Neutral safety switch location?
Postby trapper20 [OP] » January 12th 2012, 7:37pm
Where is the neutral safety switch? I am not reusing the shift linkage electronics on my 700r4, so I need to be able to start the engine without the ignition knowing that the truck is in park/neutral. What is the easiest way to bypass the switch?
trapper20
Years of Membership: trapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full years
Topics: 25
Images: 3
Extra Info: Lifted 4x4 V8
Re: Neutral safety switch location?
Postby Phantom » January 12th 2012, 7:57pm
Factory location of switch is on the side of the transmission , if you have removed the transmission the switch went with it ,, to bypass it would to connect the the wires that go to the trans in a way that passes the voltage flow to complete the circuit
Phantom
Firing on 7 Cylinders (L4)
Postby trapper20 [OP] » January 12th 2012, 8:33pm
Ok, thought so. Any idea which wires? There are two harness connectors to the shift linkage electronics assembly.
trapper20
Topics: 25
Images: 3
Postby astroracer » January 12th 2012, 8:35pm
The neutral safety switch is at the bottom of the steering column. Runs off a rod actuated by the shift lever. You have to drop the column to get clear access to it. Putting the van in Park will still actuate it. :)
Mark
2004 Astro
2001 Astro (the wifes)
2000 Monte Carlo SS
2000 Astro Conversion Van
1994 Formula V8 Firebird
1956 Chevy Station Wagon
astroracer
Years of Membership: astroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full years
Alias (AKA): astroracer
Year: 1988
Extra Info: Major renovation
Postby Phantom » January 12th 2012, 8:53pm
astroracer wrote:The neutral safety switch is at the bottom of the steering column. Runs off a rod actuated by the shift lever. You have to drop the column to get clear access to it. Putting the van in Park will still actuate it. :)
Mark
Not on a Gen2 , Gen 2 is located on the side of transmission
Phantom
Postby Phantom » January 12th 2012, 8:55pm
trapper20 wrote:Ok, thought so. Any idea which wires? There are two harness connectors to the shift linkage electronics assembly.
Yea I can tell you which wires are there , the connector also has the connection to the trans solenoids , I dig up a diagram that shows the wiring , I think it is the pink wire fro hot and the bk/white as ground
Phantom
Postby astroracer » January 12th 2012, 9:05pm
He said 700R4. I figured 1st gen. 4l60E is different but the NSS is on the bottom of his column if it's a 1st gen.
2004 Astro
2000 Monte Carlo SS
astroracer
Year: 1988
Postby Phantom » January 12th 2012, 9:21pm
astroracer wrote:He said 700R4. I figured 1st gen. 4l60E is different but the NSS is on the bottom of his column if it's a 1st gen.
Yea that could be a bit confusing ,, he has a Gen 2 van and putting a '72 Chevy 350 in it , he is apparently trying to put the 700R4 in the van , :cheers:
Phantom
Postby astroracer » January 12th 2012, 9:26pm
Phantom wrote:Yea that could be a bit confusing ,, he has a Gen 2 van and putting a '72 Chevy 350 in it , he is apparently trying to put the 700R4 in the van , :cheers:
Ahh... That 'splains it... Thanks.
2004 Astro
2000 Monte Carlo SS
astroracer
Year: 1988
Postby Phantom » January 12th 2012, 9:51pm
Here is a pic of a fellow members 97 astro NSS and here is the wirung diagram for the transmission circuit
96 ground location
97 Astro Transmission Circuit.pdf
(297.3 KiB) Downloaded 85 times
Phantom
Postby trapper20 [OP] » January 12th 2012, 10:38pm
Sweet, thanks. Yeah, sorry I neglected to mention those details, astroracer. '97 van, '74 350, '91 700r4, or 4l60, to be precise.
trapper20
Topics: 25
Images: 3
Return to Automatic
It is currently February 27th 2017, 4:48pm
Automatic Forum
Moderator: 1297chevastro
dkGarnet96
in Automatic
Date: Jan 27 '17
Time: 6:07pm
stevee
in Automatic
Date: Jan 27 '17
Time: 5:57pm
Attached by: 00awd
00awd
in Automatic
Comments: 20
Date: Jan 11 '17
Time: 9:13pm
Voltsmith
in Automatic
Date: Dec 26 '16
Time: 4:24am
in Automatic
Comments: 20
Date: Dec 09 '16
Time: 4:54pm
