Power steering pump question
Postby xit [OP] » September 24th 2011, 6:25pm
After reading about all the power steering pump problems here I would like some advice. My pump is starting to whine, should I just replace it, flush the system or drive it until it gets worse or better, it is the original pump with only 53,000 miles. I see where a lot of you have replaced them only to get one that also makes noise.
1994 Astro Van
xit
Possibly Natures most perfect food, good beef jerky and cold beer
xit
Years of Membership: xit has been a member for 1 full year
Topics: 28
Images: 4
Year: 1994
Extra Info: Conversion
  • Power steering pump questions!
    by garypely » April 5th 2013, 1:03am in Steering
    Last post by garypely View the latest post
    April 5th 2013, 1:35am
  • Wanted! Evo valve for Power steering pump
    by nopaybob » March 5th 2013, 2:28am in Steering
    Last post by deercorpse View the latest post
    April 14th 2013, 8:54am
    81
    May 22nd 2013, 2:58am
Re: Power steering pump question
Postby Phantom » September 24th 2011, 7:09pm
That is low mileage for a pump ,, flushing would do some good and using a fluid like
Valvoline SYN Power steering fluid will help , whine is usually air being pushed around , here is a procedure you can use , I noticed it in another GM forum ,, when mine whined i flushed and filled with SYN Power and it is silent now , has been ever since
Try bleeding the P/strg system this way to see if this helps.
Important: Power steering fluid level must be maintained throughout bleed procedure.
Fill pump reservoir with fluid to minimum system level, FULL COLD level, or middle of hash mark on cap stick fluid level indicator.
Important: With hydro-boost only, the oil level will appear falsely high if the hydro-boost accumulator is not fully charged. Do not apply the brake pedal with the engine OFF. This will discharge the hydro-boost accumulator.
If equipped with hydro-boost, fully charge the hydro-boost accumulator using the following procedure:
2.1. Start the engine.
2.2. Firmly apply the brake pedal 10-15 times.
2.3. Turn the engine OFF.
Raise the vehicle until the front wheels are off the ground. Refer to Lifting and Jacking the Vehicle in General Information.
Key on engine OFF, turn the steering wheel from stop to stop 12 times.
Vehicles equipped with hydro-boost systems or longer length power steering hoses may require turns up to 15 to 20 stop to stops.
Verify power steering fluid level per operating specification. Refer to Checking and Adding Power Steering Fluid .
Start the engine. Rotate steering wheel from left to right. Check for sign of cavitation or fluid aeration (pump noise/whining).
Verify the fluid level. Repeat the bleed procedure if necessary
Phantom
Firing on 7 Cylinders (L4)
Years of Membership: Phantom has been a member for 2 full yearsPhantom has been a member for 2 full years
Postby Lumpy » September 24th 2011, 7:37pm
New pump isn't expensive. Your old one, even though low mileage, is 25+ years old.
Hundred bucks or so will get you a new pump, new hoses, new fluid and a PS fluid FILTER in the low press line.
Then it'll drive like new.
You could flush and refill it. That will cost quite a few dollars. And you'll have the equivalent of
an old pump with new fluid. I've done that too. If I had the extra dollars, I'd go ahead and replace.
Firing on 2 Cylinders (L4)
Topics: 116
Year: 1989
Extra Info: 9 in. lift Camo
Postby howso » November 23rd 2011, 5:37pm
dose any one know of a HI TEST :o and or HI VOLUME :screaming: power steering pump for the Astro,Safari van line,after replacing the power steering pump on my 97 :mrgreen: astro I started thinking when I was going to convert a 110" G10 over to a 4x4 :doh: they had all kinds of overdrive pumps for the 4x4's I 'am clearly convinced that the pump combination brakes ,steering is a BIG weak link in this van !!!!!! :violin: :cheers:
afari line
howso
Years of Membership: howso has been a member for 1 full year
Extra Info: LT 4.3L V6 RWD
Postby chevymaherchevymaher is online! » December 23rd 2011, 3:01pm
howso wrote:dose any one know of a HI TEST :o and or HI VOLUME :screaming: power steering pump for the Astro,Safari van line,after replacing the power steering pump on my 97 :mrgreen: astro I started thinking when I was going to convert a 110" G10 over to a 4x4 :doh: they had all kinds of overdrive pumps for the 4x4's I 'am clearly convinced that the pump combination brakes ,steering is a BIG weak link in this van !!!!!! :violin: :cheers:
We must have the luck of the Irish then.We have had 4 vans all were driven to over 200 thousand we never had any problem with the pumps on any of them.They sell aftermarket hydroboost kits for racing/street cars.We are so impressed with them we are actually considering putting them on the chevelle and charger.Solves vacuum issues on cars with big cams.
