how to set timing????
Postby 1992RS [OP] » April 1st 2010, 4:01am
OK last thing I think I need to do to my van is set the timing again, I want to start from square one and pull the dizzy and set #1 tdc can some one tell me step by step the correct process for this?? I wish to do this as my distributor is currently in the wrong position relative to the motor and by this I mean the distributor body is turned to far clockwise I believe because the two wiring plugs that go to it are pointed at 8 o'clock when I think they are supposed to be at 7 o'clock I got the rotor pretty close to where it was when I pulled it but I just want to get it right so I can just drive the dang van without having to stomp on it to have it run smooth, PLEASE HELP
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Years of Membership: 1992RS has been a member for 7 full years1992RS has been a member for 7 full years1992RS has been a member for 7 full years1992RS has been a member for 7 full years1992RS has been a member for 7 full years1992RS has been a member for 7 full years1992RS has been a member for 7 full years
Topics: 38
Alias (AKA): tony
Extra Info: RS 4.3v rwd
  • TWO Crank Pulley Timing Marks
    by sixsix » February 12th 2017, 9:59pm in Engines
    February 22nd 2017, 11:18pm
    65
    February 26th 2017, 1:58am
Re: how to set timing????
Postby webcat » April 1st 2010, 4:22am
Astro 355 showed me how to find TDC a while back , this is from a old post
webcat wrote:
Whats the easiest way to get your #1 piston at TDC and have it be on the compression stroke?
Astro355 wrote answer
Take the valve cover off on the driver side. While rotating the engine by hand, watch the valves. During the exhaust stroke, you will see the exhaust valve open. Right before the compression stroke, the intake valve will open and close and during compression, both valves will be closed.
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby 1992RS [OP] » April 1st 2010, 4:34am
kinda helps but I am not to excited to take the valve cover off, is there any way to use the timing mark on the crank pulley?? I have heard that if you pull the number one plug you can put a small rag or similar item in the hole and the compression will blow it out when #1 is on its comp stroke?? then just line up the timing mark on the pulley with the pointer ?????
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby Jasen » April 1st 2010, 4:41am
I pull the #1 plug, stuff a rag in the hole good and tight with a screw driver. Bump the motor until you hear it "POP" out, then disconnect the batt. and use a wire as a feller through the spark plug hole and crank the motor back and forth by hand to get the piston at TDC.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Postby 1992RS [OP] » April 1st 2010, 4:52am
Cool, :ty: kinda what I thought only I was gonna hand crank the motor, then what though how do i get the dizzy set up just right???
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby Mr_Bowtie » April 1st 2010, 2:30pm
Gotta get the rotor pointing towards the #1 spark plug on the dizzy cap once you got the #1 cylinder at TDC.....right?
I have never had to do TDC......I always marked the dizzy and pulled it out and it always dropped right back in for me.
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
Postby astro355 » April 1st 2010, 2:39pm
Why not just loosen the distributor and rotate it from the 8 o'clock position to the 7 o'clock position? You don't need to take it apart to do that. And for that matter, why not just start the van, loosen the distributor and slowly rotate the distributor until the van idles good. That's how I time my van. That's one reason why I love these vans. I can rotate the distributor while driving it down the road. Makes it real easy to power time it.
astro355
Firing on 4 Cylinders (L6)
Year: 1989
Extra Info: 355 V8 700R4
Postby Mr_Bowtie » April 1st 2010, 2:46pm
astro355 wrote:Why not just loosen the distributor and rotate it from the 8 o'clock position to the 7 o'clock position? You don't need to take it apart to do that. And for that matter, why not just start the van, loosen the distributor and slowly rotate the distributor until the van idles good. That's how I time my van. That's one reason why I love these vans. I can rotate the distributor while driving it down the road. Makes it real easy to power time it.
355 FTW!!!!! :rockon:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Postby 1992RS [OP] » April 1st 2010, 6:19pm
Thats the thing here if I were to rotate it back to the seven oclock position then effectively my timing would be thrown off because when I reinstalled the dist. I lined the rotor back up as close as i could mith the mark i made where the rotor was pointing when I removed it does that make sense??
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby astro355 » April 1st 2010, 6:37pm
1992RS wrote:Thats the thing here if I were to rotate it back to the seven oclock position then effectively my timing would be thrown off because when I reinstalled the dist. I lined the rotor back up as close as i could mith the mark i made where the rotor was pointing when I removed it does that make sense??
You are over-complicating this. All you have to do is remove the doghouse, start the engine, loosen the holddown just enough so you can rotate the distributor and slowly turn the distributor and listen to the engine. Turn the distributor both clockwise and counterclockwise, not a lot either. Only a few degrees can make all of the difference. Mark the starting position if you like. Do this while in idle and even driving down the street. Now, when doing this while driving, adjust the distributor ONLY when stopped (at a light, stopsign, whatever) and then drive it. Try to notice things like torque and horsepower and adjust it to the point where both "feel" the best.
