Help! Major steering problem!
Postby kennyj [OP] » April 1st 2012, 8:54pm
So my idler arms were getting sloppy and today I went to change them out for some new ones, and now my steering is messed up. It's like it's steering backwards, or upside down. I can't figure this out. Is it possible to put the idlers on the wrong sides, or upside down?
If you want to see what I'm talking about look at the vid. This is messed up, I don't think I can drive it like this!
:confused:
kennyj
Firing on 8 Cylinders (L1)
Years of Membership: kennyj has been a member for 3 full yearskennyj has been a member for 3 full yearskennyj has been a member for 3 full years
Topics: 33
Alias (AKA): Kenny
Extra Info: RWD 183k miles
  • To have or not to have a steering problem
    by Wiper » March 8th 2013, 5:55pm in Steering
    Last post by Wiper View the latest post
  • power steering problem
    by deercorpse » January 1st 2013, 11:02pm in Steering
    Last post by redfury View the latest post
    April 15th 2013, 4:36pm
    May 22nd 2013, 2:16am
Re: Help! Major steering problem!
Postby Lumpy » April 1st 2012, 9:06pm
That's major weird. Here's a diagram of the steering components for a RWD -
I don't think you can install the idler arms in the wrong place. One has a bent mounting bracket, the other has a straight mounting bracket. But I can't imagine the idler arms having anything to do with the steering being backwards. I think you could remove them entirely and it should still steer right for right, left for left.
It's almost as if the pitman arm was installed upside down. But that's impossible, it's keyed and only fits one way.
Any chance you got the Relay Rod installed incorrectly? Not likely if all you removed were the idlers. But maybe looking at the diagram while looking at the actual front end will help you see what's connected goofy.
Firing on 2 Cylinders (L4)
Topics: 116
Year: 1989
Extra Info: 9 in. lift Camo
Postby Dirk » April 1st 2012, 9:22pm
It kind of looks like an April fools joke :dunce:
1985 Astro conversion, engine type N 4.3 4BBL
If you can't fix it with a hammer you've got an electrical problem!
Parts are cheap breakdowns expensive.
Don't worry about miles per gallon, worry about smiles per gallon!
Dirk
Years of Membership: Dirk has been a member for 3 full yearsDirk has been a member for 3 full yearsDirk has been a member for 3 full years
Extra Info: 4.3L 4BBL
Postby chevymaherchevymaher is online! » April 1st 2012, 9:31pm
I am in a rare position because my van apart. I had to go down and sit in the chair twice and stare at the front end parts. That one is for Ripleys believe it or not. Like Lumpy said pitman arm only way I see to make it do that. But it would be passing straight through the lower pulley. I think call a priest and perform an exorcism. It is amazing and I am beside myself on this one. When you figure it out post it. I just got to know what this is.
Firing on 1 Cylinder (L7)
Topics: 50
Images: 92
Year: 1994
Postby Dirk » April 1st 2012, 9:34pm
I'm sticking with an April fools joke. It's April first today ;)
Excuse me for being suspicious, I've been tricked once too many today.
Dirk
Postby chevymaherchevymaher is online! » April 1st 2012, 9:48pm
Dirk wrote:I'm sticking with an April fools joke. It's April first today ;)
I did look hard for a line like it was photoshopped. But just kept silent. :oops:
Topics: 50
Images: 92
Year: 1994
Postby Lumpy » April 1st 2012, 10:06pm
If it really is an April Fool's joke, then me and Jasen will sneak over to his house tonight and turn his pitman arm around so it really DOES steer like that.
Topics: 116
Year: 1989
Postby Mr_Bowtie » April 1st 2012, 11:54pm
Thats a pretty good April Fools joke.... :rofl:
'96 Astro AWD 206K miles!
31" tires LIFTED 4" total with tires! Pushbar, KC lights, CB radio, Tach....REDNECK!
'01 Crown Vic P71(not stock) 14.7@94mph
'97 Blazer 4x4 127K
'02 Caravan 290K
Mr_Bowtie
Years of Membership: Mr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full years
Topics: 69
Images: 8
Year: 1996
Extra Info: Lifted AWD
Postby paintdrying » April 2nd 2012, 12:10am
No, I was fooled again this year. Oh, this beat the lawn mower gas in the rear end.
paintdrying
Years of Membership: paintdrying has been a member for 2 full yearspaintdrying has been a member for 2 full years
Topics: 94
Extra Info: 108 000
Postby Mr_Bowtie » April 2nd 2012, 12:13am
^Ya that was a classic one....was that last year or the year before? :clap:
'97 Blazer 4x4 127K
'02 Caravan 290K
Mr_Bowtie
Topics: 69
Images: 8
Year: 1996
Postby kennyj [OP] » April 2nd 2012, 12:31am
I need to find the fill plug for the steering gear; I'm going to try Seafoam in the steering box and see if this gets any better.
