How to get at the spark plugs on the driver side?
Postby woodhaven22 [OP] » July 11th 2010, 12:31am
Hello,
I have an 2001 AWD Astro Van 4.3L and having an issue the P0300. Well I went about and started to change my wires and plugs and the passager side went great. Went to do the drivers side and can't figure out how to get at the plugs or wires.
How in the heck do you get at these.
Thanks
woodhaven22
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: woodhaven22 has been a member for 9 full yearswoodhaven22 has been a member for 9 full yearswoodhaven22 has been a member for 9 full yearswoodhaven22 has been a member for 9 full yearswoodhaven22 has been a member for 9 full yearswoodhaven22 has been a member for 9 full yearswoodhaven22 has been a member for 9 full yearswoodhaven22 has been a member for 9 full yearswoodhaven22 has been a member for 9 full years
Topics: 34
Re: How to get at the spark plugs on the driver side?
Postby castle_Rock » July 11th 2010, 12:41am
I find removing the wheel from the vehicle will allow you enough clearance under the Drivers side to get @ the plugs, wires. I get under the drivers side in order to remove those plugs.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Years of Membership: castle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full yearscastle_Rock has been a member for 7 full years
Topics: 35
Postby Mr_Bowtie » July 11th 2010, 12:47am
I remove the wheel & any plastic inner fender stuff I can to get better access. Then a couple nice extensions and a swivel. OH YA make sure you proper support the Van with the tire off....jack stands...SAFETY FIRST! :chevy:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Years of Membership: Mr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full yearsMr_Bowtie has been a member for 8 full years
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
Postby woodhaven22 [OP] » July 11th 2010, 12:58am
Maybe I'm missing something here!
I removed the tire and can only see one spark plug. The other two are closer to the rear and there is no access from the front wheel area.
If I look under the vechical, I only see a pipe in the way?
Thanks for any more help
woodhaven22
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 34
Postby Gary » July 11th 2010, 6:04am
You have the dog house off right??.The driver's side rear plug from the dog house,the middle plug from the wheel well and the front plug from the bottom.Make sure you don't cross thread them and strip the plug hole.I use a rubber hose fitted over the plug to get them started and then ratchet them from there.
Gary
Firing on 4 Cylinders (L3)
Years of Membership: Gary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full years
Topics: 136
Extra Info: high top
Postby woodhaven22 [OP] » July 11th 2010, 1:04pm
Thanks
Found this site with pictures. Didn't know to replace couple of spark plugs would be this hard!
http://********.org/bb2/viewtopi ... h&start=15
woodhaven22
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 34
Postby astroturf » July 11th 2010, 2:18pm
woodhaven22 wrote:Thanks
http://********.org/bb2/viewtopic.php?f ... h&start=15
Your link doesn't work...
Have a look here. http://sites.google.com/site/astrosafar ... park-plugs
Hope it helps, Jim
EDIT: This link points to a brilliant work by our own member: ihatemybike...
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Mr_Bowtie » July 11th 2010, 4:11pm
^Good read! :clap:
I found it easiest with my AWD to go from the driver's side wheel well. Got rip some of the plastic stuff out of your way and get creative with the extensions. Like Gary said use a good spark plug socket with the rubber boot inside.
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Postby rev_les » July 11th 2010, 4:58pm
They pretty much covered it, I pull the wheel off too, and use a swivel and extension and git 'er from the gap over the a-arm. I've done it with the wheel on and just jacked up so the suspension's dropped all the way, and put a cover on the tire to keep road grime off me as much as possible, but heck, once yer there, just pull the 5 lugnuts, and use a panel popper and remove the retaining plugs to get the liner outta the way...once you've done it a couple of times, it's easy...the driver's rear plug is the hardest, if you do it first, the rest of the job's a snap :)
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby woodhaven22 [OP] » July 11th 2010, 5:15pm
Same link as I tried to post, sure cleared up how to get at these. At the end, It wasn't that bad to do! took me about 2 hours on the drivers side taking it very slow.
Thanks for the support - Astro is now happy!!
woodhaven22
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 34
Postby astroturf » July 11th 2010, 5:24pm
woodhaven22 wrote:Same link as I tried to post, sure cleared up how to get at these. At the end, It wasn't that bad to do! took me about 2 hours on the drivers side taking it very slow.
Great to hear WoodHaven
astroturf
Topics: 112
Postby Mr_Bowtie » July 11th 2010, 7:56pm
Awesome! :clap:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Postby castle_Rock » July 11th 2010, 8:22pm
sweet!
