"ENGINE" COOLANT DRAIN PLUG
Postby paul43 [OP] » April 8th 2010, 10:32pm
I am in the process of draining and replacing the coolant in my 2001 Chevy Astro van with a Vortec 4300 V6.
Can anyone tell me or show me me a picture of where the ENGINE COOLANT DRAIN PLUG (NOT THE RADIATOR PLUG)is located so I can make sure I have drained all the fluid out. I have a set of GM service manuals and in the manuals they stated that if you don't drain the block will only get about 50% of the coolant out---being that the 2001 call for the DEX-COOL Antifreeze which they claim is good for 5 years or 50,000 miles I would like to make sure I have all the old coolant & water out before I add the new stuff
I ran a flush in it and remove the thermostat and put the gooseneck back on and flushed it until clear water came out---now I just want to empty the block.
Also in it a good idea to use DISTILLED WATER for the coolant mix or is regular tap water OK.
Thank You,
Paul Lijeski
Melbourne, FL
paul43@cfl.rr.com
paul43
Years of Membership: paul43 has been a member for 7 full yearspaul43 has been a member for 7 full yearspaul43 has been a member for 7 full yearspaul43 has been a member for 7 full yearspaul43 has been a member for 7 full yearspaul43 has been a member for 7 full yearspaul43 has been a member for 7 full years
Extra Info: LS 4.3 V6 RWD
  • Oil drain plug gasket
    by ryguy » February 12th 2017, 12:14am in Engines
    Last post by markmitchmarkmitch is online! View the latest post
    February 13th 2017, 2:25am
  • Uh oh, coolant on top of engine
    by juststartin » December 12th 2016, 2:33am in Engines
    Last post by MI_GhostMI_Ghost is online! View the latest post
    December 23rd 2016, 7:58am
    May 28th 2017, 3:56pm
Re: "ENGINE" COOLANT DRAIN PLUG
Postby 01safari » April 9th 2010, 1:07am
I don't have a picture, but the the "plugs" you are looking for are on each side of the block. If you were to look just in front of the oil filter, there should be a hex headed plug. If I remember right it was 1/2' or 9/16' . When you remove it, do it slowly so you don't get splashed with coolant. There is one on the other side just like. That one is around the starter. I was able to remove both without any real trouble. Also be sure to use some thread sealant on them before reinstalling them.
I did use distilled water on mine, even though the manual says clean drinking water.
01safari
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: 01safari has been a member for 8 full years01safari has been a member for 8 full years01safari has been a member for 8 full years01safari has been a member for 8 full years01safari has been a member for 8 full years01safari has been a member for 8 full years01safari has been a member for 8 full years01safari has been a member for 8 full years
Topics: 12
Extra Info: RWD
Postby Jasen » April 9th 2010, 1:11am
Welcome to A/S
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Postby Mr_Bowtie » April 9th 2010, 2:23pm
Welcome!
Distilled water is best, but tap water works fine. :chevy:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Years of Membership: Mr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full years
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
It is currently May 28th 2017, 3:56pm
Attached by: paulbot
paulbot
Date: May 22 '17
Time: 4:30am
alife2
Comments: 22
Date: May 20 '17
Time: 9:13pm
alife2
Comments: 22
Date: May 20 '17
Time: 5:08pm
alife2
Comments: 22
Date: May 18 '17
Time: 7:36pm
alife2
Comments: 22
Date: May 17 '17
Time: 10:15pm
