Ignition Coil Replacement How-To (2003 Astro)
Postby chemist [OP] » August 13th 2009, 3:57am
I don't know how to tell when your ignition coil is on the way out. It may start with power decreases as mine did. But it will eventually fail. You could be procrastinator and wait like me, then end up doing it at the most inopportune time possible. My advice would be to do it when you do the spark plugs and wires. It's a $30 dollar part, and with as much of a pain as the engine cover is to remove, you might as well do it then anyway.
Start by removing the engine cover, as shown in one of my previous posts, found here: http://www.astrosafari.com/viewtopic.php?f=9&t=4079
Once you have that off, your ignition coil is located here:
It looks inaccessible, but it isn't. The ignition coil is kind of tucked in there, but it can be gotten out. The ignition coil is contained in a bracket that has another component attached, and is bolted to top of the motor. There may be another bracket holding it down—we'll cover that later.
Start by removing the insulated wire, as shown (note: replacement wire should be obtained from a spark plug wire kit.)
Next remove the wire harness on the other side of the ignition coil.
The ignition coil bracket is held on by 2 – 10 mm bolts. To remove them you'll need a deep well 3/8” drive or 1/4” drive socket with one or two short to medium sized extensions. I could not give good pictures of these bolts. They are in a straight line going from the passenger compartment toward the front of the van. Note the location of the one closest to you by the position of the socket and extensions. If you look closely, just at the edge of the ignition coil shadow you'll see the second one appearing to be under the coil—it's not, it's just on the other side, toward the front of the van...
TIP: Use a telescoping magnet at the bottom of your socket to catch the bolts as they come out—if you don't know what I'm talking about, it's something like this one: http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_TELESCOPING-MAGNET-Ampro_9021426-P_N3499_T|GRP2083____
Alternatively, dip your socket in all purpose grease before slipping it over the bolts. If your lucky, the bolts will stick inside when you pull the socket out.
If you're incredibly unlucky—I was—there will be a bracket still holding it. If not, scroll down to the part where it comes out.
If you are so unlucky, remove the air intake assembly, as shown in one of my previous posts, found here: http://www.astrosafari.com/viewtopic.php?f=9&t=1142
Below are photos of that bracket I was telling you about (taken from inside and outside the van. There are two 10 mm bolts on it. To get at them, you'll need a 10 mm deep well socket, extensions and a universal joint—3/8” drive worked best for me. Either dip the socket in grease or use a telescoping magnet to retain those bolts—one is actually a nut and not a bolt.
Before you do this, there is a 10 mm screw—best removed from inside the van. In the top photo, I tried to point at it with a screwdriver, but didn't get a great photo of it. To remove, you will need a 10 mm racheting wrench. You will also need a telescoping magnet to catch this.
Front of bracket:
Okay, you're finally ready to pull out the ignition coil. There is a wiring harness attached to another part on the ignition coil bracket—remove it.
Unless the bracket has bolts or screws, it's riveted. Secure the whole thing in something like a vise and drill out the rivets—once you have one end out, you can tap them out with a small screwdriver or something.
You'll need to reassemble the bracket onto the new ignition coil.
Once done, re-install the same way it was removed.
TIP: As you've no doubt figured out, human hands don't reach many of the places you need to go to re-install bolts. You'll need to hold bolts and nuts in a socket, often connected to extensions and/or universal joints. One way to keep bolts in a socket is to dip the end of the socket in grease. Another is to try to position the nuts or bolts using a telescoping magnet. You take a chance either way. I prefer the grease method.
If anyone more experienced has other tips, or notices anything I might have missed, please reply to this post and give them.
2003 Chevy Astro, AWD, 124,000 mi
a must read
chemist
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: chemist has been a member for 8 full yearschemist has been a member for 8 full yearschemist has been a member for 8 full yearschemist has been a member for 8 full yearschemist has been a member for 8 full yearschemist has been a member for 8 full yearschemist has been a member for 8 full yearschemist has been a member for 8 full years
Topics: 26
Re: Ignition Coil Replacement How-To (2003 Astro)
Postby rev_les » August 13th 2009, 4:17am
nice write up! The extra component on there ( early models don't have it) is your ignition module. :mrgreen:
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby Matrixx » August 13th 2009, 4:58am
Another outstanding post and writ-up chemist. Great job I must say, Thanks.:)
Matrixx
Years of Membership: Matrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full years
Postby gollihughj » February 9th 2010, 11:35pm
Great post, a big help in my mission to replace the coil on my 96 ASTRO 2WD. I was lucky and didn't have a second bracket to remove. Still had the 3 main studs to secure the coil bracket to the block. However, on mine the stud closest to the front of the van had the throtle cable bracket mounted on it, which had to be removed from the stud before the stud was removed. Thanks again Chemist for your great post, really saved me some time and saved me from alot of frustration!
