"service awd" light. Problem solved!
Postby rubrbulits [OP] » January 11th 2011, 11:47pm
I thought I would share the solution to my problem since I have read other threads with similar issues. I just bought this 2005 AWD Astro Cargo Van for my business. I live in Iowa so the AWD is great! It has 170,000 miles on it, but they are highway miles from the previous leasee. From the start I noticed a kind of slight "grabby" feeling as I would accelerate from a stop on dry pavement going in a straight line. After reading threads about the Auto TrakII synthetic lube, I had the transfer case fluid changed. The mechanic said I already had the Auto trakII in the transfer case, but it was old and broken down. That fixed the problem with the "grabby" issue immediately! My main issue however has been that the "service awd" light would come on and off, and when the light was on, I had no awd. It would happen like this. When I go to start the van, most of the time I would hear a clicking noise in the kick panel by my left foot. About 4-5 clicks. Then the light comes on and stays on. Then, I get to my next job site, turn the van off, start it back up an hour later and no clicking sound or "awd light". More than half the time the light comes on though. I figured it could be the encoder motor, but didn't want to spend $581.00 on a hunch, "dealer price". So I found out I could get a non-OEM encoder motor at Oreilly's for 145.00 + 25.00 core, lifetime warranty. I just installed it today and it works PERFECT! I know this because we just got 6 inches of snow. I am curious to see how long this encoder motor lasts though. Thanks Astrosafari.com!
rubrbulits
Years of Membership: rubrbulits has been a member for 6 full yearsrubrbulits has been a member for 6 full yearsrubrbulits has been a member for 6 full yearsrubrbulits has been a member for 6 full yearsrubrbulits has been a member for 6 full yearsrubrbulits has been a member for 6 full years
Topics: 5
Alias (AKA): chris
Extra Info: 4.3L V6 AWD Carg
  • AWD coasting vs 2wd
    by astronator » December 30th 2016, 9:48pm in Automatic
    January 1st 2017, 6:09pm
    January 23rd 2017, 9:32am
Re: "service awd" light. Problem solved!
Postby Phantom » January 12th 2011, 1:16am
Great to hear you got it fixed , good to know there is an alternative to the dealer price
Phantom
Firing on 7 Cylinders (L4)
Postby Matrixx » January 12th 2011, 11:19pm
That's a great write-up rubrbulits, thanks for posting it.
I'm sure this will definitely help others in the same situation that you had.:)
Matrixx
Years of Membership: Matrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full years
Postby redfury » January 13th 2011, 12:26am
Yup, that's the problem with these electronically controlled drivetrains...the average guy can't just dive into them and figure out what the problem is without a proper scanner. I was just quoted $275 to have my van thrown on the computer and have the PCM and transmission gone over to have the proper parameters set. I could do it myself, but I'd have to spend $500 for the software and cables to hook up my own Laptop...crazy!
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Year: 1998
Extra Info: LT 5.7L 4wd
Postby JuneauCabbie » January 13th 2011, 6:01am
redfury wrote:Yup, that's the problem with these electronically controlled drivetrains...the average guy can't just dive into them and figure out what the problem is without a proper scanner. I was just quoted $275 to have my van thrown on the computer and have the PCM and transmission gone over to have the proper parameters set. I could do it myself, but I'd have to spend $500 for the software and cables to hook up my own Laptop...crazy!
As soon as I have a little extra cash, I'm buying an UltraGauge, mentioned in another thread here. See http://www.ultra-gauge.com/ultragauge/index.htm
I wanted a tach, but this not only has a digital tach, but a full scanner, including the ability to reset codes. And only $60!
JuneauCabbie
Years of Membership: JuneauCabbie has been a member for 7 full yearsJuneauCabbie has been a member for 7 full yearsJuneauCabbie has been a member for 7 full yearsJuneauCabbie has been a member for 7 full yearsJuneauCabbie has been a member for 7 full yearsJuneauCabbie has been a member for 7 full yearsJuneauCabbie has been a member for 7 full years
Topics: 30
Images: 21
Alias (AKA): JuneauCabbie
Year: 2003
Extra Info: SXT 4.3L V6 AWD
Postby JuneauCabbie » August 4th 2011, 8:11pm
Unfortunately, I discovered that the UltraGuage only resets P engine codes, not other sensor codes. So I can't use it to clear the "Service AWD" light.
