Rear Brakes Won't Bleed
Postby mainer [OP] » November 18th 2008, 3:43pm
I have a 2002 Astro AWD that i just had a rear brake cylinder leak. I found it blown apart. The problem i'm having is that I can't get the brake line to bleed. I tried applying pressure on the brake peddle and opening the bleeder (after replacing the cylinder), but I can't get any fluid to pump out. I even took off the bleeder and i still don't have any fluid. How long should it take before i see fluid coming out? I don't hear any air sounds and no air pressure out of the hose. The fluid level is fine (and it never went dry).
I'll check the other rear brake tonight. Maybe it's gone too.
Also, when i press the brakes with the van off, the peddle goes to the floor, but when it's turned on i get some pressure (from the booster i guess).
Please advise. Thanks!!
mainer
Years of Membership: mainer has been a member for 8 full yearsmainer has been a member for 8 full yearsmainer has been a member for 8 full yearsmainer has been a member for 8 full yearsmainer has been a member for 8 full yearsmainer has been a member for 8 full yearsmainer has been a member for 8 full yearsmainer has been a member for 8 full years
Re: Rear Brakes Won't Bleed
Postby NorwegianAstro » November 18th 2008, 6:06pm
Same problem with my -90 Astro Van. Tryed to bleed rear brake lines, but no pressure. Nothing comes oute when we open, with full pressure on the brakes...
What is wrong???
1990 Chevrolet Astro 4,3l V6
1989 Chevrolet Silverado 4x4 Pickup (sold)
1988 Pontiac Fiero Formula 2,8l, aut.
1971 Chevrolet Camaro SS 5,7l ZZ4 TH700 aut.
1971 VW Beach Buggy
1963 VW Beetle 1,7l Injection
NorwegianAstro
Years of Membership: NorwegianAstro has been a member for 8 full yearsNorwegianAstro has been a member for 8 full yearsNorwegianAstro has been a member for 8 full yearsNorwegianAstro has been a member for 8 full yearsNorwegianAstro has been a member for 8 full yearsNorwegianAstro has been a member for 8 full yearsNorwegianAstro has been a member for 8 full yearsNorwegianAstro has been a member for 8 full years
Postby mainer [OP] » November 18th 2008, 6:18pm
I'm thinking there may be air in the modulator, but i want to rule out any reset switch or anything else to do with the abs. I just found this article http://74.125.45.132/search?q=cache:xuI-Lsy7IyMJ:www.aa1car.com/library/abs_kelseyhayes.htm which explains the braking system very well.
Any other advice?
mainer
Postby astro355 » November 18th 2008, 8:24pm
Call me Captain Obvious but did you refill the master cylinder before you tried bleeding it? And if so, was the rear circuit fully drained? If all of the fluid drained from the rear circuit, you will have to work the air out of the circuit.
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full years
Year: 1989
Extra Info: 355 V8 700R4
Postby mainer [OP] » November 18th 2008, 9:18pm
What do you mean by refill the master cylinder? The resevoir is not low. Yes, the driver's side rear drained significantly when the wheel cylinder failed, so if i still have air in the line how do i work out the air?
mainer
Postby astro355 » November 18th 2008, 9:31pm
When I said master cylinder, I should have said reservoir. Was either reservoir empty? Getting air out of these systems sucks. If that is the case, what I would recommend is to open the passenger side rear bleeder first and gravity bleed it. Getting the first drops of brake fluid out of that bleeder may take a long time but you will have to watch the fluid level in the reservoir. If that level gets too low again, you will have to start over. Once you get fluid flowing, you can then bleed them normally. And only open up the passenger side rear bleeder, not both rear bleeders.
Of course, this is assuming that there are no other leaks.
Is your brake booster rusty? Especially around the mounting flange with the master cylinder.
astro355
Year: 1989
Postby mainer [OP] » November 18th 2008, 9:51pm
No rust. The brake fluid hasn't gone down after i was doing this for 10 min. How long should i anticipate for bleeding this? I took the bleeder completely off and there's no sign or sound of fluid coming out. This is an ABS system. I'm wondering if I should be resetting something? Maybe in need to bleed the modulator?
Could the proportioning valve have something to do with it?
Is there another joint or cylinder before the wheel cylinder that i have to bleed?
mainer
Postby astro355 » November 19th 2008, 12:00am
mainer wrote:No rust. The brake fluid hasn't gone down after i was doing this for 10 min. How long should i anticipate for bleeding this? I took the bleeder completely off and there's no sign or sound of fluid coming out. This is an ABS system. I'm wondering if I should be resetting something? Maybe in need to bleed the modulator?
There is nothing to reset. No to the rest of the questions. Once air gets in those systems, is a PITA. This is why shops use pressurized bleeder systems which forces the air out. It seriously could take hours.
Do you have a vacuum pump? What you could try is attaching the vacuum pump to the loosened bleeder screw and suck the air/brake fluid do to the wheel cylinder.
Is either of the brake idiot lights lit?
astro355
Year: 1989
Postby kidhauler » November 19th 2008, 7:27am
If you had a huge leak the valve in the master cylinder might have slid to shut the fluid off to the rear brakes. They do this in the event of a massive leak so that you don't blow all the fluid out and run out of brakes.
Gone to happier grounds.
kidhauler
Years of Membership: kidhauler has been a member for 9 full yearskidhauler has been a member for 9 full yearskidhauler has been a member for 9 full yearskidhauler has been a member for 9 full yearskidhauler has been a member for 9 full yearskidhauler has been a member for 9 full yearskidhauler has been a member for 9 full yearskidhauler has been a member for 9 full yearskidhauler has been a member for 9 full years
Postby astro355 » November 19th 2008, 12:31pm
kidhauler wrote:If you had a huge leak the valve in the master cylinder might have slid to shut the fluid off to the rear brakes. They do this in the event of a massive leak so that you don't blow all the fluid out and run out of brakes.
And if that's the case, one of the idiot lights will be lit.
astro355
Year: 1989
Postby mainer [OP] » November 19th 2008, 6:11pm
Thanks astro355 and kidhauler! Success! Incidently, i left the brake line open before leaving for work. When i arrived back last night the fluid leaked through (obviously nothing is holding it back). I refilled the resevior and pressed the brake for about 1/2 hr and it pumped through fine. I guess i wasn't waiting long enough.
The van now brakes fine with no sponginess. i think you're right about the master cylinder sliding shut too becuase my brakes were working fine in the front even though had a massive leak in the back.
mainer
Postby astro355 » November 19th 2008, 8:03pm
Glad you got it done.
astro355
Year: 1989
Return to Brakes
It is currently May 28th 2017, 4:07pm
Brakes Forum
Attached by: Astro Pop
Astro Pop
in Brakes
Comments: 40
Date: May 09 '17
Time: 10:53pm
Attached by: 97cargocrawler
97cargocrawler
in Brakes
Date: Apr 18 '17
Time: 4:36pm
gordo999
in Brakes
Date: Apr 10 '17
Time: 1:03am
petema
in Brakes
Comments: 14
Date: Mar 24 '17
Time: 10:25pm
in Brakes
Comments: 14
Date: Mar 24 '17
Time: 8:34pm
