Did a fluid flush cure my power steering problem?
Postby kennyj [OP] » April 6th 2011, 2:57am
This past winter I started getting a lot of pump noise, that typical whine, especially in really cold temps. Also when cranking the wheel I was getting some bad groaning sounds. I assumed I was ready for a new pump and have been waiting for warm weather to deal with it.
So today I went and picked up a new pump and got the puller tool. I wanted to start with a flush to get all the old fluid out of the system.
I disconnected the return line from the reservoir and put it in a jug to catch the old fluid, then siphoned all the old fluid from the reservoir. I proceeded to run three quarts through until it was running clean, while operating the brakes and turning the wheel lock to lock. The fluid that came out initially was really nasty: black, burnt and sludgy. No metal particles though. Chances are it was the original fluid with 160k.
When I got done flushing it was running really quiet so I went for a ride and did some hard turns and it seems totally cured. My question is what's the chance that fresh fluid took care of my problem and my pump is actually okay. Or is the pump likely damaged and needs replacing anyway? I'm hoping no particles in the old fluid was a good sign.
kennyj
Firing on 8 Cylinders (L1)
Years of Membership: kennyj has been a member for 3 full yearskennyj has been a member for 3 full yearskennyj has been a member for 3 full years
Topics: 33
Alias (AKA): Kenny
Extra Info: RWD 183k miles
  • power steering cooler and fluid
    by JT! » April 29th 2013, 2:45am in Steering
    April 29th 2013, 2:51am
  • power steering problem
    by deercorpse » January 1st 2013, 11:02pm in Steering
    Last post by redfury View the latest post
    April 15th 2013, 4:36pm
    9
    21
    May 22nd 2013, 2:15pm
Re: Did a fluid flush cure my power steering problem?
Postby paintdrying » April 6th 2011, 3:54am
Friend of mine runs seafoam through his about every 10,000 miles. Van turns like it is riding on glass. All kidding aside, on many fords they have noisy pumps and the cure seems to be flush and refill with synthetic. Chevy has a much better pump. If it is working I would take the new pump back. You can always go buy it again if you need it.
paintdrying
Years of Membership: paintdrying has been a member for 2 full yearspaintdrying has been a member for 2 full years
Topics: 94
Extra Info: 108 000
Postby cowboydan » April 13th 2011, 12:55am
totally. like any other system, it needs new fluid every now and then. i add lucas to the pump. your van seems to be a special case ...caught before it broke kind of case! you just saved yourself 500 bucks at any known shop.
2006 sebring 2.7 touring: DD
1980 buick regal sport coupe? ??
cowboydan
Firing on 7 Cylinders (L2)
Years of Membership: cowboydan has been a member for 2 full yearscowboydan has been a member for 2 full years
Topics: 64
Alias (AKA): cbd
Year: 1997
Extra Info: 4.3w CL AWD
Postby redfury » April 13th 2011, 1:00am
I may have to do the same to my van as it has a definite whine at idle and while using the brakes and turning...the brakes sound like they have a high speed valve opening and closing when I put good pressure on them. I'll report back my results when I get it done...I need to replace some hoses anyway that are leaking...good reason to mess with it now.
redfury
Firing on 5 Cylinders (L2)
Years of Membership: redfury has been a member for 2 full yearsredfury has been a member for 2 full years
Topics: 30
Images: 12
Year: 1998
Extra Info: LT 5.7L 4wd
Postby kennyj [OP] » April 23rd 2011, 5:16am
Just to report back, it's been more than 2 weeks and my power steering has been just fine. It took three quarts to get it to run clear. If you're going to do this don't forget to operate the brakes to get the hydroboost cleaned out.
After flushing I was getting a noise on right turns that I thought was the steering gear, turned out part of the wheel well skirt had come loose and was scraping on the tire. :oops:
:lol: It worked so well for my axle but I didn't even think to try it on the power steering. :rofl:
kennyj
Topics: 33
Alias (AKA): Kenny
Postby cowboydan » April 24th 2011, 12:35am
kennyj wrote:Just to report back, it's been more than 2 weeks and my power steering has been just fine. It took three quarts to get it to run clear. If you're going to do this don't forget to operate the brakes to get the hydroboost cleaned out.
i had that happen, i thought it was a bad cv, but it turned out to be the inner fender plastic also. i pinned it back on both sides and presto, gone
cowboydan
Topics: 64
Alias (AKA): cbd
Year: 1997
Return to Steering
It is currently May 22nd 2013, 2:15pm
Steering Forum
akkid
in Steering
Date: Today
Time: 1:24am
Attached by: A Random Bush
A Random Bush
in Steering
Date: May 12 '13
Time: 6:39pm
raziko
in Steering
Comments: 21
Date: Apr 17 '13
Time: 7:39pm
Attached by: Spider'sSafari
Spider'sSafari
in Steering
Comments: 21
Date: Apr 16 '13
Time: 5:26pm
andrew728
in Steering
Date: Apr 05 '13
Time: 3:56am