gollihughj
Years of Membership: gollihughj has been a member for 7 full yearsgollihughj has been a member for 7 full yearsgollihughj has been a member for 7 full yearsgollihughj has been a member for 7 full yearsgollihughj has been a member for 7 full yearsgollihughj has been a member for 7 full yearsgollihughj has been a member for 7 full years
Alias (AKA): JG
Year: 1996
Extra Info: LT 4.3L V6 RWD
Postby workinVan » February 10th 2010, 3:45am
i did mine 2 months ago including the control module
i did the control module again last week as the part failed and needed to be replaced( thank god i bought a code reader that i keep in the truck) the problem was that the screws holding it on had rusted and become a little to brittle to be tightened without snapping after i hit a big pothole that rattled it off
as the only screws i had that fit through the icm holes were stainless steel woodscrews i had to put a wood block on the backof the bracket but its more solid then broken screws.
on the plus side my milage went from 12/ gal to 14/gal and i can accelerate uphill again.
its a great part to change if you have **** mileage and a lack of passing power.
2000 cargo 4.3 v6 W rwd, a/c, G80, silverstars, hood struts, magnaflow cat
and a big honkin air filter....possibly for sale make an offer
workinVan
Years of Membership: workinVan has been a member for 7 full yearsworkinVan has been a member for 7 full yearsworkinVan has been a member for 7 full yearsworkinVan has been a member for 7 full yearsworkinVan has been a member for 7 full yearsworkinVan has been a member for 7 full yearsworkinVan has been a member for 7 full years
Topics: 9
Alias (AKA): notjim
Extra Info: 4.3 rwd cargo
Postby bkmorency13 » August 11th 2010, 4:18am
:ty: Will definitely help me out in the morning. i cant wait to see how much more power I'll have once finished. its like a light show down there right now. hard to start, but runs great once started. will post my news once finished. i would upload photo's but my laptop doesn't have a port to do so.
bkmorency13
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: bkmorency13 has been a member for 6 full yearsbkmorency13 has been a member for 6 full yearsbkmorency13 has been a member for 6 full yearsbkmorency13 has been a member for 6 full yearsbkmorency13 has been a member for 6 full yearsbkmorency13 has been a member for 6 full years
Topics: 7
Alias (AKA): slim
Extra Info: 4.3L rwd
Postby lind777 » June 2nd 2011, 6:47pm
I have the extra bracket which causes a huge pain. I found I did not need to completely remove the one screw that you loosen from the front (left hand, lower one which removes vertically when looking at it from the front).
Also, I highly recommend opening the front hood to let more light in as well as removing the air intake assembly to let more light in.
lind777
Years of Membership: lind777 has been a member for 8 full yearslind777 has been a member for 8 full yearslind777 has been a member for 8 full yearslind777 has been a member for 8 full yearslind777 has been a member for 8 full yearslind777 has been a member for 8 full yearslind777 has been a member for 8 full yearslind777 has been a member for 8 full years
Postby jimg » November 27th 2011, 10:24pm
Just a note on hoding those nuts or bolts on the end of your socket, try doubling up some paper towel and placing the towel over the head - then force the socket on. the paper will jamb and hold your bolt long enough to get it threaded. Lots o luck on the repairs.
jimg
Years of Membership: jimg has been a member for 5 full yearsjimg has been a member for 5 full yearsjimg has been a member for 5 full yearsjimg has been a member for 5 full yearsjimg has been a member for 5 full years
Postby beninski » March 25th 2012, 5:20pm
Hello. I just joined this website and must say that this acticle's instructions on ignition coil replacement was extremely helpful. Other than doing brakes myself, this is the first real repair job I've attempted. My 2000 Safari now starts in damp weather and I am noticing a huge increase in acceleration power. Thanks for a great post!!
beninski
Years of Membership: beninski has been a member for 4 full yearsbeninski has been a member for 4 full yearsbeninski has been a member for 4 full yearsbeninski has been a member for 4 full years
Year: 2000
Extra Info: SL RWD 4.3L
Postby junkout » March 31st 2012, 3:04pm
i changed mine without removing the bracket i just drilled out the rivits in place and bolted new coil in changed ignition module with bracket still on engine to i thought it was easier but you may not
junkout
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: junkout has been a member for 5 full yearsjunkout has been a member for 5 full yearsjunkout has been a member for 5 full yearsjunkout has been a member for 5 full yearsjunkout has been a member for 5 full years
Extra Info: awd work van
Postby Brian D » April 10th 2012, 9:34pm
In regards to the coil replacement on 2000 and up Chevy Astro that was a great description with pictures however I think I found an easier way.. Basically the coil is sandwiched in between that bracket that is a pain in the butt to get out and has to be removed from engine along with another electrical component.. If you look at the coil itself from the passenger side, there are only 2 rivets holding the coil in there where there should be BOLTS,, GRRR.. Just drill the bottom 2 rivets out and you should be able to pull the coil right up and out without disconnecting "anything else" other than the wiring harness and spark plug wire...
