1999 GMC Safari AWD steering box
Postby kramerhd [OP] » May 10th 2012, 1:20pm
Been reading a few post on steering box adjustments.
The following picture is the box for my AWD Safari. Are the red and Yellow screws the adjustment points?
And If so, Is there a right and wrong way to adjust it. My steering has a little too much play, and want to see if a slight adjustment would help.
NOTE* New tires,Idle arms,Alignment,Bushings are in good shape,ball joints are good. Nothing else seems to need replace or repair.
1999 GMC Safari AWD Steering box
kramerhd
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: kramerhd has been a member for 1 full year
Topics: 7
Images: 10
Alias (AKA): Kramerhd
Year: 1999
Extra Info: SLT AWD
Re: 1999 GMC Safari AWD steering box
Postby chevymaherchevymaher is online! » May 10th 2012, 2:06pm
No they are not. Those are just plastic plugs to keep dirt out. That is where the power steering hoses attach.
The one in the center with the yellow mark is the one. There is a nut on that. Loosen it tighten the center screw untill the steering wheel has about 3/8 to 1/2 inch side to side play. Tighten it down and check again. It may change when it is tight. Do the adjustment without the van running.
Firing on 1 Cylinder (L7)
Topics: 50
Images: 92
Year: 1994
Postby kramerhd [OP] » May 10th 2012, 2:33pm
OMG...What a dummy I am, Need to wake up before posting. Of course that is the line connections.
Thanks for the explanation on how to adjust. Really do appreciate your assistance,.
kramerhd
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 7
Images: 10
Year: 1999
Extra Info: SLT AWD
Return to Steering
It is currently May 23rd 2013, 2:50pm
Steering Forum
akkid
in Steering
Time: 1:24am
Attached by: A Random Bush
A Random Bush
in Steering
Date: May 12 '13
Time: 6:39pm
raziko
in Steering
Comments: 21
Date: Apr 17 '13
Time: 7:39pm
Attached by: Spider'sSafari
Spider'sSafari
in Steering
Comments: 21
Date: Apr 16 '13
Time: 5:26pm
andrew728
in Steering
Date: Apr 05 '13
Time: 3:56am
Users browsing this forum: Lowd239Lowd239 is online! and 1 guest
