How close do AWD tires need to match?
Postby DJSteve [OP] » June 15th 2011, 4:30pm
The front passenger side tire on my 94 Astro awd has sidewall damage and needs to be replaced. The other three tires have quite a bit of life yet (probably not more than 8-10k on them), however they are a couple years old and this particular tire isn't in production anymore. What's my best plan of action?
If I replace just the one tire, how close do I need to stay to the same circumference? I really don't want to have to replace all four. One tire shop I had check it out suggested I replace in pairs, however I don't understand how that gains me much. Is there any sort of mechanism in the transfer case to compensate for uneven front/rear wheel speed? I didn't really think there was, but I could be mistaken. If that's the case replacing two you'd have to put one on each axle to keep the driveshaft speeds even, but then both differentials would be turning constantly--right?
The tires in question are Uniroyal Radial A/S -- P215/75R15. I'm measuring around 7/32 remaining tread depth--don't have a tire gauge but digital caliper was showing about .215" on rears and .205" on fronts.
DJSteve
Years of Membership: DJSteve has been a member for 4 full yearsDJSteve has been a member for 4 full yearsDJSteve has been a member for 4 full yearsDJSteve has been a member for 4 full years
Topics: 9
  • 88 astro with new tires
    by astro352 » March 16th 2013, 9:25pm in Wheels/Tires
    Last post by astro352 View the latest post
    April 5th 2013, 3:25pm
  • Snow Tires?
    by MattW » December 18th 2012, 5:44am in Wheels/Tires
    Last post by chevymaherchevymaher is online! View the latest post
    March 13th 2013, 1:04pm
    60
    May 22nd 2013, 5:44pm
Re: How close do AWD tires need to match?
Postby orion33 » June 15th 2011, 5:10pm
it would be best to stay with the same size tire.you dont need to buy two.just a simular tread pattern.make sure to balace it and i always put the unmatched tire on the rear.
Astros are out of this World!Beam me up Scotty!
orion33
Years of Membership: orion33 has been a member for 1 full year
Alias (AKA): Torry
Extra Info: CL 4.3 AWD Shrty
Postby Pantaz » June 15th 2011, 11:52pm
The closer the better, but a minor size difference shouldn't be a big deal. Many tire manufacturers list tire diameter or circumference on their websites. Measure your tire's current size and see if you can find a close match.
I agree with moving the mismatched tire to the rear. The steering is much more sensitive to size differences than the AWD.
Pantaz
Years of Membership: Pantaz has been a member for 2 full yearsPantaz has been a member for 2 full years
Year: 1985
Extra Info: Stretched 34 in.
Postby maximus7001 » August 3rd 2011, 9:51am
Just make sure you have the same correct pressure in all 4 tires and you should be fine.
97 Safari SLT AWD
68 AMC Javelin SST
85 AMC Eagle wagon 4x4
97 Ford Contour
maximus7001
Years of Membership: maximus7001 has been a member for 4 full yearsmaximus7001 has been a member for 4 full yearsmaximus7001 has been a member for 4 full yearsmaximus7001 has been a member for 4 full years
Topics: 7
Year: 1997
Extra Info: AWD 375000km
Postby gtkane » August 5th 2011, 4:12am
GM says max 2/32" difference between tires on any AWD or 4WD vehicle.
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby 88astroLT » August 5th 2011, 7:27pm
Yes try and keep the thread heights the same. If the tire really needs replacing i would suggest buying a Used tire (there should be some local near you) that has as close as possible thread depth as the other three.
