Problems with 3rd gear
Postby GaryLan1 [OP] » November 7th 2011, 2:24am
OK guys, I need your help. I have just bought a 2004 GMC SAFARI that has been well maintained but the transmission will not shift past 2nd gear. When I put it in drive it takes off in 1st, then shifts into 2nd, and then when its time to shift ito 3rd its like its not there.It makes an attempt to shift but it just rev's up untill i let off the gas and it falls back into 2nd, where it stays. Im hopeing its not shot and maybe the silinoid or another problem. ANYBODY got a clue?????????
GaryLan1
Years of Membership: GaryLan1 has been a member for 5 full yearsGaryLan1 has been a member for 5 full yearsGaryLan1 has been a member for 5 full yearsGaryLan1 has been a member for 5 full yearsGaryLan1 has been a member for 5 full years
Extra Info: LT 4.3 RWD
  • Intermittent shift from 2nd to 3rd gear
    by dcarlson12 » November 6th 2016, 6:18pm in Automatic
    November 8th 2016, 8:53pm
  • Motor and transmission problems P0300
    by theFlyingDutchman » October 31st 2016, 10:44pm in Automatic
    November 20th 2016, 3:24pm
    April 23rd 2017, 6:46pm
Re: Problems with 3rd gear
Postby ihatemybike » November 7th 2011, 2:18pm
Sorry to say that this reads exactly what Green did when the 3-4 clutch pack wore out, only solution was major trans work. In my case, I found a rebuilder that sells units for $800 when you bring your old trans as a core. Being the curious sort and having a spare vehicle to use, I had them rebuild Green's mostly to verify that my suspicion about the clutch pack was accurate. I also had them upgrade the trans with a better clutch pack, Beast sun shell, Corvette servo along with the Transgo HD-2 kit that they normally install. Even with the upgrades and renting the transmission jack I had it fixed properly for less than $1000.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Years of Membership: ihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full years
Topics: 67
Postby Mr_Roboto » November 7th 2011, 2:25pm
I bet he's right it could be a valve body issue but dubious. Pull your dip stick if it smells really burnt and looks sorta blackish it's a 3-4 pack that went out. Did this myself yesterday, second time for me too.
Mr_Roboto
Firing on 8 Cylinders (L1)
Years of Membership: Mr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full years
Topics: 37
Postby astroracer » November 7th 2011, 3:49pm
Does it have reverse? If not it is the sun gear. Stripped out teeth. Time for a rebuild.
Mark
2004 Astro
2001 Astro (the wifes)
2000 Monte Carlo SS
2000 Astro Conversion Van
1994 Formula V8 Firebird
1956 Chevy Station Wagon
astroracer
Years of Membership: astroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full years
Alias (AKA): astroracer
Year: 1988
Extra Info: Major renovation
Postby GaryLan1 [OP] » November 15th 2011, 4:10am
Thanks Guys, and yes it has reverse. Thats what i was kinda thinking that it was 3r 4th gear clutch pack but i needed someone else's opion b4 I took it out, because deending on the mood, it can be a ***** to take out, especilly with out the proper jack. Its all good!!! Thanks, Gary Lancaster
GaryLan1
Return to Automatic
It is currently April 23rd 2017, 6:46pm
Automatic Forum
Moderator: 1297chevastro
Attached by: chevymaher
in Automatic
Comments: 23
Date: Apr 07 '17
Time: 1:07am
gordo999
in Automatic
Comments: 23
Date: Apr 05 '17
Time: 4:24am
in Automatic
Comments: 9
Date: Mar 30 '17
Time: 6:15pm
Attached by: MtAstro
MtAstro
in Automatic
Comments: 44
Date: Mar 12 '17
Time: 3:44pm
in Automatic
Comments: 44
Date: Mar 11 '17
Time: 4:50pm
Users browsing this forum: Google Adsense [Bot] and 2 guests
