Hesitation at Idle + Low RPM
Postby PHANTOMII [OP] » June 1st 2016, 1:19am
Hi! Joined today! My 2001 Astro AWD has developed hesitation at idle + low RPM since I removed the 2 plastic side pieces that snap into the air filter box. I took them off to allow more air to flow easier to the air filter. Seems like the engine doesn't like not having to suck hard. I didn't do any other changes to anything and now I have this hesitation. Thanks in advance for HELP!
PHANTOMII
Year: 2001
  • Low idle 550 rpm
    by ezbeinsteezy » January 10th 2017, 5:36pm in Engines
    January 14th 2017, 2:41pm
  • engine looses high RPM power
    by mattds » March 22nd 2017, 9:17pm in Engines
    Last post by Bat View the latest post
    April 18th 2017, 7:16am
    9
    79
    May 23rd 2017, 9:50pm
Re: Hesitation at Idle + Low RPM
Postby RVMAN » June 2nd 2016, 12:04pm
Ďid you unplug the MAF while doing this "procedure" and maybe forgot to plug it back in?
Not sure what you removed or why, the engine will not notice any difference.
Got a picture of what you did?
RVMAN
Years of Membership: RVMAN has been a member for 1 full year
Alias (AKA): Ray
Year: 2000
Postby timothy47130 » June 2nd 2016, 12:05pm
Check and make sure the clamps on the air snorkel between the mass airflow sensor and throttle body are tight and that there are no cracks or leaks in the rubber. Also try cleaning the maf sensor with maf sensor cleaner.
Tim
1998 chevy astro mark III conversion with 125,000 miles
all stock besides-
dual exhaust
rear lifted 1" more than stock with s-10 leafs
10,000 lb capacity transmission cooler
corvette 2nd gear servo
Trans-go SK4L60E shift kit
timothy47130
Years of Membership: timothy47130 has been a member for 2 full yearstimothy47130 has been a member for 2 full years
Topics: 38
Images: 7
Alias (AKA): Tim
Year: 1998
Extra Info: mark III conversion
Postby Leeann_93Leeann_93 is online! » June 2nd 2016, 10:50pm
Removing those side pieces makes warmer air enter the air filter box. The pieces scoop cool air directly from behind the grille - moving forward forces the air in.
They really were designed with purpose.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby swharris » June 10th 2016, 10:34pm
^^^^THIS^^^^
swharris
Years of Membership: swharris has been a member for 7 full yearsswharris has been a member for 7 full yearsswharris has been a member for 7 full yearsswharris has been a member for 7 full yearsswharris has been a member for 7 full yearsswharris has been a member for 7 full yearsswharris has been a member for 7 full years
Topics: 81
Images: 4
Alias (AKA): S4
Extra Info: 4.3 Vortec 2wd
Postby WimpazzWimpazz is online! » June 17th 2016, 2:10am
x3!
2000 AWD Safari "TK421"; (Build Here):http://www.astrosafari.com/viewtopic.php?f=127&t=103714
Years of Membership: Wimpazz has been a member for 1 full year
Topics: 25
Images: 74
Alias (AKA): =Wimpy=
Year: 2000
Extra Info: AWD 3+1 Lift
It is currently May 23rd 2017, 9:50pm
Attached by: paulbot
paulbot
Time: 4:30am
alife2
Comments: 22
Date: May 20 '17
Time: 9:13pm
alife2
Comments: 22
Date: May 20 '17
Time: 5:08pm
alife2
Comments: 22
Date: May 18 '17
Time: 7:36pm
alife2
Comments: 22
Date: May 17 '17
Time: 10:15pm
