Redrilled rotors to the 5 x 4 3/4 bolt pattern
Postby ProStreet_LS1 [OP] » March 12th 2012, 5:45pm
Here is a picture of my redrill brake rotors to smaller Chevy bolt pattern. It was on my 85 prostreet Astro.
In the picture it is on my 98 soon to be prostreet. It is not completely installed, just checking fitment, looks good. They look good, even wear and plenty thick, so will use them.
1985 Pro Street Chevy Astro: parted, scrapped & upgraded to
1998 Pro Street Chevy Astro: Tubbed w/ 33x22 rear tires, 350 hp aluminum LS1 V8
PRO STREET 4 LIFE, GEARHEAD 4 LIFE
ProStreet_LS1
Years of Membership: ProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full years
Topics: 54
Year: 1998
Extra Info: LS1 V8 Pro Street
  • New Brake Pads/Rotors
    by Astrodawn » May 8th 2017, 6:31pm in Brakes
    Last post by Astrodawn View the latest post
    Today, 3:32am
  • '05 Astro AWD: Torque Specs for rear pads & rotors
    by Rich G. » December 2nd 2016, 10:02pm in Brakes
    Last post by astrotardis View the latest post
    December 11th 2016, 3:23am
    7
    27
    May 28th 2017, 3:52pm
Re: Redrilled rotors to the 5 x 4 3/4 bolt pattern
Postby tedanderson » March 13th 2012, 12:11am
Nice! :thumbup:
tedanderson
Firing on 8 Cylinders (L3)
Years of Membership: tedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full years
Topics: 74
Alias (AKA): 2Big4aMiniVan
Postby streetnova » March 13th 2012, 5:25am
nice i do it soon More pics it be good nice work
i have skylark 76 spindell same as astro 97
Redrilled rotors to the 5 x 4 3/4 bolt pattern it good ??
streetnova
Years of Membership: streetnova has been a member for 5 full yearsstreetnova has been a member for 5 full yearsstreetnova has been a member for 5 full yearsstreetnova has been a member for 5 full yearsstreetnova has been a member for 5 full years
Images: 18
Alias (AKA): nova
Year: 1997
Extra Info: 4.3l v6
Postby ProStreet_LS1 [OP] » March 13th 2012, 5:28am
You can do the same in the rear, redrill axle plate and brake drum
ProStreet_LS1
Topics: 54
Year: 1998
Postby streetnova » March 13th 2012, 5:43am
yes whit a good Lug Pattern Drill Guide from
Rotten Leonard's Jalopy Shop
is it safe to redrill
streetnova
Images: 18
Alias (AKA): nova
Year: 1997
Extra Info: 4.3l v6
Postby streetnova » March 15th 2012, 12:34am
tpibadassastro wrote:Here is a picture of my redrill brake rotors to smaller Chevy bolt pattern. It was on my 85 prostreet Astro.
could i see from other side of the rotor ???
streetnova
Images: 18
Alias (AKA): nova
Year: 1997
Extra Info: 4.3l v6
Postby astroracer » March 15th 2012, 2:06am
You realize you don't have to re-drill the Astro rotors.... B-body and small bolt pattern B bodies use the same style spindle and bearings. Just pick up a small pattern rotor... The hubs I modified to carry the Corvette rotors on Bad Ast were small pattern Delta 88 rotors. I got them for free as the rotor part was used up and all I needed was the bearing hub.
Mark
2004 Astro
2001 Astro (the wifes)
2000 Monte Carlo SS
2000 Astro Conversion Van
1994 Formula V8 Firebird
1956 Chevy Station Wagon
astroracer
Years of Membership: astroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full years
Alias (AKA): astroracer
Year: 1988
Extra Info: Major renovation
Postby ProStreet_LS1 [OP] » March 15th 2012, 4:01am
There is nothing different on the back of the rotor. It just has holes for studs drilled out for 5 x 5 bolt pattern.
Do what astroracer suggests, it will be a lot easier.
ProStreet_LS1
Topics: 54
Year: 1998
Postby streetnova » March 17th 2012, 2:07am
astroracer wrote:You realize you don't have to re-drill the Astro rotors.... B-body and small bolt pattern B bodies use the same style spindle and bearings. Just pick up a small pattern rotor... The hubs I modified to carry the Corvette rotors on Bad Ast were small pattern Delta 88 rotors. I got them for free as the rotor part was used up and all I needed was the bearing hub.
Mark
very good that a 12 rotor
streetnova
Images: 18
Alias (AKA): nova
Year: 1997
Extra Info: 4.3l v6
Postby streetnova » March 17th 2012, 2:32am
Mark
What rotor i could use whit astro spindell to change bolt pattern 5x 4,75
i think it bether for me to redrill ,i install draglite from weld racing wheel
streetnova
Images: 18
Alias (AKA): nova
Year: 1997
Extra Info: 4.3l v6
Postby streetnova » March 17th 2012, 3:59am
tpibadassastro wrote:There is nothing different on the back of the rotor. It just has holes for studs drilled out for 5 x 5 bolt pattern.
cost more $$$$$ lol
streetnova
Images: 18
Alias (AKA): nova
Year: 1997
Extra Info: 4.3l v6
Return to Brakes
It is currently May 28th 2017, 3:52pm
Brakes Forum
Attached by: Astro Pop
Astro Pop
in Brakes
Comments: 40
Date: May 09 '17
Time: 10:53pm
Attached by: 97cargocrawler
97cargocrawler
in Brakes
Date: Apr 18 '17
Time: 4:36pm
gordo999
in Brakes
Date: Apr 10 '17
Time: 1:03am
petema
in Brakes
Comments: 14
Date: Mar 24 '17
Time: 10:25pm
in Brakes
Comments: 14
Date: Mar 24 '17
Time: 8:34pm