:shrug:
kennyj
Topics: 33
Alias (AKA): Kenny
Postby TDMobile » April 2nd 2012, 12:42am
What all exactly DID you take off the front end? I almost feel like somehow you switched the steering arms around.......
And looking at the video, if it's fake - it's a damn good one, if you look at the reflection of the tire on the body, it matches the position of the tire, and with his head moving back and forth through the whole thing, that'd have to be a damn good editor
TDMobile
Years of Membership: TDMobile has been a member for 1 full year
Topics: 12
Images: 5
Year: 2005
Extra Info: AWD Cargo 300K
Postby Big_kid » April 2nd 2012, 2:18am
My money says that the steering linkage is disconnected, and there's an accomplice on the passenger wheel turning in the opposite direction.
Best April Fools joke I've seen all day. :D
Firing on 3 Cylinders (L4)
Years of Membership: Big_kid has been a member for 4 full yearsBig_kid has been a member for 4 full yearsBig_kid has been a member for 4 full yearsBig_kid has been a member for 4 full years
Topics: 66
Images: 39
Extra Info: 2WD conversion
Postby Jasen » April 2nd 2012, 2:25am
Lumpy, I'll meet you at the truck stop, we can have a piece of pie first.
http://the-99percent.blogspot.com/
I'm a Journeyman woodworker,
Every projects a journey man.
Firing on 4 Cylinders (L7)
Years of Membership: Jasen has been a member for 3 full yearsJasen has been a member for 3 full yearsJasen has been a member for 3 full years
Topics: 249
Images: 68
Year: 1997
Postby Thunderball » April 2nd 2012, 2:53am
I'm with Big Kid on this one. I think there's someone on the passenger side manually turning the wheels. There's no way this could happen from changing idler arms...I just did it and it's fine. Unless the Pitman arm is 180 degrees off, and that can't happen.
But that does look pretty bizarre...be weird to drive like that!!
_________________________________________________________________________________
2001 Astro LS - 4.3L V-6 - RWD - 260,000 miles
Thunderball
Years of Membership: Thunderball has been a member for 2 full yearsThunderball has been a member for 2 full years
Images: 5
Year: 2001
Extra Info: LS 4.3L V6 RWD
Postby kennyj [OP] » April 2nd 2012, 6:18am
I was just reading that YouTube has been released on DVD.
I'm excited that my video will be part of the boxed set!
Happy April 1st! :wave:
kennyj
Topics: 33
Alias (AKA): Kenny
Postby kennyj [OP] » April 2nd 2012, 6:34am
Big_kid wrote:My money says that the steering linkage is disconnected, and there's an accomplice on the passenger wheel turning in the opposite direction.
:ty:
Nope, no hands got dirty for the video. I shot the video (with camera on a tripod), then cropped out the steering wheel part into a new clip. Then I pasted edited portions of that clip back into the original video. It was really tricky getting the timing right, then matching up the clips lighting and movement. There's a few tell-tales; the line through my jeans below the steering wheel, and a few stray thumbs below the crop, like at :26 seconds.
I love April 1st! :bouncy:
kennyj
Topics: 33
Alias (AKA): Kenny
Postby Jasen » April 2nd 2012, 6:35am
kennyj wrote:
Happy April 1st! :wave: :violence-enforcer:
Topics: 249
Images: 68
Year: 1997
Postby RECox286 » April 2nd 2012, 3:04pm
Finally ! A breakthrough on the problem of backing up a trailer.
I knew it was just a matter of time...
Uncle Bob
RECox286
Green Status (L4)
Green Status (L4)
Years of Membership: RECox286 has been a member for 2 full yearsRECox286 has been a member for 2 full years
Topics: 28
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [323K mi]
Postby Mr_Bowtie » April 2nd 2012, 7:22pm
That was good.... :clap:
'97 Blazer 4x4 127K
'02 Caravan 290K
Mr_Bowtie
Topics: 69
Images: 8
Year: 1996
Return to Steering
It is currently May 22nd 2013, 2:16am
Steering Forum
akkid
in Steering
Date: 52 minutes ago
Time: 1:24am
Attached by: A Random Bush
A Random Bush
in Steering
Date: May 12 '13
Time: 6:39pm
raziko
in Steering
Comments: 21
Date: Apr 17 '13
Time: 7:39pm
Attached by: Spider'sSafari
Spider'sSafari
in Steering
Comments: 21
Date: Apr 16 '13
Time: 5:26pm
andrew728
in Steering
Date: Apr 05 '13
Time: 3:56am
