electronic brake controle module motor relay circuit?co265??
Postby bkzxclusive [OP] » November 3rd 2008, 6:55am
I've been having ABS prob. with my astro ever since i got it, bout 5months now, changed a couple of stuff, tires, rotors, drums, pads and shoes hoping it will fix it but unfortunately it didnt. The prob is while im braking slowly once i hit the 5mph range ABS kicks in and wont let me stop, the ABS and BRAKE lights randomly light up, so once it lite up, i took it to a shop to get the codes out, it came out to be Code 265, Electronic Brake Control Module Motor Relay Circuit. What and Where is this?? and Where can i get it??? HELP!!!!!! This prob has almost got me into several accidents!!!
2000 ASTRO AWD
bkzxclusive
Years of Membership: bkzxclusive has been a member for 8 full yearsbkzxclusive has been a member for 8 full yearsbkzxclusive has been a member for 8 full yearsbkzxclusive has been a member for 8 full yearsbkzxclusive has been a member for 8 full yearsbkzxclusive has been a member for 8 full yearsbkzxclusive has been a member for 8 full yearsbkzxclusive has been a member for 8 full years
Topics: 27
  • Brake lines
    by plymouthcranbrook » November 16th 2016, 4:49am in Brakes
    Last post by plymouthcranbrook View the latest post
    December 3rd 2016, 6:50am
  • Brake issue
    by Bertsam2 » February 6th 2017, 6:34am in Brakes
    Last post by deafman View the latest post
    February 20th 2017, 10:52pm
    7
    16
    April 29th 2017, 10:35am
Re: electronic brake controle module motor relay circuit?co265??
Postby spongebob218 » November 5th 2008, 2:49am
It sounds like you have two seperate issues. Your low speed activation is most likely the result of rust under the front wheel speed sensors. It causes them to lift slightly and increases the airgap between the sensor and the reluctor wheel in the hub. The sensors need removed and the mounting surface needs cleaned. This is an extremely common problem on all late model GM trucks.
The C0265 is an internal failure in the EBCM/Pump motor assembly. If this is a hard failure(light is always on, code sets every ignition), the first thing to check is if you have power at the EBCM/motor assembly. Check the fuses first, if they are good, check for power at the connectors for the EBCM/motor. Check the connectors for corrosion. If all that checks good, the cheapest solution would be an EBCM/motor assembly from a salvage yard. It will need to be setup by the dealer however.
If the the code is intermittent, there are a few specific checks that should be done, but...it basically comes out the same.
Hope this helps.
You ain't nothin' unless you have green plugs.
spongebob218
Years of Membership: spongebob218 has been a member for 8 full yearsspongebob218 has been a member for 8 full yearsspongebob218 has been a member for 8 full yearsspongebob218 has been a member for 8 full yearsspongebob218 has been a member for 8 full yearsspongebob218 has been a member for 8 full yearsspongebob218 has been a member for 8 full yearsspongebob218 has been a member for 8 full years
Postby bkzxclusive [OP] » November 7th 2008, 6:53am
wow, sounds great, ill give all these things a try!! is there a way that i can get a pic of the sensors and ebcm so that i could know exactly what im looking for? I dont have much time to wrk on my truck do to my work schedule, so i need to get things done quik! srry for the late response!
2000 ASTRO AWD
bkzxclusive
Topics: 27
Postby AstroAustin » November 7th 2008, 7:13am
>> Moved from New Member Lounge to Brakes forum. Please don't post the same question twice in two different forums.
-AstroAustin
support@astrosafari.com
Full FBSS Air Suspension :: Triangulated 4-Link :: Engine Driven Compressor :: 4 Air Tanks :: 1/2" SMC Valves :: Phantom Billet Grill
AstroAustin
Blue Status (L2)
Blue Status (L2)
Years of Membership: AstroAustin has been a member for 9 full yearsAstroAustin has been a member for 9 full yearsAstroAustin has been a member for 9 full yearsAstroAustin has been a member for 9 full yearsAstroAustin has been a member for 9 full yearsAstroAustin has been a member for 9 full yearsAstroAustin has been a member for 9 full yearsAstroAustin has been a member for 9 full yearsAstroAustin has been a member for 9 full years
Topics: 120
Images: 18
Year: 1988
Extra Info: 4.3L V6 FBSS AirRide
Postby Nutsy » September 14th 2009, 10:39pm
spongebob218 wrote:It sounds like you have two seperate issues. Your low speed activation is most likely the result of rust under the front wheel speed sensors. It causes them to lift slightly and increases the airgap between the sensor and the reluctor wheel in the hub. The sensors need removed and the mounting surface needs cleaned. This is an extremely common problem on all late model GM trucks.
Hope this helps.
I am getting this code intermittently. What are the checks?
Thanks.
Nutsy
Years of Membership: Nutsy has been a member for 8 full yearsNutsy has been a member for 8 full yearsNutsy has been a member for 8 full yearsNutsy has been a member for 8 full yearsNutsy has been a member for 8 full yearsNutsy has been a member for 8 full yearsNutsy has been a member for 8 full yearsNutsy has been a member for 8 full years
Topics: 7
Extra Info: SLT
Return to Brakes
It is currently April 29th 2017, 10:35am
Brakes Forum
Attached by: 97cargocrawler
97cargocrawler
in Brakes
Comments: 13
Date: Apr 18 '17
Time: 4:36pm
gordo999
in Brakes
Date: Apr 10 '17
Time: 1:03am
petema
in Brakes
Comments: 14
Date: Mar 24 '17
Time: 10:25pm
in Brakes
Comments: 14
Date: Mar 24 '17
Time: 8:34pm
in Brakes
Comments: 14
Date: Mar 24 '17
Time: 4:25pm
