Harmonic Balancer or ........?
Postby garymocwi [OP] » August 16th 2009, 3:14am
The crankshaft pulley on my 02 Safari is not running true and is wobbling a bit. Not a wobble side to side, but up & down. It has the effect of changing the belt tension because the belt tensioner is moving back & forth as well. It also appears that the harmonic balancer is wobbling the same. So far I've replaced the harmonic balancer (but used the same pulley) and it still has the same problem. Everything is tight and there isn't much wiggle room to shift the pulley around when mounting it. Not sure what is going on. It almost seems as if the crankshaft is bent on the end, but I suspect with the hardness of the metal it would crack before it would bend. Also the oil seal that goes around the back end of the harmonic balancer would be damaged if the crankshaft was wobbling and it looks fine. Everything else in the serpentine belt path looks good and the crankshaft pulley doesn't appear to be damaged.
The engine runs good and doesn't have any weird shakes or vibrations. The van has 57,000 miles on it.
Any Ideas? Or is this something to not worry about.
2002 SLE GMC Safari RWD
Color - Crappy Red/Brown - ok it looks like a dark brown maroon kind of thing
garymocwi
Years of Membership: garymocwi has been a member for 4 full yearsgarymocwi has been a member for 4 full yearsgarymocwi has been a member for 4 full yearsgarymocwi has been a member for 4 full years
Re: Harmonic Balancer or ........?
Postby gtkane » August 16th 2009, 3:45am
If it ain't broke, don't fix it.
I have seen a lot of pullies/balancers that wobble and gave no vibrations.
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby astro355 » August 16th 2009, 8:04am
gtkane wrote:If it ain't broke, don't fix it.
Quoted for truth.
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 4 full yearsastro355 has been a member for 4 full yearsastro355 has been a member for 4 full yearsastro355 has been a member for 4 full years
Year: 1989
Extra Info: 355 V8 700R4
Postby Big_kid » August 16th 2009, 8:04pm
Try a junk yard pulley?
Firing on 3 Cylinders (L4)
Years of Membership: Big_kid has been a member for 4 full yearsBig_kid has been a member for 4 full yearsBig_kid has been a member for 4 full yearsBig_kid has been a member for 4 full years
Topics: 66
Images: 39
Extra Info: 2WD conversion
Postby garymocwi [OP] » August 17th 2009, 2:14am
Big_kid wrote:Try a junk yard pulley?
Possibly the next step.
I've also got some squeaking that's coming from the serpentine belt as well. It got worse after spraying some belt dressing on it. Anything above idle and it squeals like a pig. The belt and tensioner are new. I may end up cleaning the pulleys with a toothbrush again (like I did on my 95 Astro). My neighbor says to use silicone spray. Anyone try this with success?
garymocwi
Postby Big_kid » August 17th 2009, 3:11am
I once had a can of belt dressing. It only helped while it was being sprayed. After that, it was worse.
Clean the pulleys, scuff up any glaze on them. I'd avoid trying silicone, they rely on friction to drive them.
Topics: 66
Images: 39
Postby garymocwi [OP] » August 17th 2009, 4:31am
Anyone have a source of new crank pulleys (in case I can't find one at a bone yard)?
garymocwi
Postby plumberjames » October 13th 2009, 1:36pm
Hello, I have a 98 safari W4.3 AWD. my crank nose also flopps around, so my reluctor wheel scrapes the TDC sensor(this makes a horrible noise). My van only has 150,000 mi (240,000km). do you thing i need a rebuild or new crank bearings? oil presure seems good.
plumberjames
Years of Membership: plumberjames has been a member for 3 full yearsplumberjames has been a member for 3 full yearsplumberjames has been a member for 3 full years
Extra Info: 4.3 AWD
  • Balancer
    by Fatjoe216 » March 19th 2010, 1:59pm in Engines
    Last post by icebrrg3rd View the latest post
    March 19th 2010, 10:20pm
    19Replies
    180Replies
    May 22nd 2013, 12:05am
  • Balancer Shaft??
    by chargedbird » November 23rd 2011, 6:17pm in Engines
    Last post by RECox286 View the latest post
    November 23rd 2011, 11:57pm
It is currently May 22nd 2013, 12:05am
Attached by: SilverBullet1997
SilverBullet1997
Time: 4:49pm
kumisukka
Comments: 0
Date: May 20 '13
Time: 2:20pm
Attached by: chevymaher
Comments: 19
Date: May 20 '13
Time: 1:37am
Comments: 19
Date: May 20 '13
Time: 12:40am
Attached by: aztec1987
aztec1987
Date: May 19 '13
Time: 2:44am
Users browsing this forum: Bing [Bot] and 15 guests
