No Vacuum @ PCV Valve
Postby castle_Rock [OP] » July 5th 2010, 2:16am
Alright, I checked the PCV valve & found no vacuum when the engine was idling at normal temp when I placed my hand over the valve. What hoses in particular should I check for to see if their plugged up. Anything else needs to be checked as well?
I also shook the PCV valve as well, & heard it rattle, which is a good thing.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Years of Membership: castle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full years
Topics: 35
  • Vacuum leak
    by M_a_t_t » November 29th 2016, 7:05pm in Engines
    Last post by M_a_t_t View the latest post
    November 30th 2016, 8:00pm
  • Vacuum issue
    by dyamia » September 11th 2016, 1:37am in Engines
    Last post by dyamia View the latest post
    September 13th 2016, 12:16am
    February 26th 2017, 1:56am
Re: No Vacuum @ PCV Valve
Postby Mr_Bowtie » July 5th 2010, 4:42am
PCV isn't open that much at idle. Its open more when its under load. Did you take that line off the PCV and check for vacuum?
Good read on the PCV valve:
http://www.aa1car.com/library/pcv.htm
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
Postby 979roadrunner » July 5th 2010, 4:49am
Don't know how common it is on an Astro, But pre 94 Caprices with 5.7L V8s (police interceptors) would sometimes get carbon build up in the PCV passage in the throttle body. Just a thought.
I'm not old, I'm vintage!
979roadrunner
Years of Membership: 979roadrunner has been a member for 6 full years979roadrunner has been a member for 6 full years979roadrunner has been a member for 6 full years979roadrunner has been a member for 6 full years979roadrunner has been a member for 6 full years979roadrunner has been a member for 6 full years
Alias (AKA): Art, Mr Vintage
Extra Info: 4.3V6 RWD Conver
Postby castle_Rock [OP] » July 5th 2010, 5:27pm
Mr_Bowtie wrote:PCV isn't open that much at idle. Its open more when its under load. Did you take that line off the PCV and check for vacuum?
Thanks for the Link Bowtie - I removed the Valve by the boot as a whole to check for suction, but didn't take the valve itself off to check.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby Astroplane » July 6th 2010, 7:26am
castle_Rock wrote:What hoses in particular should I check for to see if their plugged up. Anything else needs to be checked as well?
At idle, there should be enough flow at idle to suck your thumb a little on the intake side of the PCV valve. W or Z engine?
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 7 full yearsAstroplane has been a member for 7 full yearsAstroplane has been a member for 7 full yearsAstroplane has been a member for 7 full yearsAstroplane has been a member for 7 full yearsAstroplane has been a member for 7 full yearsAstroplane has been a member for 7 full years
Extra Info: LT RWD
Postby castle_Rock [OP] » July 7th 2010, 5:30am
Its a Z engine.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby astroturf » July 7th 2010, 6:11am
castle_Rock wrote:Its a Z engine.
Is there vacuum at that port at idle?
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Astroplane » July 7th 2010, 8:32am
If you remove the PCV hose at the TBI, the idle RPM should increase almost to mid-range. If not, and now that we know this is a Z, the port is restricted with carbon buildup.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby castle_Rock [OP] » July 7th 2010, 5:38pm
Astroplane wrote:If you remove the PCV hose at the TBI, the idle RPM should increase almost to mid-range. If not, and now that we know this is a Z, the port is restricted with carbon buildup.
I remember removing the PCV hose from the valve, & it came off the TBI by accident when I first checked it - I don't think the RPM went up once it was disconnected. So it be carbon buildup. Should the hose be disconnected from the TBI while leaving the pcv connected to the valve? Or does it matter?
Thanks
Nick
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby Astroplane » July 8th 2010, 9:22am
It doesn't matter. You have no suction at the PCV valve and there was no vacuum leak when it came off the TBI. Time to remove the TBI unit and clean the vacuum passageways. You will need a TBI base gasket, carb and choke aerosol cleaner, drill bits that match the ports' inner diameter, compressed air if possible, and a new hose for the PCV (if needed). Reinforced fuel hose sold by the foot at the LAPS will not hold up for long to the heat and oil vapor present in the PCV circuit. It will work, but the hose will become hard and brittle.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby castle_Rock [OP] » July 8th 2010, 4:39pm
alright, thanks AstroPlane -
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
It is currently February 26th 2017, 1:56am
AstroNuts
Comments: 73
Date: Feb 24 '17
Time: 4:56am
AstroNuts
Comments: 73
Date: Feb 23 '17
Time: 5:19am
Comments: 22
Date: Feb 22 '17
Time: 4:37am
Attached by: 97cargocrawler
97cargocrawler
Comments: 73
Date: Feb 21 '17
Time: 6:29pm
Attached by: Coaster
CoasterCoaster is online!
Comments: 113
Date: Feb 20 '17
Time: 5:25pm