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby alexalexanders » July 12th 2010, 1:31am
Before i found this site or any for that matter. I changed my current astro and old astro plugs and wire thourgh the doghouse! Wish i would have found the site first, now im not dreading it that much any more!
2000 GMC Safari SLE
alexalexanders
Firing on 8 Cylinders (L1)
Years of Membership: alexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full years
Topics: 80
Extra Info: SLE 4.3 Vortec
Postby LWright » July 28th 2010, 8:55pm
I found it easier to remove the 3 left side body to frame bolts and jack up the body a few inches, along with removing the wheel and shield.
LWright
Years of Membership: LWright has been a member for 6 full yearsLWright has been a member for 6 full yearsLWright has been a member for 6 full yearsLWright has been a member for 6 full yearsLWright has been a member for 6 full yearsLWright has been a member for 6 full years
Extra Info: 4.3
Postby RECox286 » July 28th 2010, 9:25pm
The front and middle plug are easily accessable from the wheel well. Get a 2 ft or longer extension, a flex spark plug socket and a ratchet with a longer handle than is standard, also helps to have a swiveling handle ratchet. Easiest way to get the rear plug is to go under the truck, and reach up to the manifold, remove the plug wire end, and use just the flex socket and ratchet. As mentioned, the old mechanic's trick of using a 6" piece of 3/8" rubber
hose will make installation go so much easier. One last tip, never try to remove spark plugs from a hot engine. Best to wait for the engine to cool to ambient temperature. Also, while there is more space on the passenger side of the doghouse, the same proceedure will work on the right side plugs.
Don't forget to coat the spark plug boots with dielectric silicone grease. I use it on all the high tension wire ends (distributor, plugs, and coil).
Once you've done a few of what may at first seem to be impossible jobs, and learn some of the tricks, then you will come to the realization that, as most of us here who work on these trucks, the thought that went into getting so much stuff into such a small space, and still have room to work, was a real feat of automotive genius.
Keep truck'n
Bob
RECox286
Topics: 39
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby cowboydan » August 6th 2010, 5:27am
so... what type of plugs did you pull out? what are your new ones?
2006 sebring 2.7 touring: DD
cowboydan
Firing on 8 Cylinders (L2)
Years of Membership: cowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full years
Topics: 67
Alias (AKA): cbd
Year: 1997
Extra Info: 4.3w CL AWD
Postby oldtymehockey » January 14th 2011, 7:12pm
Hey all, I am reviving this thread as it is the only one I have found so far in my one day tenure here with instructions and tips on spark plug replacement.
I have questions about the left side. Can you share any tricks to getting the spark plug wires off and back on? I am not seeing how I may get a grip on number 3 and 5. I think a long screwdriver, long needle nose, or pick would pull the wire off but I think getting the new one set back in there would be a challenge.
The plugs don't seem as difficult as I have plenty of extensions and u-joints to get a socked in on the plug.
PM if easier. Pics might help too.
1998 Astro AWD close to 300k
oldtymehockey
Years of Membership: oldtymehockey has been a member for 6 full yearsoldtymehockey has been a member for 6 full yearsoldtymehockey has been a member for 6 full yearsoldtymehockey has been a member for 6 full yearsoldtymehockey has been a member for 6 full yearsoldtymehockey has been a member for 6 full years
Alias (AKA): Ekim
Extra Info: AWD BASE
Postby RECox286 » January 14th 2011, 8:12pm
Hey Hockey,
There are pliers made specifically to remove the boot from the spark plug, however, there is barely enough room as it is to work from the wheel well, or even from the underneath of the truck. I find that a long flat blade screw driver, positioned to push the boot from the engine side, and worked carefully does as good a job as anything else I have tried.
If you come up with anything better, let us know.
Good luck
Bob
RECox286
Topics: 39
Year: 1993
Postby oldtymehockey » January 14th 2011, 9:52pm
Thanks Bob; and thank you for your service to our great country.
oldtymehockey
Alias (AKA): Ekim
It is currently April 28th 2017, 11:09am
Attached by: nonhog
nonhog
Time: 5:32pm
nubetoob
Comments: 19
Date: Apr 26 '17
Time: 7:09pm
Attached by: chevymaher
Date: Apr 25 '17
Time: 2:34am
Jakstro
Date: Apr 17 '17
Time: 5:42am
Attached by: nonhog
nonhog
Date: Apr 14 '17
Time: 11:06pm
cron