You have to understand that every engine is different be it by size, displacement, wear and age. Sure, there are general guidelines to setting the timing on an engine but if an engine wants more timing, give it more timing (or vice versa regarding retarding).
If you want to wait til this weekend, I'll shoot a video of this while I'm doing it in my van.
And did you know that running too far advanced can make your engine run very hot?
astro355
Year: 1989
Postby 1992RS [OP] » April 1st 2010, 9:10pm
No I didnt know that, my only real issue with just adjusting it where its at is that the wires that plug in to the dizzy are drawn pretty tight due to its position so I would be unable to turn it clockwise only counter clockwise thats my issue, I would post a pick if my fiance didnt take my camera with her to her sis' graduation.
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby Mr_Bowtie » April 1st 2010, 11:31pm
Oh ya a tech video coming I can't wait! :rockon:
Here is the dizzy placement on my '92 W motor.......just to give you a idea of where mine is...if its any help to you. :shrug:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Postby Jasen » April 2nd 2010, 1:06am
Bumping the motor over you will hear the POP out which also lets you know your on the compression stroke.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Postby 1992RS [OP] » April 2nd 2010, 1:34am
Yeah mine is like 20-30 degrees clockwise from where yours is and thats why my wires are so tight now I know I need to pull it out and try moving it back some.
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby astro355 » April 2nd 2010, 2:32am
1992RS wrote:Yeah mine is like 20-30 degrees clockwise from where yours is and thats why my wires are so tight now I know I need to pull it out and try moving it back some.
Oh, now I see. If that's the case, you will have to remove and reinstall the distributor. The last thing you want to happen is short those wires out on the distributor housing since they are too tight. And yes, that can happen.
astro355
Year: 1989
Postby 1992RS [OP] » April 2nd 2010, 3:52am
Yes that is my fear, I plan on doing it tomorrow by first clocking the motor and then pulling the cap after that I will pull the dizzy and clock that to the correct position and put it back in and hope she purrs like like a kitten after some slight tweaking
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby LEVE » April 2nd 2010, 12:47pm
Here's what I've always done:
  • Remove all plugs
  • Insert a straw into Plug # 1 hole
  • Put your finger into Plug #1 hole
  • Manually rotate engine to feel compression build up
  • Insert straw into #1 plug hole
  • Continue rotation of engine
  • Watch for the straw to go up to it's highest point
  • At the highest point of the straw's rise, that's TDC, stop rotation
  • Ground the #1 Plug so you can see the electrode
  • Unlock the distributor so you can manually rotate it
  • Turn the ignition to "Run" mode, not "Start" mode.
  • Manually rotate the distributor so you see a spark on the grounded plug
  • Tighten the distributor down when you just see the spark occur.
  • You're done
I've used this method on EFI (using TDC as a spark point) engines, and on non EFI (using 6-7 degrees BTDC) for years. It's worked, and I rarely use any timing light. This sets the sparking at the gnat's eyebrow, not in the ballpark. If there's a continued problem it's now in the distributor gearing or timing chain that drives the gearing.
LEVE
Years of Membership: LEVE has been a member for 6 full yearsLEVE has been a member for 6 full yearsLEVE has been a member for 6 full yearsLEVE has been a member for 6 full yearsLEVE has been a member for 6 full yearsLEVE has been a member for 6 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby astro355 » April 2nd 2010, 4:10pm
You don't need to set the timing by finding TDC for cylinder #1. All you need to do is much the rotor counterclockwise. Mark the distributor alignment first. Remove the distributor and once you feel the distributor shaft gear become free of the camshaft drive gear, rotate the rotor counterclockwise just one tooth and reinstall the distributor. It may not go in all the way, but the slot on the oil drive shaft is oversized so you should be able to work it in. You will then rotate the distributor housing the same distance as the rotor rotated. Start the engine and time if necessary. If you still need to move the distributor, redo the steps again.
astro355
Year: 1989
It is currently February 26th 2017, 1:58am
AstroNuts
Comments: 73
Date: Feb 24 '17
Time: 4:56am
AstroNuts
Comments: 73
Date: Feb 23 '17
Time: 5:19am
Comments: 22
Date: Feb 22 '17
Time: 4:37am
Attached by: 97cargocrawler
97cargocrawler
Comments: 73
Date: Feb 21 '17
Time: 6:29pm
Attached by: Coaster
CoasterCoaster is online!
Comments: 113
Date: Feb 20 '17
Time: 5:25pm
