Transmission won't go into gear when cold!
Postby KC10Chief [OP] » November 9th 2011, 8:53am
I have a 97 Safari AWD that I just bought yesterday. It has 74,000 miles on it. It runs, shifts and rides great! Tonight, I was leaving work about 10pm here in Alaska. It was about 5 degrees out. The van had been running for about 5 minutes (I have auto start). I came out, got in and it wouldn't shift into reverse to back out. The RPMs went way up and it moved back a little, but nothing. It wouldn't go forward in drive either. Finally, after about a minute of revving the engine in reverse, it started to move. It was a little slow to go into drive, but it did and I was able to drive home. It shifted funny one time but after that when I started driving, but it drove great the rest of the way home. I got home and ran it through the gears. Everything seemed perfectly normal then. Any ideas? I'm pretty certain that the cold caused this somehow. Bad fluid? I'll be checking the fluids out tomorrow. Any thoughts on other things I could check?
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Years of Membership: KC10Chief has been a member for 5 full yearsKC10Chief has been a member for 5 full yearsKC10Chief has been a member for 5 full yearsKC10Chief has been a member for 5 full yearsKC10Chief has been a member for 5 full years
Topics: 24
  • 1st gear slipping (I think)? Tips/advice? ... Replace/fix?
    by 99SafariTime » May 22nd 2017, 12:35am in Automatic
    May 22nd 2017, 1:37am
  • Transmission slipping?
    by 00awd » January 11th 2017, 2:32am in Automatic
    Last post by 00awd View the latest post
    January 11th 2017, 9:15pm
    May 25th 2017, 2:14am
Re: Transmission won't go into gear when cold!
Postby daisykleen » November 9th 2011, 11:59am
did you check the fluid ?? when was the last time it was change ?? :?: :?: :?:
daisykleen
Years of Membership: daisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full yearsdaisykleen has been a member for 8 full years
Topics: 9
Postby Phantom » November 9th 2011, 1:23pm
Low fluid level will cause that . If level is high enough ; sometimes when you have a dirty clogged trans filter it takes a while for the fluid to warm up enough to find clear path through the filter , may be time for filter change .
Phantom
Firing on 7 Cylinders (L4)
Postby gmtech68 » November 9th 2011, 4:06pm
GM's reply to several customers when I was working there: "warm up your vehicle."
90 shorty Astro "retirement home for squirrels" 456 000 km
88 Astro Stolen and trashed in 2009
93 Astro AWD LT 405 000 km and climbing
97 Astro AWD Freebie 380 000 km and climbing
A collection of Chev Vegas and variants
gmtech68
Years of Membership: gmtech68 has been a member for 8 full yearsgmtech68 has been a member for 8 full yearsgmtech68 has been a member for 8 full yearsgmtech68 has been a member for 8 full yearsgmtech68 has been a member for 8 full yearsgmtech68 has been a member for 8 full yearsgmtech68 has been a member for 8 full yearsgmtech68 has been a member for 8 full years
Year: 1993
Extra Info: LT AWD 402 000km
Postby KC10Chief [OP] » November 9th 2011, 7:22pm
Thanks! What transmission fluid is the best for these transmissions?
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Topics: 24
Postby Phantom » November 9th 2011, 7:43pm
Dexron 3 or Dexron 6 , Dex3 is what came in it , Dex 6 is GM latest upgrade per TSB is suitable for anything that uses dex 3 , I use Castrol , any quality brand name should be good, if you change the filter be sure to use a good quality filter with the fibrous material , not just a screen and NOT any cheap brand ,
Phantom
Postby KC10Chief [OP] » November 9th 2011, 8:04pm
Thanks! The O'Reilly's near me has Wix and AC Delco. The AC Delco is twice the price of the Wix. Is it worth it? Also, is there more than one transmission for these vans? I thought I had the 4L60, but one of the other options is an M30? Never heard of that.
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Topics: 24
Postby Phantom » November 9th 2011, 8:25pm
4L60E is the same as M30 , just a different way of listing it , GM often calls it both
in the Gen 1 vans of early age they had a few choices , but all Gen 2 96 and newer have the M30
Wix are good so is Ac Delco , unusual that there be that much price difference , it should be 25 -30 dollars , before you put out your money have the counter guy bring out both and compare them
Phantom
Postby KC10Chief [OP] » November 11th 2011, 10:30pm
Well it just got worse. It is like the torque converter just unlocks while I'm driving. It won't get above 30 mph. It pulls fine through first and second and then it feels like the torque converter just unlocks. The rpms go way up. I'm typing on my phone now. I'll type more when I get home. Any ideas?
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Topics: 24
Postby Phantom » November 11th 2011, 11:30pm
What condition /color of your fluid at this time?
Phantom
Postby KC10Chief [OP] » November 11th 2011, 11:37pm
The fluid looks great! I'm going to start with changing the fluid an filter.
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Topics: 24
Postby KC10Chief [OP] » November 11th 2011, 11:39pm
Also, I realized that the torque converter seems fine. It is shifting into a lower gear. It shifts into second and then when I'm up to about 20 mph or so, it shifts back into first. Guy at Napa suggested that it could be the mass air flow sensor. I have a check engine light as well. I am going to take it down to pull the code in a bit.
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Topics: 24
Postby KC10Chief [OP] » November 12th 2011, 1:19am
Just got back from O'Reilly's. The code I got was a P1870 for transmission component slipping. I researched a little on here and most other people are getting this code but not having transmission issues. I am definitely having transmission issues. It will not shift into 3rd or 4th no matter what I do. To get it to shift into 2nd from 1st, I have to drive it to about 25 to 30 mph with the RMPs way up, then let off the gas. It will then shift into 2nd and stay there until I slow back down. Transmission fluid looks good. I did have to add three quarts! I just bought this van and it was fine until today. I drove it last night and it was perfectly fine. Drove it on the highway and everything. It drove fine all the way home last night. It was parked outside last night and it was about 10 degrees outside. This morning, it didn't want to go into gear at first. Kind of the same thing it was doing at first. When it did it the first time, it was fine after about a minute or two. Not today though. Any thoughts?
