power steering pump interchange?
Postby webcat [OP] » April 8th 2009, 11:59pm
will a power steering pump from a 1996 5.0L v8 work on a 1988 5.7L without any mods?
webcat
Section Moderator
Section Moderator
Firing on 2 Cylinders (L3)
Years of Membership: webcat has been a member for 4 full yearswebcat has been a member for 4 full yearswebcat has been a member for 4 full yearswebcat has been a member for 4 full years
Topics: 251
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
  • Power steering pump questions!
    by garypely » April 5th 2013, 1:03am in Steering
    Last post by garypely View the latest post
    April 5th 2013, 1:35am
  • Wanted! Evo valve for Power steering pump
    by nopaybob » March 5th 2013, 2:28am in Steering
    Last post by deercorpse View the latest post
    April 14th 2013, 8:54am
    47
    May 23rd 2013, 6:21pm
Re: power steering pump interchange?
Postby gtkane » April 9th 2009, 12:07am
It all depends if the '96 has a 2 wire sensor on the pressure port. If it does, then no.
You may have to swap pullies, though. There is a wide one and a narrow one.
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby webcat [OP] » April 9th 2009, 2:41am
very helpful very very helful thanks
webcat
Section Moderator
Section Moderator
Topics: 251
Return to Steering
It is currently May 23rd 2013, 6:21pm
Steering Forum
akkid
in Steering
Time: 1:24am
Attached by: A Random Bush
A Random Bush
in Steering
Date: May 12 '13
Time: 6:39pm
raziko
in Steering
Comments: 21
Date: Apr 17 '13
Time: 7:39pm
Attached by: Spider'sSafari
Spider'sSafari
in Steering
Comments: 21
Date: Apr 16 '13
Time: 5:26pm
andrew728
in Steering
Date: Apr 05 '13
Time: 3:56am
