looking into changing my break calllipers
Postby juakherri [OP] » March 14th 2012, 12:45am
What would I need nd how is go about it? Iv check around for forums but there are none on them..:(
juakherri
Years of Membership: juakherri has been a member for 1 full year
Alias (AKA): juacurly
Year: 1989
Extra Info: manual
Re: looking into changing my break calllipers
Postby paintdrying » March 14th 2012, 1:24am
Caliper should be very easy. Two 3/8 inch allen head bolts. Change the rubber line as well.
paintdrying
Years of Membership: paintdrying has been a member for 2 full yearspaintdrying has been a member for 2 full years
Topics: 94
Extra Info: 108 000
Postby juakherri [OP] » March 14th 2012, 1:42am
Thats what I was thinking just wanted to make sure it was the right way to go.. thank you much man
juakherri
Year: 1989
Extra Info: manual
Postby juakherri [OP] » March 15th 2012, 10:26pm
I hear that to change callipers I should replace the rubber line as well and flush the break fluid. I get how to take them off but I'm unsure about the rubber line and flushing the fluid... And tips offered would be greatly appriciated
juakherri
Year: 1989
Extra Info: manual
Postby Lumpy » March 16th 2012, 1:42am
The rubber brake lines simply unscrew with a wrench. Screw the new one's on. Then you have to bleed the brakes. There's several ways to do that. Browsing throughYouTube about BLEEDING BRAKES will return a gazillion videos on the subject.
None of the above is difficult in the least. One of the easiest DIY jobs I've ever done.
Firing on 2 Cylinders (L4)
Topics: 116
Year: 1989
Extra Info: 9 in. lift Camo
Postby juakherri [OP] » March 16th 2012, 2:25am
Right on thank u.
juakherri
Year: 1989
Extra Info: manual
Postby paintdrying » April 5th 2012, 7:05pm
Those rubber lines just screw off? Do I have to hold the metal one. Everything is pretty rusty, and not much room to work as well. Maybe I could pop the clip off of the rubber line. Please explain further.
paintdrying
Topics: 94
Extra Info: 108 000
Postby Jasen » April 5th 2012, 7:15pm
The clip just holds the line to the bracket. Spray liberally with PB blaster and use tubing wrenches on both hard and soft lines.
This is the clip you speak of?
http://the-99percent.blogspot.com/
I'm a Journeyman woodworker,
Every projects a journey man.
Firing on 5 Cylinders (L7)
Years of Membership: Jasen has been a member for 3 full yearsJasen has been a member for 3 full yearsJasen has been a member for 3 full years
Topics: 250
Images: 68
Year: 1997
Postby paintdrying » April 5th 2012, 8:46pm
Exactly the clip. Not sure if pulling the shock would help, or if I should unbolt the bracket holding the clip and then wrestle with it while the rubber line is on the ground.
paintdrying
Topics: 94
Extra Info: 108 000
Postby Jasen » April 5th 2012, 11:49pm
i've not done them on my van, but i think you can leave it in the clip while removing the rubber line. if your replacing the rubber, just take some pruning shears to it and get it out of your way, pulling the shock might give you a little extra working room.
Topics: 250
Images: 68
Year: 1997
Postby smokinjoe » April 6th 2012, 2:36am
You should attempt to retain as much brake fluid as possible in the system. This way you use the new stuff to pump out the old. (meaning pinch or plug the brake lines)
If you just let it run dry (air), then it will take you approximately one million times longer to bleed the system.
Then you will come crawling back on here begging for answers..........
smokinjoe
Years of Membership: smokinjoe has been a member for 4 full yearssmokinjoe has been a member for 4 full yearssmokinjoe has been a member for 4 full yearssmokinjoe has been a member for 4 full years
Topics: 77
Alias (AKA): smokinjoe
Year: 1995
Extra Info: RWD
Return to Brakes
It is currently June 19th 2013, 12:24pm
Brakes Forum
Attached by: chevymaher
in Brakes
Comments: 17
Date: Apr 16 '13
Time: 1:16am
allman
in Brakes
Comments: 19
Date: Apr 03 '13
Time: 5:44pm
allman
in Brakes
Comments: 19
Date: Mar 24 '13
Time: 6:02pm
in Brakes
Comments: 19
Date: Mar 24 '13
Time: 2:00pm
allman
in Brakes
Comments: 19
Date: Mar 24 '13
Time: 1:54pm
