1-2 Shift P1870
1-2 Shift P1870
Postby DjPcEra [OP] » May 13th 2011, 1:29am
I'm going to drain the transmission fluid and change the filter hoping it solves my issue.
I will also add an additive.
Will keep posted with new updates.
Edit : will I need some gasket sealer for this?
1998 Chevy Astro : RWD 4.3L LS
DjPcEra
Years of Membership: DjPcEra has been a member for 5 full yearsDjPcEra has been a member for 5 full yearsDjPcEra has been a member for 5 full yearsDjPcEra has been a member for 5 full yearsDjPcEra has been a member for 5 full years
Topics: 26
Alias (AKA): Mr.Gee
Extra Info: LS 4.3L V6 RWD
Re: 1-2 Shift P1870
Postby DjPcEra [OP] » May 13th 2011, 2:02am
DjPcEra wrote:I'm going to drain the transmission fluid and change the filter hoping it solves my issue.
What transmission fluid should I use? Remember that I won't be flushing, don't know how, nor know if it would help.
DjPcEra
Topics: 26
Alias (AKA): Mr.Gee
Re: 1-2 Shift P1870
Postby chevymaher » May 13th 2011, 2:18am
Dexron just ask when you go to parts place.They will know what you need.You should not need gasket sealer either gasket will be just fine.
Topics: 82
Year: 1994
Re: 1-2 Shift P1870
Postby DjPcEra [OP] » May 13th 2011, 2:36am
chevymaher wrote:Dexron just ask when you go to parts place.They will know what you need.You should not need gasket sealer either gasket will be just fine.
I will only need a gallon of atf, right ?
And is installing a drain plug really hard?
DjPcEra
Topics: 26
Alias (AKA): Mr.Gee
Re: 1-2 Shift P1870
Postby Leeann_93 » May 13th 2011, 2:54am
5 qts, generally. Installing a drain plug is pretty easy.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Re: 1-2 Shift P1870
Postby DjPcEra [OP] » May 13th 2011, 3:27am
Leeann_93 wrote:5 qts, generally. Installing a drain plug is pretty easy.
easy enough for novice?
Also, what is the avg cost for someone to test the pressure lines from the transmission?
DjPcEra
Topics: 26
Alias (AKA): Mr.Gee
Re: 1-2 Shift P1870
Postby DjPcEra [OP] » May 14th 2011, 7:03pm
ok, ive read it's possible to remove the tcc valve without removing the body... anyone?
Solved: watched a vid
DjPcEra
Topics: 26
Alias (AKA): Mr.Gee
Re: 1-2 Shift P1870
Postby DjPcEra [OP] » May 14th 2011, 7:20pm
DjPcEra wrote:ok, ive read it's possible to remove the tcc valve without removing the body... anyone?
wdf the clips on are backwars -_-
DjPcEra
Topics: 26
Alias (AKA): Mr.Gee
Re: 1-2 Shift P1870
Postby DjPcEra [OP] » May 14th 2011, 10:17pm
have the valve body out... the valve plug is stuck... can't push it in or out
DjPcEra
Topics: 26
Alias (AKA): Mr.Gee
Re: 1-2 Shift P1870
Postby DjPcEra [OP] » May 16th 2011, 8:03pm
It went in.... and still does the shift too slow..
I went to another transmission guy and he said there is a ball inside that gets stuck...
sometimes it won't get 1st and pass to 2nd shift... he said he would charge me 200$
DjPcEra
Topics: 26
Alias (AKA): Mr.Gee
Return to Automatic
It is currently April 23rd 2017, 6:55pm
Automatic Forum
Moderator: 1297chevastro
Attached by: chevymaher
in Automatic
Comments: 23
Date: Apr 07 '17
Time: 1:07am
gordo999
in Automatic
Comments: 23
Date: Apr 05 '17
Time: 4:24am
in Automatic
Comments: 9
Date: Mar 30 '17
Time: 6:15pm
Attached by: MtAstro
MtAstro
in Automatic
Comments: 44
Date: Mar 12 '17
Time: 3:44pm
in Automatic
Comments: 44
Date: Mar 11 '17
Time: 4:50pm
