2 wheel abs vs 4 wheel abs
Postby felcan [OP] » December 20th 2012, 9:54pm
I have a 1990 safari Gt ......How do I know without taking the rotor off the front if I have 2wd ABS or 4 wd ABS ........I have found a RPO code of JM5 but unsure if this is the code or not......Ted
felcan
Years of Membership: felcan has been a member for 7 full yearsfelcan has been a member for 7 full yearsfelcan has been a member for 7 full yearsfelcan has been a member for 7 full yearsfelcan has been a member for 7 full yearsfelcan has been a member for 7 full yearsfelcan has been a member for 7 full years
Topics: 9
Alias (AKA): t
Year: 1990
Extra Info: Gt.4.3 v6 2wd
Re: 2 wheel abs vs 4 wheel abs
Postby kornphlake » December 20th 2012, 10:08pm
You should be able to see the wire from the ABS sensor without removing he wheel, it will be the only electrical cable coming from the wheel hub area running up the A-arm. I'm not sure in your van, but in later generations the ABS module is under the van directly below the driver's seat, if you can't find the wire coming from the front hub, try tracing it from the ABS module under the driver's set to the front of the van, it should be pretty obvious. Alternately you could drive onto some dirt, stomp on the brake and crank the steering wheel, if you skid in a straight line you don't have 4 wheel ABS, if you turn instead of stopping you've got 4 wheel ABS.
kornphlake
Years of Membership: kornphlake has been a member for 6 full yearskornphlake has been a member for 6 full yearskornphlake has been a member for 6 full yearskornphlake has been a member for 6 full yearskornphlake has been a member for 6 full yearskornphlake has been a member for 6 full years
Images: 8
Extra Info: SLT RWD
Postby felcan [OP] » December 20th 2012, 10:21pm
I want to change the rotors due to some rust issues on the rotor.......there are 2 listings for rotors for the van....1 with 4wd ABS and 1 with 2wd ABS it looks like there is 2 different thickness in the rotors......right now my ABS light is on constant so the ABS is not working ....am wondering if previous owner had the right rotors on
felcan
Topics: 9
Alias (AKA): t
Year: 1990
Postby DRZ » December 20th 2012, 10:35pm
AWD rotors are just slide on rotors over the hubs . 2wd rotors are also the hub assy as one unit.
DRZ
Firing on 5 Cylinders (L2)
Years of Membership: DRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full years
Topics: 45
Images: 55
Alias (AKA): HPbyStan
Year: 2004
Extra Info: awd cargo Alloys
Postby ProStreet_LS1 » December 20th 2012, 10:40pm
There should wires wrapped inside a black tube about the size of a straw coming out behind your wheel & running up the A-arm. I am not using ABS, cut my off.
Not an expect, but dont think there is a thickness difference. The only difference, there is a spot for the sensor. My 98 Astro came with ABS & ABS rotors. I have regular rotors, that were on my 85 Astro, on it now.
1985 Pro Street Chevy Astro: parted, scrapped & upgraded to
1998 Pro Street Chevy Astro: Tubbed w/ 33x22 rear tires, 350 hp aluminum LS1 V8
PRO STREET 4 LIFE, GEARHEAD 4 LIFE
ProStreet_LS1
Years of Membership: ProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full years
Topics: 54
Year: 1998
Extra Info: LS1 V8 Pro Street
Postby WoodButcher » December 20th 2012, 11:51pm
It isn't 4 wheel or 2 wheel ABS. You either have ABS or not and yours does. The question your asking or being asked is whether your van is "all wheel drive" or "two wheel drive". The brake rotors are different.
What you need to do is look under your van for a differential and axles in the front,,,, or a sticker on the fender, maybe a plate on the doorjamb, if your really stuck look up the vin at compnine.
WoodButcher
Firing on 4 Cylinders (L5)
Topics: 28
Images: 436
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby ProStreet_LS1 » December 21st 2012, 1:02am
Is it AWD or RWD (2wd)?
Was AWD an option on 90 Safari GT?
If it is AWD, the rotor is thicker as a whole, has to fit over AWD hub.
ProStreet_LS1
Topics: 54
Year: 1998
Postby felcan [OP] » December 21st 2012, 5:06am
It is a 2 Wheel Drive .....The listing for brake rotors say's that there is 2 different rotors for this .....1 is for 2 wheel ABS and the other is for 4 wheel ABS......just was wondering if there was a way to tell by the rpo codes without crawling under and checking to see if there was the wire coming from the wheel sensors
felcan
Topics: 9
Alias (AKA): t
Year: 1990
Postby WoodButcher » December 21st 2012, 1:52pm
Well, I guess I learn something new today,
Like I said, try compnine.
http://www.compnine.com/vid.php
WoodButcher
Topics: 28
Images: 436
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Return to Brakes
It is currently February 27th 2017, 4:49pm
Brakes Forum
Attached by: chevymaher
in Brakes
Comments: 32
Date: Nov 28 '16
Time: 5:59am
in Brakes
Comments: 32
Date: Nov 28 '16
Time: 3:12am
in Brakes
Comments: 32
Date: Nov 28 '16
Time: 2:48am
in Brakes
Date: Nov 12 '16
Time: 6:03am
Attached by: 97cargocrawler
97cargocrawler
in Brakes
Date: Nov 10 '16
Time: 10:33pm
Users browsing this forum: Google [Bot] and 1 guest