JuneauCabbie
Topics: 30
Images: 21
Year: 2003
Postby rubrbulits [OP] » November 26th 2012, 11:42pm
UPDATE! Since this post I've replaced the encoder motor twice. It originally lasted about 2 months, The next one made it about 3 months. Oreillys wont warranty the part anymore so I have been driving with the SERVICE AWD light on for a while now. Now that its almost December I crawled under my van to test the encoder motor and it of course is shot. I guess I will try an OEM part this time, it's really all I can do at this point.
rubrbulits
Topics: 5
Alias (AKA): chris
Postby Don1806 » December 6th 2012, 12:55am
Any idea what brand the Encoder Motor from O'Reilly's was? There are numerous brands of aftermarket and rebuilt units available through Rock Auto, Auto Zone, Advance etc. with a full range of prices as well. Just curious which brand you had the quality issue with. Thanks.
99 Astro LT - Orginal Owner.
Don1806
Years of Membership: Don1806 has been a member for 6 full yearsDon1806 has been a member for 6 full yearsDon1806 has been a member for 6 full yearsDon1806 has been a member for 6 full yearsDon1806 has been a member for 6 full yearsDon1806 has been a member for 6 full years
Images: 2
Alias (AKA): Don
Year: 1999
Extra Info: AWD 170K
Postby Don1806 » December 6th 2012, 4:40pm
Disregard my last question. Looked at O'Reilly's website and for the price you quoted the motor was a Cardone which is a rebuilt motor. Just saw your other post where you thought it was a Dorman. The Dormans are over $ 200.00 but are new, not rebuilt.
I'm having a Dorman put on mine today, so will update if there are any issues or problems with that one as well. Keeping my fingers crossed. I've bought other Dorman products and had no issues, so hoping that hold true for the encoder motor as well.
Don1806
Images: 2
Alias (AKA): Don
Year: 1999
Postby Bread Van » December 6th 2012, 6:51pm
Sounds like you need to get an OEM encoder from a JY. OR, better yet, find out why your encoders are going out. Sounds as though something else might be going on and killing your encoder motors.
Bread Van
Years of Membership: Bread Van has been a member for 6 full yearsBread Van has been a member for 6 full yearsBread Van has been a member for 6 full yearsBread Van has been a member for 6 full yearsBread Van has been a member for 6 full yearsBread Van has been a member for 6 full years
Topics: 36
Alias (AKA): mapper
Year: 2003
Extra Info: AWD 2 inch lift
transfer case motor refurb
Postby sadglad » March 17th 2013, 10:40am
I refurbished my transfer case motor and thought someone might like seeing what's inside. Yes, I have more time than money at the moment.
I'm not sure this is a worthwhile project but I was reluctant to buy a new motor based on the bad experience rubrbulits had with them. Worst case scenario the refurb would not work and I only lose a little time. The brushes and commutator looked like they had enough material left to last long enough to make a refurb worthwhile.
I don't like the design of this part. I think it could have been made so the motor could be replaced as a separate part rather than replacing the whole assembly. The planetary gearbox and the gears in the flat housing probably account for 90% of the cost of a new unit and they look like they would last forever. The electric motor itself is nothing more than you would see in a cheap toy and could be sold at low cost. As designed, you have to take everything apart to remove the motor. Dumb.
I had the typical symptoms discussed earlier and measured high resistance across the motor terminals. Light came on about 75% of the time when starting the van. Once I got it apart there was a lot of carbon floating around and the commutator was solid black instead of copper color. I cleaned them up with small needle files and contact cleaner then blew everything out with compressed air. Resistance after was .5 Ohm.
The hardest part of the project was putting the brushes and springs back in the motor. The front part of the motor holding the brushes can only be separated by about .5" so you are working through a small gap. The brushed are held against the commutator by some little springs. You need the dexterity of a three handed brain surgeon get them coiled up and back into place while keeping the brushes in position. Now that I have a technique figured out I could probably do it in 1/4 the time.
The planetary gearbox is held onto the front of the motor with three spiral tension pins. I drilled them out but in hindsight I maybe could have pressed them out and reused them. I ended up drilling and taping the holes and using screws to reattach the planetary housing to the motor.
