testing sensors
811 views 2 replies 3 participants last post by  Astroplane
#1 ·
How do I test the map sensor and iac valve? My van chugs when its cold sometimes and hesitates occasionally. Also where is the location of these? Thanks
#3 ·
On an '04, start with a scan for codes, data, and misfire history. You can also check the throttle plate for buildup where it seats in the bore. Search Technical Info for the online manual link for component locations.
