Changing head gasket, how difficult is it? (Engine is out)
Postby Astro88 [OP] » May 17th 2010, 5:02pm
Hello.
I wonder how hard it is to change the head gaskets on my 88 astro 4,3?
I already have the engine out of the car.
I have never done this kind of a job, is it difficult?
Is there some guides i can find online?
Anything special I have to remember?
Astro88
Years of Membership: Astro88 has been a member for 7 full yearsAstro88 has been a member for 7 full yearsAstro88 has been a member for 7 full yearsAstro88 has been a member for 7 full yearsAstro88 has been a member for 7 full yearsAstro88 has been a member for 7 full yearsAstro88 has been a member for 7 full years
  • Rough idle, blown head or intake gasket?
    by cathairez » October 19th 2016, 6:35pm in Engines
    Last post by Wimpazz View the latest post
    October 31st 2016, 1:47am
  • Temperature changing erratically
    by Jasekcco » January 8th 2017, 7:28am in Engines
    Last post by Jasekcco View the latest post
    January 8th 2017, 9:49pm
    7
    25
    March 24th 2017, 6:54pm
Re: Changing head gasket, how difficult is it? (Engine is ou
Postby LEVE » May 17th 2010, 5:10pm
It's not hard... but it is time consuming. Just go slow, use a manual, be aware of your torque settings and buy a Head up kit for the gaskets and seals you'll need.
Whenever I pull a head here's what I do for every cylinder.
1. Rotate the piston to BDC (Bottom Dead Center).
2. Spray the cylinder walls with Carb Cleaner.
3. Use the air compressor to dry the walls.
4. Run my thumbnail up and down the walls searching for unseen grooves.
5. Recoat the cylinder wall with motor oil.
6. Rotate the Piston to TDC (Top Dead Center).
7. Flood the top of the piston with Carb Cleaner.
8. Wait about 15 seconds for the carb cleaner to soften any carbon build up.
9. Using scotchbrite or a thin putty knife, I remove the carbon.
10. Repeat step 7 - 8 as necessary.
11. When the top of the piston is clean I again flood the area with carb spray.
12. Dry the area off with the compressed air.
13. Again put some oil into the cylinder and lower the piston.
15. Move on to the next cylinder.
16. Put a rag into the cylinder just worked on to keep it clean.
17. Repeat for all cylinders.
19. Remove ALL head gasket debris.
20. Using scotchbrite I hunt for burrs on the block mating surface and remove them.
LEVE
Years of Membership: LEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby Woodweasel » May 17th 2010, 5:11pm
Well if you pulled the engine, you can pull the heads. Get yourself a shop manual. They have a decent explanation along with some grainy black and white pictures, they do help to see what they are talking about sometimes. The hardest part is getting the wires and hoses back in the right spot, which is minimal. Removing the intake and heads is easy with it on an engine stand.
Tear into it!!!! :banana: You run into problems? bring em back here if you cant figure it out. Thats what its all about!
GOOD LUCK and keep us posted!
Woodweasel
Firing on 7 Cylinders (L1)
Years of Membership: Woodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full years
Topics: 36
Extra Info: 140K miles
Postby 1992RS » May 17th 2010, 5:13pm
man with the engine out this should be a super easy yet time consuming job, the worst part of changing the headgaskets in these vans is the limited work space and with the motor out you have essentially made this the easiest motor ever to work on. as far as a guide check out www.autozone.com you may have to complete a free registration but they have free repair manuals that include torque specs and tightening/ loosening sequences also, i used the site to get the info for my 1992 and it was very thorough.. hope this helps and have fun getting it done and remember to reward yourself a beer or something when your done for the night, also remember to get new head bolts as they are stretch type bolts and will require changing.
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Years of Membership: 1992RS has been a member for 7 full years1992RS has been a member for 7 full years1992RS has been a member for 7 full years1992RS has been a member for 7 full years1992RS has been a member for 7 full years1992RS has been a member for 7 full years1992RS has been a member for 7 full years
Topics: 38
Alias (AKA): tony
Extra Info: RS 4.3v rwd
Postby ShAgSTRO » May 17th 2010, 5:31pm
relatively easy...certainly easier than having the engine in
1986 Astro...I like my EFI carb ;)
ShAgSTRO
Years of Membership: ShAgSTRO has been a member for 6 full yearsShAgSTRO has been a member for 6 full yearsShAgSTRO has been a member for 6 full yearsShAgSTRO has been a member for 6 full yearsShAgSTRO has been a member for 6 full yearsShAgSTRO has been a member for 6 full years
Topics: 16
Extra Info: 4.3L
Postby Astro88 [OP] » May 17th 2010, 5:41pm
Thank you for quick replys.