Firing on 1 Cylinder (L7)
Topics: 50
Images: 92
Year: 1994
Postby 2xlbob » September 11th 2012, 1:26am
Although this thread is a year old, it seems to fit right in with my problem. I'm a newby with a 2000 AWD, and gettin' too damn old to be rollin' around underneath this thing. I originally thought I had a power steering pump going out, due to the increasing amount of effort it took to turn it(mostly at low speeds). After replacing the pump, I couldn't turn the wheels at all. So, upon further investigation it was discovered that the drivers side idler arm was locked up(good thing I'm not gettin' paid by the hour). After replacing both idler arms I made a feeble attempt to bleed the system and failed. Tonight I tried the "Phantom" bleed system, which seemed a little better at first, but didn't change the stiff turning and no brakes. So why not take a test drive. Thinking that higher rpm's might get things flowing, still no luck. Aside from throwing a new pump at it, I was wondering if anyone has ever tried doing a pressure bleed on this, like some do on a brake job. Any suggestions at this point would be most welcome.
2xlbob
Years of Membership: 2xlbob has been a member for 1 full year
Year: 2000
Postby Lumpy » September 11th 2012, 3:23pm
I can't imagine how any kind of external pressure bleed scenario would do something that the regular pump pressure wouldn't do.
I'm a little confused in your description. Did you replace the pump?
Did replacing the idler arms remedy the locked up steering?
When you fill the reservoir, then turn the wheels lock to lock in attempt to bleed, does the PS fluid level appear to go down?
When you drive it around the block, do you hear that "power steering whine" that sounds like your fluid is low? Or does it sound normal, just steers hard? Which brings the question, how are you determining that the PS system is not yet bled?
Do you have hydroboost brakes or vacuum boost brakes?
If that's a new pump, and the steering gear is anywhere near functioning, I have to think that there's something really simple that's just not connected right, belt not on etc.
Topics: 116
Year: 1989
Postby 2xlbob » September 13th 2012, 3:00am
In answer to your questions
I'm a little confused in your description. Did you replace the pump? Yes
Did replacing the idler arms remedy the locked up steering? Yes
When you fill the reservoir, then turn the wheels lock to lock in attempt to bleed, does the PS fluid level appear to go down? No
When you drive it around the block, do you hear that "power steering whine" that sounds like your fluid is low? Yes Or does it sound normal, just steers hard? No Which brings the question, how are you determining that the PS system is not yet bled? When I loosen the pressure line I get fluid but very little pressure.
Do you have hydroboost brakes or vacuum boost brakes? Hydroboost
If that's a new pump, and the steering gear is anywhere near functioning, I have to think that there's something really simple that's just not connected right, belt not on etc. New belt routed like the picture, and it fits fine. I'll check the feed tube this weekend to see if its clear. If so, I'll probably get a new pump, and try again. Thanks
2xlbob
Year: 2000
Postby Lumpy » September 13th 2012, 5:25pm
Do the brakes appear to be functioning normally? ie they feel like they are getting normal power assist?
Is the high pressure line a new replacement? Every time you remove and recouple those ends, it's probably a good idea to replace the 50c O-ring.
We'd better get someone more familiar with hydroboost in on the thread. Mine is vacuum, just two hoses, no external reservoir etc.
I'm still a little cloudy about the initial symptoms, idler arms, PSteering, PBrakes and how any of the symptoms and resolutions seem connected.
Topics: 116
Year: 1989
Return to Steering
It is currently May 22nd 2013, 2:58am
Steering Forum
akkidakkid is online!
in Steering
Date: Today
Time: 1:24am
Attached by: A Random Bush
A Random Bush
in Steering
Date: May 12 '13
Time: 6:39pm
raziko
in Steering
Comments: 21
Date: Apr 17 '13
Time: 7:39pm
Attached by: Spider'sSafari
Spider'sSafari
in Steering
Comments: 21
Date: Apr 16 '13
Time: 5:26pm
andrew728
in Steering
Date: Apr 05 '13
Time: 3:56am
