Trouble Code 45 Rich Exhaust
Postby Kirkus [OP] » November 7th 2010, 12:11am
Hi everyone,
For the past few years, I've been getting a Rich Exhaust trouble code every now and then. The service engine light came on again last night on the drive home and sure enough, it was Code 45. Here are a few symptoms:
1. Rough Idle
2. 12-15 MPG City
3. Noticeable Exhaust smell
4. Inside of the tailpipe is pretty black
5. Lack of power
I've looked all over the forum for possible solutions but I haven't found anything. Any suggestions would be great! Thanks!!!!
Jerome The Bus is his name and taking care of Kirkus is his game. :layrubber: 1992 GMC Safari XT 4.3L 262 RWD At least 245,000 Mi Orig eng and tranny
Kirkus
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: Kirkus has been a member for 7 full yearsKirkus has been a member for 7 full yearsKirkus has been a member for 7 full yearsKirkus has been a member for 7 full yearsKirkus has been a member for 7 full yearsKirkus has been a member for 7 full yearsKirkus has been a member for 7 full years
Alias (AKA): Kirk
Extra Info: 262 Z
  • Rough idle and trouble code 12
    by PalIstvan » April 22nd 2017, 11:38am in Engines
    April 22nd 2017, 4:04pm
  • Motor mount trouble
    by ezbeinsteezy » February 14th 2017, 9:30am in Engines
    February 22nd 2017, 7:22pm
    14
    June 25th 2017, 6:25am
Re: Trouble Code 45 Rich Exhaust
Postby astroturf » November 7th 2010, 3:27am
Vacuum Leaks?
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Kirkus [OP] » November 7th 2010, 4:47am
I'm thinking I might have a few vacuum leaks. I'm away at school right now so I won't be able to dig into it and see. I'm hoping once I go on thanksgiving break, I'll change some stuff. I actually planned on it. Would anyone know where I could find a vacuum diagram? I think there was a factory add-on vacuum pump. I took it off because it stopped working. I can't recall but I think it started running rough after I took the pump off...
Thanks for the suggestions!
Kirkus
Fueling (5/8 tank)
Fueling (5/8 tank)
Alias (AKA): Kirk
Extra Info: 262 Z
Postby Phantom » November 7th 2010, 5:47am
Years ago when I had a car that I removed the A.I.R pump off of it needed the vacuum lines routed slightly different because the pump was no longer there , after setting the timing it ran great , but it was necessary to adjust the timing , might as well replace all the vacuum lines and get a couple caps to plug off a port or two, when you remove things you have to make adjustments to compensate for it . The pump was an emissions thing that I did not need ,as I do not live in Cali. and it caused a parasitic power loss due to that it needed belt power to drive it .
Phantom
Firing on 7 Cylinders (L4)
Postby Kirkus [OP] » November 7th 2010, 6:21am
Phantom,
This wasn't the actual AIR pump. Honestly, I don't even think I have an AIR pump on the engine… The pump I'm talking about was completely electrical. The dealership mounted it on the crossmember below the crank pulley and behind the fan shroud. It had two lines coming off I'm guessing input and output.
Kirkus
Fueling (5/8 tank)
Fueling (5/8 tank)
Alias (AKA): Kirk
Extra Info: 262 Z
Postby Phantom » November 7th 2010, 1:53pm
Here is a diagram , what was the pump for? I took a air pump off Olds Custom Cruiser wagon and used it as an air compressor , 12 volt , think it had like 100 psi pressure ,good for pumping up tires ,etc. it was for the automatic leveling system
89 to 94 vacuum diagram.jpg (53.98 KiB) Viewed 1800 times
Phantom
Postby Kirkus [OP] » November 7th 2010, 6:35pm
Thanks Phantom!
Well, I was going through the old repair records and it looks like the engine had some kind of issue with vacuum pressure in the past. It kept throwing up the SES codes for either 44 or 45 I believe. To solve this issue, the dealership added two vacuum pumps. One is mounted on my firewall w/ in line with the vehicle wiring harness and the other was mounted on that crossmember that I was talking about earlier. Judging from the repair history something might have been faulty from assembly and the dealership just did this to cover their behinds until the warranty ran out... I was lucky that I knew the two previous owners of the van before I purchased it and they were organized enough to keep a folder of every single thing that they did to the van. Receipts and all! When I get home for Thanksgiving, I'm going to look at that service order again to see exactly what was going on when the pump was added. I'm pretty sure with the combination of the pump being added back on, and a vacuum tuneup, Jerome might be running like new again! We shall see though!
Additionally, I know this pump was nothing like an air compressor. I doubt this thing could put out 100 psi! lol
Kirkus
Fueling (5/8 tank)
Fueling (5/8 tank)
Alias (AKA): Kirk
Extra Info: 262 Z
Postby Zebediah III » November 8th 2010, 3:25am
The stealership added two vacuum pumps because the engine wouldn't produce enough vacuum?
Wow!
Zebediah III
Years of Membership: Zebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full years
Extra Info: 383 Crate Motor
Postby rev_les » November 8th 2010, 6:44am
Kinda like tossing a rug over the grand canyon........
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby Kirkus [OP] » November 8th 2010, 8:32am
Yeah I did a little research and found that one is for the a/c. The other, I wasn't able to find... The dealership is truly a mess!
Kirkus
Fueling (5/8 tank)
Fueling (5/8 tank)
Alias (AKA): Kirk
Extra Info: 262 Z
It is currently June 25th 2017, 6:25am
Rookie162
Date: Jun 13 '17
Time: 11:28pm
astrometalvan
Date: Jun 10 '17
Time: 5:10pm
Attached by: xit
xit
Date: Jun 07 '17
Time: 3:17pm
Attached by: Astro Pop
Astro Pop
Date: Jun 06 '17
Time: 6:17am
astrometalvan
Date: Jun 06 '17
Time: 1:14am
