A thud and then 2wd
A thud and then 2wd
Postby redfury [OP] » February 4th 2012, 6:36am
Yay! I lost 4wd. My van has a 4wd transfer case set up and the first time I used it this year, I heard a whine out of it and it wouldn't electrically shift into 2wd on the fly. Then it clunked out of it. The second time I used it, it came out on it's own with a big THUD and now it won't re-engage. It worked perfectly last year. Hmph. The only thing different is that I changed tires. I'm going to have to measure the circumference of them to see if I've got a problem there, but in the mean time, I need to figure out what exactly happened to the transfer case.
Since I've never dealt with anything AWD or 4WD, I'd appreciate any input or diagrams for the 4wd transfer case for a 98 GM driveline. My shop manual obviously only covers the AWD case.
redfury
Firing on 5 Cylinders (L2)
Years of Membership: redfury has been a member for 2 full yearsredfury has been a member for 2 full years
Topics: 30
Images: 12
Year: 1998
Extra Info: LT 5.7L 4wd
Re: A thud and then 2wd
Postby Heavyopp » February 5th 2012, 4:31pm
I know there's a common problem in the blazers. Its got to do with the solenoid and wiring harness for the transfer case.
I'm sure a google search will bring up the answer.
Heavyopp
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: Heavyopp has been a member for 1 full year
Year: 1992
Extra Info: HD S10 rear springs
Postby redfury [OP] » February 5th 2012, 7:51pm
I started doing that shortly after posting since I wasn't getting a bevvy of replies. I'm going to get up under the van today and see exactly which transfer case I do have, and see if I have the vacuum lines hooked up and working properly. Since I recently got the P0171/74 codes on the van, there's a possibility that there's a vacuum leak down there and I never got proper engagement.
redfury
Topics: 30
Images: 12
Year: 1998
Return to Automatic
It is currently May 23rd 2013, 4:06am
Automatic Forum
Moderator: 1297chevastro
Attached by: Jasen
in Automatic
Date: May 05 '13
Time: 4:27pm
gollihughj
in Automatic
Date: May 02 '13
Time: 12:21am
gollihughj
in Automatic
Date: Apr 13 '13
Time: 3:22am
Drummernaut
in Automatic
Date: Apr 02 '13
Time: 8:45pm
pcengine92
in Automatic
Date: Mar 18 '13
Time: 10:59pm