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Topics: 24
Postby Phantom » November 12th 2011, 1:27am
This reading should help explain more about this code
viewtopic.php?f=70&t=9925
viewtopic.php?f=70&t=13260
Phantom
Postby Phantom » November 12th 2011, 1:28am
Phantom
Postby KC10Chief [OP] » November 12th 2011, 2:04am
Thanks! I had already read those threads. They just don't quite fit the problem I'm having. Most people that get the P1870 code, aren't having any shifting problems or they are having a hard 1-2 shift. I'm definitely having shifting problems that came on suddenly. The 1-2 shift is delayed, but it's definitely not a hard shift. Also, I reset the code with the scan tool. I drove the van another 10 miles or so to get home. The shifting problems are still there, but the code didn't come back. Any other ideas?
I have had this van since Monday. I haven't even put a half tank of gas through it. It was driving and shifting perfectly fine until this morning. I'm about sick over this. I haven't had problems with any vehicle for a long time now. This week, everything is going downhill. I have three vehicles and all have issues. My 96 S-10 just started leaking gas out of one of the injectors this week too. My wife's 08 G6 desperately needs the snow tires put on due to all of the recent snow we have had. I'm going to go do that now, and hopefully I'll have some more ideas from you guys when I get back! I'm very frustrated with vehicles right now.
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Topics: 24
Postby JuneauCabbie » November 12th 2011, 7:32am
Is it possible you could have overfilled the transmission? Did you add fluid, or drain it all and then fill it?
Overfilling the transmission is very hard on the fluid pump.
When I've had shifting problems, it's been a dirty shift body or a malfunctioning shift solenoid. If you were overdue for a fluid change, gunk could have accumulated in the shift body and it would need cleaning. If a solenoid is worn or lube is sticky, it could cause trouble shifting.
And the transmission won't warm up much until the rig's been moving for a little while and fluid has been circulating.
I've got to get that extra set of seats and those tires out of my garage and get the Safari in there before it gets seriously cold here in Our Fair Capital City so I can start the day with a warm and dry taxi. Weather forecast says temps in the low 20s around the middle of next week, after we have 6 inches of snow, followed by rain, followed by more snow; typical Rain Country winter weather.
JuneauCabbie
Years of Membership: JuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full years
Topics: 30
Images: 21
Alias (AKA): JuneauCabbie
Year: 2003
Extra Info: SXT 4.3L V6 AWD
Postby KC10Chief [OP] » November 12th 2011, 8:53am
It's not over filled. Matter of fact, it's still a bit low. It's at the cold line. Also, the transmission had plenty of time to warm up today. We put about 25 miles on it.
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Topics: 24
Postby gmtech68 » November 13th 2011, 10:53pm
Is it possible one of the shaft sealing rings is sticking when it's cold? The ones that GM told the drivers to warm up their vehicles was at about -5 F and colder. That was from technical assistance! Looks like you need someone with a lot of technical knowledge and a scanner to tell what exactly is slipping. To grab a straw, does the speedo work properly? I think these use the output shaft sensor for shifting and operating the speedo. If this trans senses bad slipping it may also default into limp mode which turns off all the electronics and gives you second gear and reverse so you can "limp" home. If it were mine I'd be removing the pan and opening up the filter to check for debris. If it's starving for fluid because it can't get through the filter it will behave very strangely.
gmtech68
Year: 1993
Postby KC10Chief [OP] » November 14th 2011, 2:41am
Well, the past couple of times I've gone out to start it when it's cold, it goes right into gear. It just won't go beyond 2nd gear. It acts like it's going to shift into third, but third just isn't there. It revs way up high. I let off the gas and it goes back into 2nd gear where it stays. .
Today, I went and changed the transmission fluid and the filter. Of course, I didn't get all of the fluid. The fluid definitely smells burned. I just couldn't smell it on the dip stick. But when it came out of the pan, it smells pretty badly burned. There weren't any big chunks of anything in the pan but there was some fine black powder. Looked like clutch material. There was probably just enough in there to cover the bottom of the pan with a thin layer. There was also a layer of sludge stuck to the magnet. I disconnected the battery for a few minutes hoping that if the transmission were in some sort of computer controlled fail safe mode, that it would be reset. No change either.
What do you guys think? Sound toasted? I'm thinking I'll take it in and get a diagnosis done at a transmission shop. I've decided that if this transmission is bad, I'll just buy a new or rebuilt one and to the removal and installation myself. If that comes to pass, what else should I fix while I have it out? I think the rear main seal might be leaking a bit. Not sure. Thoughts?
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Topics: 24
Return to Automatic
It is currently May 25th 2017, 2:14am
Automatic Forum
Moderator: 1297chevastro
Attached by: markmitch
in Automatic
Comments: 194
Time: 7:43pm
in Automatic
Comments: 13
Date: May 18 '17
Time: 7:33pm
Attached by: 97cargocrawler
97cargocrawler
in Automatic
Comments: 13
Date: May 18 '17
Time: 5:33pm
Attached by: 95AstroLT
95AstroLT
in Automatic
Date: May 03 '17
Time: 11:32pm
95AstroLT
in Automatic
Date: May 03 '17
Time: 7:43pm
Users browsing this forum: Google [Bot] and 4 guests