Brian D
Years of Membership: Brian D has been a member for 4 full yearsBrian D has been a member for 4 full yearsBrian D has been a member for 4 full yearsBrian D has been a member for 4 full years
Year: 2000
Extra Info: 4.3 V-6 RWD
Postby george » July 15th 2012, 4:51pm
New member here, great website. Thanks to the chemist for this info, I never would have tried this without this blog. That being said, I still made a rookie mistake and didn't pay close enough attention to the order in which I removed the nuts & 10mm bolts holding the coil bracket & cable bracket that sits on top. Is there anyway to get an exploded schematic of this on-line? My searches haven't gotten very far. Thanks for the info.
george
Years of Membership: george has been a member for 4 full yearsgeorge has been a member for 4 full yearsgeorge has been a member for 4 full yearsgeorge has been a member for 4 full years
Year: 2003
Extra Info: 4.3L V6 AWD
Postby kennysmoke » January 26th 2014, 8:12pm
I just changed the coil in my 2003 following these steps... although difficult to reach everything it went smoothly... thanks for the great write up!
"Live Free Or Die" Image
kennysmoke
Firing on 8 Cylinders (L1)
Years of Membership: kennysmoke has been a member for 5 full yearskennysmoke has been a member for 5 full yearskennysmoke has been a member for 5 full yearskennysmoke has been a member for 5 full yearskennysmoke has been a member for 5 full years
Images: 7
Alias (AKA): kennysmoke
Year: 2003
Extra Info: AWD Tow Pakage
Postby martian » June 21st 2014, 1:09am
Also want to declare my appreciation for this. I wasn't aware of the second bracket (the throttle cable mount) and was getting quite frustrated. Thanks!
martian
Years of Membership: martian has been a member for 2 full yearsmartian has been a member for 2 full years
Alias (AKA): Rick
Year: 2002
Extra Info: Commercial AWD
Postby MrPaseoDave » October 31st 2014, 9:07pm
Great post.... more informative than the Hayne's manual. :)
MrPaseoDave
Years of Membership: MrPaseoDave has been a member for 2 full yearsMrPaseoDave has been a member for 2 full years
Year: 2003
Postby pauldeere » October 31st 2014, 9:48pm
Great post and write up, as they say a pic. is worth a thousand words, sure hold true trying to explain this particular repair.
pauldeere
Years of Membership: pauldeere has been a member for 2 full yearspauldeere has been a member for 2 full years
Topics: 18
Alias (AKA): Tall Paul
Postby Slim1 » January 6th 2017, 3:27am
Information, the gift that keeps on giving. ;)
This was a huge help, as I had never done one on my 2002 with the bracket on it. I did cut a corner, and only disconnected the sensor, and just took the flex hose off instead of the whole aircleaner. My trick for getting those nuts bolts etc to stay in the socket, is scotch tape. If it's a nut just put the tape over it in the socket and use a pick to punch a hole in it. For bolts & studs, put it in the socket, and wrap two pieces of tape over the edges, one on each side. It pretty much tears off without any residual tape left on the nut or bolt. Anyway, thanks for the pictures, and info, sure saved me a lot.
Slim1
Years of Membership: Slim1 has been a member for 4 full yearsSlim1 has been a member for 4 full yearsSlim1 has been a member for 4 full yearsSlim1 has been a member for 4 full years
Year: 2002
Extra Info: 4.3 RWD
It is currently January 18th 2017, 11:15pm
Ingmire
Date: Today
Time: 1:09am
Driftedone
Comments: 13
Date: Jan 10 '17
Time: 7:12am
Echo
Comments: 17
Date: Jan 09 '17
Time: 6:50pm
Attached by: shredzorv2
shredzorv2
Date: Jan 01 '17
Time: 2:12am
Voltsmith
Comments: 40
Date: Dec 28 '16
Time: 10:24pm
Users browsing this forum: MSNbot Media and 7 guests
