Need vacuum diagram/help for 2001
Postby jal [OP] » May 29th 2010, 3:11am
I am replacing some of the vacuum lines on my 2001 Astro since one was broken. While removing that one, another one broke, and I discovered a third one which was not attached anywhere. I don't know where this mystery hose should be connected. I looked around and could not find a diagram under the hood. I have a Haynes manual and it does not show a diagram.
I'll try to describe the mystery hose. First of all, there's a line that starts at the left valve cover, and is about 2' long and ends up at a T connection with a check valve in it. This connection is on the passenger side of the engine compartment and can easily be seen/reached from the front/top. The check valve is between this 2' hose and two other hoses, one short, and one long. The long hose was not connected to anything.
Thanks for the help.
jal
Years of Membership: jal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full years
Images: 3
  • Vacuum leak
    by M_a_t_t » November 29th 2016, 7:05pm in Engines
    Last post by M_a_t_t View the latest post
    November 30th 2016, 8:00pm
  • Vacuum issue
    by dyamia » September 11th 2016, 1:37am in Engines
    Last post by dyamia View the latest post
    September 13th 2016, 12:16am
    February 27th 2017, 4:46pm
Re: Need vacuum diagram/help for 2001
Postby Jasen » May 29th 2010, 4:43am
Try autozones help center online. They may have they diagram you need.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Postby astroturf » May 29th 2010, 4:51am
Are all hoses connected to the vacuum ball? It's about in the area you describe. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby astroturf » May 29th 2010, 5:07am
jal, Have a look at this. It is for a 99, but it may get you closer. Jim
astroturf
Topics: 112
Postby unrreal » May 29th 2010, 8:41pm
unrreal
Years of Membership: unrreal has been a member for 7 full yearsunrreal has been a member for 7 full yearsunrreal has been a member for 7 full yearsunrreal has been a member for 7 full yearsunrreal has been a member for 7 full yearsunrreal has been a member for 7 full yearsunrreal has been a member for 7 full years
Topics: 22
Images: 12
Year: 1999
Extra Info: 4.3L LS AWD
Postby castle_Rock » May 29th 2010, 8:48pm
unrreal wrote:here you go hope it helps: http://gsi.xw.gm.com/image_en_us/gif/00 ... 280403.gif
Nice find.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Years of Membership: castle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full years
Topics: 35
Postby jal [OP] » May 30th 2010, 12:02am
Nice find.
Yes, nice! Once I got the cowl off I could see the "ball" thingy, so I plugged it in there. Thanks for the help!
jal
Images: 3
Postby chevy57bert » May 30th 2010, 12:07am
Good Job..
plug in here : Image
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Topics: 67
Images: 52
Alias (AKA): Bertjuh
Year: 1992
Extra Info: Ext 4.3L rwd
Postby jal [OP] » May 30th 2010, 4:46am
Yup, that was it!
jal
Images: 3
It is currently February 27th 2017, 4:46pm
MmusicmanMmusicman is online!
Comments: 89
Date: 51 minutes ago
Time: 3:54pm
AstroNuts
Comments: 89
Date: Feb 24 '17
Time: 4:56am
AstroNuts
Comments: 89
Date: Feb 23 '17
Time: 5:19am
sixsixsixsix is online!
Comments: 22
Date: Feb 22 '17
Time: 4:37am
Attached by: 97cargocrawler
97cargocrawler
Comments: 89
Date: Feb 21 '17
Time: 6:29pm
