Radiator drain access
Postby Donnymo [OP] » August 22nd 2010, 7:56pm
How do you get to the drain plug on an AWD 2003 Safari? I'm assuming it's on the passanger side below the lower radiator hose. I just don't see how you get to it. Thanks,
Donnymo
Years of Membership: Donnymo has been a member for 6 full yearsDonnymo has been a member for 6 full yearsDonnymo has been a member for 6 full yearsDonnymo has been a member for 6 full yearsDonnymo has been a member for 6 full yearsDonnymo has been a member for 6 full years
Year: 2003
  • Oil drain plug gasket
    by ryguy » February 12th 2017, 12:14am in Engines
    February 13th 2017, 2:25am
  • Radiator Hose Size
    by 1lowcab » February 22nd 2017, 12:16am in Engines
    Last post by 1lowcab View the latest post
    February 22nd 2017, 1:19am
    9
    13
    March 28th 2017, 9:08am
Re: Radiator drain access
Postby Big_kid » August 22nd 2010, 9:50pm
I don't remember exactly where it is, but it's near the lower hose somewhere, IIRC it's facing the engine.
I flushed mine out almost 2 years ago. I try to block that memory out because I did it in the grass, at night, in November, a freeze was coming that night, and I had been running straight water. I remember being cold, wet, and wishing it were July.
Welcome aboard, BTW.
:chevy:
Firing on 6 Cylinders (L5)
Topics: 138
Images: 67
Extra Info: 2WD conversion
Postby ihatemybike » August 23rd 2010, 2:23am
On AWD vans it's a pain to see and reach from underneath. I've found it easier to pull the fan and shroud and reach it from above. I usually will shove a bit of 3/8" hose on the drain tube before I start too.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Years of Membership: ihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full years
Topics: 67
Postby astroturf » August 23rd 2010, 1:24pm
On my 05 the drain is located on the lower radiator hose.
Simply disconnect the lower hose, and wa lah a drain...
Jim
PS My 05 has no drain on the radiator.
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby ihatemybike » August 23rd 2010, 7:26pm
astroturf wrote:PS My 05 has no drain on the radiator.
I challenge this statement as the radiators have the same part number 1996-2005 AWD/RWD.
ACDELCO Part # 21331
Thus the fact that my two vans each have one means your van has one as well.
Aaron
ihatemybike
Topics: 67
Postby astroturf » August 23rd 2010, 9:00pm
Lead On Brother, and I will go snap a pic of where it is not.
Jim
PS I have also been looking for a PCV Valve & EGR Valve too.
astroturf
Topics: 112
Postby ihatemybike » August 23rd 2010, 9:15pm
Gonna have to pull the radiator shroud and fan. Be hard to get a good pics from underneath, although on 2WD vans it is barely visible.
For the others take a pic of the driver's side valve cover and then the area to the drivers side of the T-stat.
Aaron
ihatemybike
Topics: 67
Postby astroturf » August 23rd 2010, 10:09pm
ihatemybike wrote:Gonna have to pull the radiator shroud and fan. Be hard to get a good pics from underneath, although on 2WD vans it is barely visible.
Help Me, Help You...
PCV & EGR are not there. PCV was replaced by a fixed orifice system. And I am still looking for the Where's Waldo EGR on an 05.
Here is a pic of the not there Radiator Drain...
Jim
PS Maybe this one was made on a Friday or a Monday...
astroturf
Topics: 112
Postby 94 Van Guy » August 23rd 2010, 10:17pm
:o
:shrug:
Jim, is that the kind where you use a can opener?
:rofl: :rofl: :rofl: :rofl: :rofl:
'91 Chevy G30 Bus 39.3K Miles
Retired
Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Firing on 5 Cylinders (L3)
Years of Membership: 94 Van Guy has been a member for 7 full years94 Van Guy has been a member for 7 full years94 Van Guy has been a member for 7 full years94 Van Guy has been a member for 7 full years94 Van Guy has been a member for 7 full years94 Van Guy has been a member for 7 full years94 Van Guy has been a member for 7 full years
Topics: 71
Images: 44
Alias (AKA): Keith
Year: 1991
Extra Info: G30 Bus
Postby rev_les » August 23rd 2010, 10:31pm
Drain or not, it's easier to just pull that lower hose. Getting the drain opened and re-tightened is a royal PITA. Jim, I looked up your EGR valve part number...... you seem to have an EGR gasket, but no EGR valve :mrgreen: The '02 through '05's are VIN "X", they use some newfangled control systems.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby astroturf » August 23rd 2010, 10:34pm
Keith, Just another leak point.
Rev, It is Fangled Alright.
astroturf
Topics: 112
Postby ihatemybike » August 24th 2010, 3:17am
Jim, your van is goofy, I don't like it. :snooty:
Aaron
ihatemybike
Topics: 67
Postby rev_les » August 24th 2010, 4:49am
ihatemybike wrote:Jim, your van is goofy, I don't like it. :snooty:
I'm kinda jealous of the rear wheel discs myself :whistle:
NRA Lifetime Member
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 39
Alias (AKA): Les
Postby Donnymo [OP] » August 29th 2010, 1:44pm
I removed the fan shroud and I have the same radiator. It is the same part number and a new radiator at O'reiliy's had a drain plug. Starnge but true. Thanks for the help guys.
Donnymo
Year: 2003
It is currently March 28th 2017, 9:08am
cybrvanr
Date: Mar 21 '17
Time: 4:55pm
Comments: 23
Date: Mar 17 '17
Time: 1:28pm
Comments: 23
Date: Mar 16 '17
Time: 4:38pm
dweseen
Date: Mar 16 '17
Time: 2:08am
Jawon
Date: Mar 09 '17
Time: 8:43pm