88 Astro LT RWD 345k+ 3.43
97 Safari SLE RWD 113k+ 3.43 Limited Slip
88astroLT
Years of Membership: 88astroLT has been a member for 2 full years88astroLT has been a member for 2 full years
Topics: 16
Extra Info: LT 4.3L V6 RWD
Postby tedanderson » August 6th 2011, 1:34am
I also agree with putting the mismatched tire on the rear. The rear diff is not as sensitive to differences in tire size. I imagine that the front diff is more particular because it has to contend with being pushed by the transfer case as well as the overall inertia of the van.
tedanderson
Firing on 5 Cylinders (L3)
Years of Membership: tedanderson has been a member for 3 full yearstedanderson has been a member for 3 full yearstedanderson has been a member for 3 full years
Topics: 62
Alias (AKA): 2Big4aMiniVan
Postby Mr_Bowtie » August 6th 2011, 10:20pm
I just replaced all 4 tires on my Van cause one blew out................figured they only have 15K left on them MAYBE & they are cheaper/easier then having to fix the transfer case.
'96 Astro AWD 206K miles!
31" tires LIFTED 4" total with tires! Pushbar, KC lights, CB radio, Tach....REDNECK!
'01 Crown Vic P71(not stock) 14.7@94mph
'97 Blazer 4x4 127K
'02 Caravan 290K
Mr_Bowtie
Years of Membership: Mr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full years
Topics: 69
Images: 8
Year: 1996
Extra Info: Lifted AWD
Postby maximus7001 » August 7th 2011, 1:19am
tedanderson wrote:I also agree with putting the mismatched tire on the rear. The rear diff is not as sensitive to differences in tire size. I imagine that the front diff is more particular because it has to contend with being pushed by the transfer case as well as the overall inertia of the van.
Make sure you have an open rear diff. This may destroy a g80 limited slip if the size is too far off.
Nobody takes into account that 90% of all vehicle tires are not properly inflated or checked. This could make more of a difference than different brands of the same size that are properly inflated and checked.
97 Safari SLT AWD
68 AMC Javelin SST
97 Ford Contour
maximus7001
Topics: 7
Year: 1997
Postby rich69 » August 12th 2011, 1:51am
I was told by a tire dealer that it had to be within something like 3/32 of an inch.
Otherwise, the computer can't properly adjust for the difference.
Quite frankly, I'd say he was selling tires.
rich69
Years of Membership: rich69 has been a member for 3 full yearsrich69 has been a member for 3 full yearsrich69 has been a member for 3 full years
Extra Info: 4.3L AWD
Postby redfury » August 12th 2011, 3:27am
On a 94, there is no computer involved in the AWD. The idea behind the tires on an AWD being within a certain tolerance is simple, anytime you have one tire rotating faster than another, there is additional strain on the system, whether it's the transfer case because of a front/rear rolling size difference, or the differentials taking the strain from two different sized tires.
Two scenarios come to mind. Put two tires on one axel so that the strain is lessened all around, or put one tire on any axel and have that one tire throw everything off.
Personally, if I wasn't in a position to replace all the tires or even two, I'd look to find a used tire within the same rolling diameter as the rest on the van. It isn't ideal to mix and match tires on any drive axel, but any tire shop can measure the rolling diameter and get you into a tire that will work for the time being...any other way and you are rolling the dice to see what is going to fail first.
Keep it in spec ( 2/32 ) and you should be fine until you can pull the trigger for 4 new ones.
redfury
Firing on 5 Cylinders (L2)
Years of Membership: redfury has been a member for 2 full yearsredfury has been a member for 2 full years
Topics: 30
Images: 12
Year: 1998
Extra Info: LT 5.7L 4wd
Return to Wheels/Tires
It is currently May 22nd 2013, 5:44pm
Wheels/Tires Forum
Brady628
in Wheels/Tires
Date: May 18 '13
Time: 10:14pm
Attached by: AmericanMade717
AmericanMade717
in Wheels/Tires
Comments: 64
Date: May 01 '13
Time: 1:34am
hereticsdetroit
in Wheels/Tires
Comments: 9
Date: Apr 09 '13
Time: 3:58am
terrymcp
in Wheels/Tires
Date: Apr 09 '13
Time: 12:47am
Attached by: hebert
hebert
in Wheels/Tires
Date: Apr 06 '13
Time: 4:09pm
