Astro power steering hiss noise from steering wheel
Postby RegalCustom [OP] » January 5th 2011, 5:23am
I have a 2002 Astro LT 4.3L rwd, and after changing the steering gear box it makes a hissing sound from the steering wheel through the steering colum. It sounds like the power steering fluid that is being pumped through the steering gear box. I have replaced the power steering gear twice and it still makes the hiss noise. Also, flushed the system and replaced with GM PS fluid and also tried a synthetic fluid. No change. The sound occurs when the wheel is turned in either direction at idle or while moving. I have read similar threads about this type of noise with other GM trucks but can't seam to find a solution.
Thank you for any possible suggestions.
RegalCustom
Years of Membership: RegalCustom has been a member for 2 full yearsRegalCustom has been a member for 2 full years
Extra Info: LT 4.3L V6 RWD
  • Steering Wheel not turning properly
    by lilpig » March 13th 2013, 12:57am in Steering
    Last post by lilpig View the latest post
    March 16th 2013, 8:29pm
  • Electric Power Steering
    by Jimmy_safari » March 29th 2013, 11:43pm in Steering
    Last post by Jimmy_safari View the latest post
    May 24th 2013, 10:45am
Re: Astro power steering hiss noise from steering wheel
Postby redfury » January 9th 2011, 4:39am
Possible air in the system? Bleeding is as simple as turning the wheel to the left and the right, but not to the stopping point, just before a few times, then returning to center and letting the engine run a few more minutes to help push the air up and out, checking the fluid as you go along.
If this doesn't change the noise, then it may be the pump itself? I'm assuming when you talk the gearbox, you are talking the gearbox at the end of the steering shaft, correct? Because if that's the case, the only thing it should be is something in the hydraulics. A whine or noise from the pump could be transmitted through the column, as well as anything else in the suspension that could be making noises. A hiss though tends to tell me something that is constant.
redfury
Firing on 5 Cylinders (L2)
Years of Membership: redfury has been a member for 2 full yearsredfury has been a member for 2 full years
Topics: 30
Images: 12
Year: 1998
Extra Info: LT 5.7L 4wd
Return to Steering
It is currently May 24th 2013, 10:45am
Steering Forum
akkid
in Steering
Date: May 22 '13
Time: 1:24am
Attached by: A Random Bush
A Random Bush
in Steering
Date: May 12 '13
Time: 6:39pm
raziko
in Steering
Comments: 21
Date: Apr 17 '13
Time: 7:39pm
Attached by: Spider'sSafari
Spider'sSafari
in Steering
Comments: 21
Date: Apr 16 '13
Time: 5:26pm
andrew728
in Steering
Date: Apr 05 '13
Time: 3:56am
