Brake fluid leaking '02 Astro RWD
Postby middleman90 [OP] » July 13th 2012, 2:22am
2002 Astro. RWD 165k
Noticed fluid on garage floor at drivers side front. After some research, I figured it was coming from under the reservoir. Not the reservoir itself but from the aluminum block that is below reservoir and booster. I assume this is a brake proportioning valve???
When standing at front of van there is a small nipple/pin on the right side of the block that "pops" out when the brake is applied. When this "pin/nipple" pops out a drip or 2 of brake fluid come out with it.
Can anyone tell me whats going on here?
I have been adding fluid to the reservoir to keep up with whats coming out.
I did front rotors and pads about a year ago. Backs need to be done soon.
Thanks for your help. :pray:
middleman90
Alias (AKA): middleman
Year: 2002
  • Front Passenger side brake line on AWD Astro
    by AstroSafarifam » November 24th 2012, 11:04pm in Brakes
    Last post by AstroSafarifam View the latest post
  • Brake failure! Help please?
    by davlafont » February 10th 2013, 10:43pm in Brakes
    Last post by davlafont View the latest post
    March 25th 2013, 6:45pm
    May 20th 2013, 3:55am
Re: Brake fluid leaking '02 Astro RWD
Postby paintdrying » July 13th 2012, 2:54am
If it is your pro valve then they are about 150 dollars. I have installed new ones, not sure if that is a good idea. If it is leaking it is bad.
paintdrying
Years of Membership: paintdrying has been a member for 2 full yearspaintdrying has been a member for 2 full years
Topics: 94
Extra Info: 108 000
Postby RECox286RECox286 is online! » July 13th 2012, 3:19am
You have an Oring that is passing a bit of fluid. The book says that the assy is not serviceable, and believe me it ain't (at the least, it is a
ruinous process to get one apart).
Not saying that you shouldn't address the problem, you should, but if I were you, I would take a look in the JY for a good used one. One that is
off the same exact model, year, JB# brake system, etc. You don't want to be screwing around with a valve that is not ratioed correctly
for your truck.
Good hunting
Uncle Bob
Green Status (L4)
Green Status (L4)
Years of Membership: RECox286 has been a member for 2 full yearsRECox286 has been a member for 2 full years
Topics: 28
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [323K mi]
Postby middleman90 [OP] » July 14th 2012, 3:58am
Thanks guys...I apppreciate your help. I'll start looking into new and used prop valves.
middleman90
Year: 2002
Return to Brakes
It is currently May 20th 2013, 3:55am
Brakes Forum
Attached by: chevymaher
in Brakes
Comments: 17
Date: Apr 16 '13
Time: 1:16am
allman
in Brakes
Comments: 19
Date: Apr 03 '13
Time: 5:44pm
allman
in Brakes
Comments: 19
Date: Mar 24 '13
Time: 6:02pm
in Brakes
Comments: 19
Date: Mar 24 '13
Time: 2:00pm
allman
in Brakes
Comments: 19
Date: Mar 24 '13
Time: 1:54pm
