Factory S10 Alum wheels on Astro AWD...?
Postby 64crew4x4 [OP] » October 28th 2011, 4:58pm
Has anyone put these wheels on an AWD astro....?
http://www.ebay.com/itm/15-Inch-Wheels- ... es&vxp=mtr
I can Buy a set of 5 Locally for 100.00
I was thinking of Putting them on my 235x70x15 Tires for the Van....
Does anyone have pics of these on an Astro...?
Thanks, John
64crew4x4
Years of Membership: 64crew4x4 has been a member for 5 full years64crew4x4 has been a member for 5 full years64crew4x4 has been a member for 5 full years64crew4x4 has been a member for 5 full years64crew4x4 has been a member for 5 full years
  • 2001 AWD Astro with 15 x 8 rims hitting cut away fender
    by NomadforNature » September 24th 2016, 1:52am in Wheels/Tires
    Last post by WoodButcherWoodButcher is online! View the latest post
    October 1st 2016, 3:41pm
  • new wheels!! also help
    by CoasterCoaster is online! » August 27th 2016, 2:55am in Wheels/Tires
    Last post by CoasterCoaster is online! View the latest post
    October 26th 2016, 8:32pm
    23
    February 24th 2017, 4:33am
Re: Factory S10 Alum wheels on Astro AWD...?
Postby 'cudapaul » October 28th 2011, 5:09pm
Thy won't fit, the bolt spacing diameter is too small.
'cudapaul
Years of Membership: 'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby 64crew4x4 [OP] » October 28th 2011, 5:22pm
So Factory 1993 S10 Wheel lug pattern is Different....?
I thought The Astro and S10 Shared the same pattern...?
the Wheel off e-bay was just a referance pic...For the style of rim I am looking at...
Thanks, John
64crew4x4
Postby Phantom » October 28th 2011, 5:28pm
S-10 have 4.75 bolt pattern
Gen2 Astro has 5 x 5 bolt pattern ,, some of the older Astro had the 4.75
Phantom
Firing on 7 Cylinders (L4)
Postby 64crew4x4 [OP] » October 28th 2011, 5:32pm
Ok...Good to know....
Thanks.....
64crew4x4
Postby ProStreet_LS1 » October 28th 2011, 5:34pm
Pretty sure, all Astro were 5x5 bolt pattern. I have an 85 Astro, had new holes drill into the rotor for the 5x4 3/4 bolt pattern.
1985 Pro Street Chevy Astro: parted, scrapped & upgraded to
1998 Pro Street Chevy Astro: Tubbed w/ 33x22 rear tires, 350 hp aluminum LS1 V8
PRO STREET 4 LIFE, GEARHEAD 4 LIFE
ProStreet_LS1
Years of Membership: ProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full yearsProStreet_LS1 has been a member for 7 full years
Topics: 54
Year: 1998
Extra Info: LS1 V8 Pro Street
Postby Phantom » October 28th 2011, 5:47pm
Yep I just looked it up ,, all astro are 5x5 until 02
Phantom
Postby Lumpy » October 28th 2011, 9:05pm
tpibadassastro wrote:... I have an 85 Astro, had new holes drill into the rotor for the 5x4 3/4 bolt pattern.
That answers a question I asked you in another thread.
Did you do that to accomodate some other non-Astro wheels?
You mentioned needing new calipers and brakes with the new spacing.
Was that too because of the non-Astro wheels?
Topics: 258
Year: 1989
Return to Wheels/Tires
It is currently February 24th 2017, 4:33am
Wheels/Tires Forum
KennTower
in Wheels/Tires
Time: 9:02pm
YakClimber78
in Wheels/Tires
Comments: 29
Date: Feb 08 '17
Time: 6:01pm
SLAYOR
in Wheels/Tires
Comments: 29
Date: Feb 08 '17
Time: 4:24pm
3vilfallen
in Wheels/Tires
Date: Feb 05 '17
Time: 7:19am
Attached by: Nomad
Nomad
in Wheels/Tires
Date: Feb 05 '17
Time: 6:27am
