Is there any harm in just leaving it as-is? (at least for a little while)? I've got so many other expenses right now and this doesn't seem to be a serious issue, in the grand scheme of things. Based on other posts I've read, the price to fix this can vary from cheap hack jobs to expensive hub and sensor replacements. I'm not a mechanic and do not do any work on my vehicles. When replacing parts, I prefer to get them from the stealership, oops I mean dealership, even though they're more expensive. I've rarely found a case where aftermarket parts were better than OEM parts, although it is possible (excluding high performance upgrades). I believe in fixing things the right way, and I'd like to have ABS the way the van was meant to be. I just need to save up a bit, expecially if this will be a few hundred dollars or more.
My van is a 2005 Astro RWD with about 66,000 miles (106,000 kms). Sometimes I use it daily, sometimes once or twice a week, and on rare occasions it may stay parked for 7 to 10 days. I use it mostly in city driving with a bit of highway driving. I've noticed my brakes have started to pulsate a bit, probably due to cheap aftermarket brake rotors. I wonder if this has anything to do with with ABS coming on at low speeds? Both issues came up around the same time. I bought the van used about 6 months ago, and love it. Aside from routine maintenance and new winter tires in January, I haven't put any more money into it. When I fix things, I like it to be done right and with good quality parts. However, I suspect the used car lot that sold me the van may have replaced the front brakes with cheap aftermarket pads and rotors. Again, I'm not a mechanic and won't be pulling off the wheels to do my own brake job. But I just want to know what I might be in for when I take it to the Chevy dealer and if this can wait for a little while. Any suggestions would be greatly appreciated, thanks!
