1999 Astro Van - How to do a tune up?
Postby runrunrun [OP] » July 27th 2010, 3:56am
Any write ups?
I changed the oil, but i figuere it's time for a tune up.
On the front of the engine theres a sticker that reads timing is adjusted by the computer do not adjust timing.
So are there any write ups?
Can i get a parts list going?
I've done tune ups for older cars and such, but never for a van. It seems pretty starught forward... Plugs, wires, distibuter...
Well does my 1999 use a distributer or a coil pack??
thanks folks...
runrunrun
Years of Membership: runrunrun has been a member for 4 full yearsrunrunrun has been a member for 4 full yearsrunrunrun has been a member for 4 full yearsrunrunrun has been a member for 4 full years
Alias (AKA): George
  • 1997 Astro SDM to 1999 Astro??
    by CreepiE » April 6th 2013, 4:06am in Engines
    Last post by chevymaherchevymaher is online! View the latest post
    April 11th 2013, 1:47am
  • Tune up
    by onelowstro » November 25th 2012, 3:27am in Engines
    Last post by onelowstro View the latest post
    November 25th 2012, 7:19pm
    43
    May 19th 2013, 9:42pm
Re: 1999 Astro Van - How to do a tune up?
Postby Astroplane » July 27th 2010, 7:40am
Search the site. It will provide a wealth of info. AC-Delco plugs, cap, and rotor. Wires can be Delco, Delphi, or high end performance brand. Replace the air filter and clean the MAF. Inspect/replace the PCV. Check all vacuum lines. Change the fuel filter. Inspect/Clean the throttle plate and bore.
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 3 full yearsAstroplane has been a member for 3 full yearsAstroplane has been a member for 3 full years
Extra Info: LT RWD
Postby LEVE » July 27th 2010, 1:12pm
From the Chilton's manual, you've got a Distributor.
Yes, that is correct, the timing is fixed and controlled by the ECU.
Go to here to Veiw/Download 1999 Astro Owner's Manual and, it will tell you the maintenance interval.
This May help, consult the Owner's Manual for Specs...
  • Oil filter - AC/PF52
  • Air filter - AC/A1163C, 25098463, WIX 46117, Puro A2473, Fram CA7421
  • Fuel filter - AC/GF652, 2517179,2 WIX 33481
  • Differential Oil - Mobil 1 75W90
  • Transfer Case Oil - AutoTrak II, GM 12378508
  • Power Steering Fluid - GM 1050017 (Spec No. 9985010)
  • Spark plugs - AC 41-932 - P/N 25321614
  • Spark Plug Wires - 88984265, AC 746KK, Standard 7673
  • Distributor Cap - 10452485, AC D328A, Standard DR475
  • Distributor Rotor - 10452457, AC D465, Standard DR331
  • Acc. Belt - GM012555016, Dayco 6PK2425
  • PCV valve - AC CV769C, 06487532
LEVE
Years of Membership: LEVE has been a member for 3 full yearsLEVE has been a member for 3 full yearsLEVE has been a member for 3 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby rev_les » July 27th 2010, 11:27pm
They pretty much have it covered. I'd also run some Lucas fuel injector cleaner through it, or a bottle of Techron injector cleaner. As for the vacuum lines, look especially careful at the long one that goes from the tree close to the MAP sensor, to the vacuum ball and A/C blend door (Basically from the driver side, top mid engine, to the passenger side firewall under the hood) That line likes to get brittle and break. DON'T use a cheapie cap and rotor, they'll leave you stranded in the near future. I had a BWD rotor glaze up in less than 3000 miles, and leave my wife stranded on the highway,I was less than amused at the $100 dollar tow bill, and the headache (you don't normally suspect new parts of failing) of finding out a 5 dollar part failed.
Don't forget to de-pressurize the fuel line before you unscrew the fittings on the fuel filter.( pull the fuel pump relay and start it, or better yet, use a fuel pressure gauge with a bleed-off button). There's plenty of info about changing spark plugs on here, to sum it up, use a wobbler and I recommend taking the front tires OFF, though you can just jack it up and securely support it on stands and work over the top of them. It's a good time to check the brakes and lube the ball joints,idler arms, etc, anyway!
NRA Lifetime Member
2'nd amendment supporter
'99 Astro, 296K 4.3 "W" 3.73's RIP
91 Sable wgn, 43K
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 4 full yearsrev_les has been a member for 4 full yearsrev_les has been a member for 4 full yearsrev_les has been a member for 4 full years
Topics: 37
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby runrunrun [OP] » July 28th 2010, 6:06am
Geez you dudes are awesome.
Thanks!!
runrunrun
Alias (AKA): George
It is currently May 19th 2013, 9:42pm
Attached by: aztec1987
aztec1987
Date: Today
Time: 2:44am
aztec1987
Date: Today
Time: 12:03am
aztec1987
Date: May 17 '13
Time: 5:45am
Attached by: chevymaher
Date: May 17 '13
Time: 5:22am
Date: May 16 '13
Time: 11:39pm
Users browsing this forum: Baiduspider [Spider], Bing [Bot] and 14 guests