So far my service AWD light is staying out since putting it back in. Time will tell if works long term.
sadglad
Years of Membership: sadglad has been a member for 4 full yearssadglad has been a member for 4 full yearssadglad has been a member for 4 full yearssadglad has been a member for 4 full years
Images: 14
Year: 2002
Extra Info: 2002 AWD Cargo
Postby sadglad » March 17th 2013, 10:46am
Some pics from the refurb.
sadglad
Images: 14
Year: 2002
Postby sadglad » March 17th 2013, 10:48am
more pics
sadglad
Images: 14
Year: 2002
Postby sadglad » March 17th 2013, 10:50am
more pics
sadglad
Images: 14
Year: 2002
Postby Drummernaut » March 17th 2013, 4:55pm
Nice work!
Thank you
1999 Astro LT AWD
MODS: Electric fan, Transmission cooler/fan, AWD engaged LED
Drummernaut
Years of Membership: Drummernaut has been a member for 6 full yearsDrummernaut has been a member for 6 full yearsDrummernaut has been a member for 6 full yearsDrummernaut has been a member for 6 full yearsDrummernaut has been a member for 6 full yearsDrummernaut has been a member for 6 full years
Topics: 9
Alias (AKA): Drummer From Hell
Year: 1999
Extra Info: LT V6 AWD
Postby Alaskastreamin » April 20th 2013, 2:31am
Looking on rockauto.com I see two motors. One is listed as a 4wd actuator (listed under drivetrain) and has a yellow arm in the flat sided hole and the other is listed under " transfer case" (motor) and looks identical but without the yellow lever. $117 vs $301.
I just bought a '02 AWD with no light on dash and old owner reported won't go into AWD. They had computer swapped and still nothing. 82k miles. Now I am reading on what to look for.
Ron
Ron Pratt
Sitka, Alaska
Alaskastreamin
Years of Membership: Alaskastreamin has been a member for 3 full yearsAlaskastreamin has been a member for 3 full yearsAlaskastreamin has been a member for 3 full years
Year: 2002
Postby Drummernaut » April 20th 2013, 9:01am
Alaskastreamin wrote:I just bought a '02 AWD with no light on dash and old owner reported won't go into AWD. They had computer swapped and still nothing. 82k miles. Now I am reading on what to look for.
Ron
Since this post was about a service AWD light being stuck on because of a bad motor, I would start or look for another post about no service AWD light. There is going to be a different cause for this problem.
1999 Astro LT AWD
Drummernaut
Topics: 9
Year: 1999
Postby tgwms » December 8th 2013, 11:11pm
Thread resurrection!
Long time lurker here; I appreciate the time you all have put into this excellent resource.
Does anyone have re-installation torque specs for the servo motor and front drive shaft bolts? Neither the Chilton or Hayes has the AWD parts, so not sure if they take a good 'uhmpf' or if they need a certain torque for proper function.
Thanks all!
tgwms
Years of Membership: tgwms has been a member for 3 full yearstgwms has been a member for 3 full yearstgwms has been a member for 3 full years
Year: 2005
Postby Jp400motox » December 4th 2014, 4:55pm
I am thinking of trashing the motor off the unit and fabing a manual lever in its place with a cable or rod going into the cabbin. Like a parking brake hand lever... thoughts?
Jp400motox
Years of Membership: Jp400motox has been a member for 2 full yearsJp400motox has been a member for 2 full years
Year: 2001
Extra Info: 01 astro awd cargo
Postby rollinghome » January 4th 2015, 9:45pm
Nice necro! I've been thinking of a similar mod. It would be nice to nix the motor but even a manual switch that controlled the motor would be better than the stock setup.
Jp400motox wrote:I am thinking of trashing the motor off the unit and fabing a manual lever in its place with a cable or rod going into the cabbin. Like a parking brake hand lever... thoughts?
rollinghome
Years of Membership: rollinghome has been a member for 4 full yearsrollinghome has been a member for 4 full yearsrollinghome has been a member for 4 full yearsrollinghome has been a member for 4 full years
Year: 1999
Extra Info: AWD Cargo
Return to Automatic
It is currently January 23rd 2017, 9:32am
Automatic Forum
Moderator: 1297chevastro
Attached by: 00awd
00awd
in Automatic
Comments: 20
Date: Jan 11 '17
Time: 9:13pm
Voltsmith
in Automatic
Date: Dec 26 '16
Time: 4:24am
in Automatic
Comments: 20
Date: Dec 09 '16
Time: 4:54pm
Attached by: markmitch
in Automatic
Comments: 189
Date: Dec 01 '16
Time: 12:51am
theFlyingDutchman
in Automatic
Date: Nov 20 '16
Time: 5:10am
Users browsing this forum: MSNbot Media and 2 guests
