $12.
EDIT: damn, beaten by 355 again (whose post wasn't there when I started typing, I swear)
Image Image
Topics: 27
Year: 2002
Postby astro355 » January 23rd 2009, 8:29pm
Leeann_93 wrote:You need a fuel injection pressure test kit - it'll need to do at least 65 psi. It connects to a schrader valve on the fuel pressure line as it goes into the intake manifold.
Don't worry, dear. Its those super moderator powers! :screaming:
astro355
Year: 1989
Postby Leeann_93Leeann_93 is online! » January 23rd 2009, 8:31pm
astro355 wrote:Don't worry, dear. Its those super moderator powers! :screaming:
:lol:
Image Image
Topics: 27
Year: 2002
Postby RussTypeS [OP] » February 6th 2009, 6:53pm
It turned out to be a leaking fuel pressure regulator. Diagnosed by good fuel pressure at first but it dropped steadily as soon as the pump stopped running (about 2 seconds after turning the ignition to "on" but not starting), clamping the fuel line from the tank did not stop the leak so it had to be something in the CPI unit. It turns out that when the FPR leaks it spills fuel in half of the intake plenum (so only one side of the engine is rich) causing the rough idle and hard starting unless the throttle is open (makes sense, you have to lean it out a bit to compensate for all the fuel pooled in the LIM).
Once I removed the UIM I found almost exactly what this guy found: http://www.treasureboards.com/blazer/cpi/CPI.html. $45 and a trip to Autozone later I have a new FPR and a smooth running van. Thanks for the help guys.
RussTypeS
Postby astro355 » February 6th 2009, 9:53pm
Great! Glad to hear you got it running good again.
astro355
Year: 1989
Postby Astro Hole » October 3rd 2014, 11:15pm
Resurrecting dinosaur bones for no apparent reason...
...oh wait, I am having the exact same problem. Instead of starting another thread for the same issue, I figured I'd give this one a bump in case anyone else could use the info. (And so I can find it again.)
Astro Hole
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Astro Hole has been a member for 2 full yearsAstro Hole has been a member for 2 full years
Images: 2
Alias (AKA): Hey you; A. Hole
Year: 2001
Extra Info: 223672 miles
Postby Astro Hole » October 4th 2014, 12:11am
A new fuel pressure regulator is $14.88 with free shipping.
A HF fuel pressure gauge is $19 and change. The nice one is almost a hundred.
My question is, should you spend more for the tool to tell you that you might need to change the part or save the difference and just change the part?
:confused:
Astro Hole
Fueling (1/2 tank)
Fueling (1/2 tank)
Images: 2
Year: 2001
Postby Leeann_93Leeann_93 is online! » October 4th 2014, 2:25am
This thread is about a diferent injection system than on your Astro.
Start a new thread, but the correct tool.
Image Image
Topics: 27
Year: 2002
Postby Astro Hole » October 4th 2014, 1:46pm
Thanks Leeann. I'll be stopping in at HF this weekend, and the pressure gauge is now on my list.
Astro Hole
Fueling (1/2 tank)
Fueling (1/2 tank)
Images: 2
Year: 2001
It is currently May 23rd 2017, 9:49pm
Attached by: paulbot
paulbot
Time: 4:30am
alife2
Comments: 22
Date: May 20 '17
Time: 9:13pm
alife2
Comments: 22
Date: May 20 '17
Time: 5:08pm
alife2
Comments: 22
Date: May 18 '17
Time: 7:36pm
alife2
Comments: 22
Date: May 17 '17
Time: 10:15pm