I have one more question. I took of the rocker cover some days ago just to look inside. It seems like there is a bit of "hardend" (dont know the english word) oil inside.
What is the best way to remove/clean the head when its loose from the engine? I dont want to do anything wrong with the valve spings etc inside there.
Astro88
Postby 1992RS » May 17th 2010, 9:13pm
use a good aerosol degreaser and nylon brushes, thats what i did, also definately bring the heads into a machine shop and have them checked for cracks and warping hate to see you put it all back together and have it leak again in a few days
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby Astro88 [OP] » May 17th 2010, 9:17pm
Ok, but can clean it with water also?
The head gasket on the engine is not blown, but I want to change it because its fairly old and I have the engine out of the car.
So I guess there is no damage on the heads.
Astro88
Postby chevy57bert » May 17th 2010, 9:51pm
Astro88 wrote:Ok, but can clean it with water also?
I use a hottank (@ work)
Why did you took your heads off Torje?
It seems that the gaskets look good.
maybe you have an other issue with your engine?
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Topics: 68
Images: 68
Alias (AKA): Bertjuh
Year: 1992
Extra Info: Ext 4.3L rwd
Postby Astro88 [OP] » May 17th 2010, 10:00pm
I have bought a "new" engine, because the engine in my car is broken.
Before installing the new engin I thought it might be smart to change the head gasket so I dont have to do it in 6 months.
I guess the head gaskets on my engine is ok, but would not you change it now as the engine is out of the car?
I guess the head gaskets on this engine is fairly old.
Astro88
Postby chevy57bert » May 17th 2010, 10:13pm
Astro88 wrote:I have bought a "new" engine, because the engine in my car is broken.
Didn`t know that.. Your the Man Torje. better to do now...
did you get in contact with Ice_driver??
chevy57bert
Section Moderator
Section Moderator
Topics: 68
Images: 68
Year: 1992
Postby Astro88 [OP] » May 17th 2010, 11:28pm
Ok. didn`t contact him, but got his e-mail
Astro88
Postby tedanderson » May 18th 2010, 2:12am
From my own experience, I would suggest that you get a breaker bar in addition to a torque wrench. Secondly get some new sockets and make sure that they are the 12-point type. If you cant afford a new set, at least get the exact size for the head bolts and intake manifold bolts. On most projects, if you have a metric bolt, you can usually get away with the standard equivalent and vice versa. However, the head bolts and intake bolts will not be as forgiving. It's been a while since I've done this type of job so I couldn't tell you the exact bolt size but take the extra time to make sure that the socket fits snugly and there isn't any wiggle room. And be sure to buy only Craftsman, Snap-On, or any other high-quality equivalent. The $5.99 socket set from your favorite discount store will leave you with plenty of heart-ache. Third, use SLOW and STEADY movement when breaking the bolts loose. Don't yank, jerk, or shove the breaker bar. Take your time with breaking the bolts loose. Lastly get a big piece of cardboard. A pizza box works well for this- When you start pulling out bolts and rods, poke holes in the cardboard in relation to where the parts go on the engine and then stick your rods and bolts into the holes and use a magic marker to make notes on the cardboard if needed. e.g. "This is the special screw that goes behind the throttle body..don't lose it"
But I would have to agree with what was said about it being out of the van- The job can't get any easier than that.. unless you put it on an engine stand. Then you won't have to bend over while you work.
tedanderson
Firing on 8 Cylinders (L3)
Years of Membership: tedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full years
Topics: 74
Alias (AKA): 2Big4aMiniVan
It is currently March 24th 2017, 6:54pm
cybrvanr
Date: Mar 21 '17
Time: 4:55pm
Comments: 23
Date: Mar 17 '17
Time: 1:28pm
Comments: 23
Date: Mar 16 '17
Time: 4:38pm
dweseen
Date: Mar 16 '17
Time: 2:08am
Jawon
Comments: 17
Date: Mar 09 '17
Time: 8:43pm
