Im looking for the highest quality (lifetime) front brake rotors for an early Safari '86
looking for input from only those that have put over 100,000 miles on them.
Ive managed to get over 200,000 on the originals, (never let the pads wear down)
Im thinking I'll go with OEM rotors since these have been great and only recently warped one pulling a trailer down a mountain but I doubt the quality is available that was in 1986. a performance aftermarket set is probably the best bet form long term. anyone have good results they can share?
mine are the hubrotors with bearings pressed into them, how easy can this be changed to seperate rotor/hub assemblies while retaining 5X5 lug pattern?
the '86 doenst have ABS, is there an upgraded master cylinder for these?
mine sees extream use so I want to improve the most important parts on it if I can (Brakes)
thanks
thanks
