Where is the "SET TIMING CONNECTOR" located?
Postby zach914v8zach914v8 is online! [OP] » November 30th 2010, 4:58am
I don't have a sticker under my hood. I have a 1994 astro van. I need to find this connector please help! BTW should I set the base to 0* or something else?
Thanks
Zach
My Rides:
1974 Porsche 914 powered by a 305 Chevy v8.
1994 GMC Safari TBI 4.3, Lifted 4"
Years of Membership: zach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full yearszach914v8 has been a member for 7 full years
Topics: 12
Alias (AKA): ballzach
Extra Info: 4 inch lift
  • TWO Crank Pulley Timing Marks
    by sixsix » February 12th 2017, 9:59pm in Engines
    February 22nd 2017, 11:18pm
    81
    March 26th 2017, 2:00pm
Re: Where is the "SET TIMING CONNECTOR" located?
Postby fast68 » November 30th 2010, 5:37am
if there is a knock module anywhere then unplug that to set the timing
if not then look for single inline wire connector tan color wire somewhere near ECM or near ALDL connector or such
set to zero with disconnected
fast68
Years of Membership: fast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full years
Topics: 12
Alias (AKA): fast
Extra Info: 4.3L Z EXT RWD
Postby chevymaher » November 30th 2010, 1:53pm
My van is set at 18 degrees advance. and it runs a lot better than it did stock.If I retarded it just two degrees it stalled and would not restart. I did that just to see where it stood on timing.Not sure what the powers to be were thinking when they set them that way but you get better milage and power if it set for power. and my knock sensor is hooked up and it is not fighting it at that point.Iam racing mustangs and winning 90 percent of the time.Before I did the timing it was alot slower.I have 410 rr end that part of it but timing more of it.
Topics: 82
Year: 1994
Postby zach914v8zach914v8 is online! [OP] » November 30th 2010, 5:44pm
Still lost guys, I can't find it.
My Rides:
Topics: 12
Postby mkj54 » November 30th 2010, 6:04pm
http://www.aldlcable.com/
Go here, there's a good picture if you scroll down past the cables. The connector is located inside almost directly below the steering wheel, at about knee level.
What you do is short pins A and B together with the engine warmed-up and running. (A paper clip works good) Your check engine lite shoud flash once per second. Now it is at base timing and ready to be set. Set it at 0. Then remove the clip and the ECM will take over the timing. You may have to shut it off to get the check engine lite to go out.
mkj54
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: mkj54 has been a member for 6 full yearsmkj54 has been a member for 6 full yearsmkj54 has been a member for 6 full yearsmkj54 has been a member for 6 full yearsmkj54 has been a member for 6 full yearsmkj54 has been a member for 6 full years
Postby jeff's93astro » November 30th 2010, 6:39pm
Disconnect this, set timing, connect back. And I believe its tan with a white stripe Its just been awhile since i messed with it.
88 Silverado 5.7L RWD 284,000 miles (going 383 soon)
93 Astro CS 4.3L RWD 230,000 miles (89 Astro 4.3)
jeff's93astro
Firing on 1 Cylinder (L2)
Years of Membership: jeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full years
Topics: 53
Extra Info: CS 4.3L V6 RWD
Postby zach914v8zach914v8 is online! [OP] » November 30th 2010, 9:08pm
I found it!
My Rides:
Topics: 12
Postby zach914v8zach914v8 is online! [OP] » November 30th 2010, 9:09pm
Thanks for all your help guys!!!
My Rides:
Topics: 12
Postby limrick » September 13th 2015, 4:44am
Zach, I've got a 94 and I can't find it on the passenger side near the heater, or ..... it's well hidden.
Where did you find it ?
limrick
Years of Membership: limrick has been a member for 9 full yearslimrick has been a member for 9 full yearslimrick has been a member for 9 full yearslimrick has been a member for 9 full yearslimrick has been a member for 9 full yearslimrick has been a member for 9 full yearslimrick has been a member for 9 full yearslimrick has been a member for 9 full yearslimrick has been a member for 9 full years
Topics: 7
Postby 97cargocrawler » September 13th 2015, 10:02am
It's right in front of the ballzach. Look straight down.
97cargocrawler
Orange Status (L5)
Orange Status (L5)
Years of Membership: 97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years
Topics: 42
Alias (AKA): CC, CARGO, CRAWLER, ASSHOLE
Year: 1997
Postby markmitch » September 13th 2015, 3:16pm
on my 89 it is right by the distributor
Firing on 2 Cylinders (L4)
Years of Membership: markmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full yearsmarkmitch has been a member for 9 full years
Topics: 433
Images: 5
Alias (AKA): Mitch
Year: 1989
Extra Info: RS 350 TBI
Postby limrick » September 13th 2015, 6:00pm
Next to the distributor ....... right where the emissions sticker said it would be
Thanks for the info.
limrick
Topics: 7
Postby limrick » September 13th 2015, 6:38pm
I've got 2 timing marks on my harmonic balancer, which one do I use for TDC ?
TIA
limrick
Topics: 7
Postby chevymaher » September 13th 2015, 6:49pm
limrick wrote:I've got 2 timing marks on my harmonic balancer, which one do I use for TDC ?
TIA
First mark coming around the horn. Second one is for cylinder 3.
Topics: 82
Year: 1994
Postby sixsix » September 15th 2015, 3:01am
5 Year old post - Brought back to life...
Mike
The Van's Build: viewtopic.php?f=127&t=59385
There are 3 types of people in this world - First, the type that can count
and Second, the type that can't.
Firing on 6 Cylinders (L2)
Years of Membership: sixsix has been a member for 2 full yearssixsix has been a member for 2 full years
Topics: 21
Images: 874
Year: 1992
Extra Info: LT W-CPI Motor 200K
Postby Lumpy » September 15th 2015, 3:48am
I think that means that you have to increase the timing the same amount as the earth's magnetic declination change over that same 5 yrs.
I think.
Year: 1989
Postby AstroWill » September 15th 2015, 10:34pm
Better than a new post with the same info.
Topics: 60
Images: 87
Alias (AKA): Richard C., Advocatus Diaboli
Year: 2003
Extra Info: 90TigerGTv8 03AWD
Postby Lumpy » September 16th 2015, 3:33am
AstroWill wrote:Better than a new post with the same info.
I agree. I like to see old threads re-visited. That tends to keep the answers centralized in one place. 5 threads with 5 people's results is kind of difficult to weed through, compared to if it were in one place.
It's not easy to search this forum, at least not from the internal search function. "Hey what ever happened to your failing gerflumsich rundinator?" Is something I'm often wondering.
Year: 1989
It is currently March 26th 2017, 2:00pm
cybrvanr
Date: Mar 21 '17
Time: 4:55pm
Comments: 23
Date: Mar 17 '17
Time: 1:28pm
Comments: 23
Date: Mar 16 '17
Time: 4:38pm
dweseen
Date: Mar 16 '17
Time: 2:08am
Jawon
Date: Mar 09 '17
Time: 8:43pm
Users browsing this forum: Bing [Bot] and 6 guests
