Need help diagnosing WOT slippage
Postby ritous1 [OP] » March 2nd 2012, 6:16am
Well guys, I think the supercharger has finally taken a toll on the 130k mile tranny. I can't say that I've been taking it easy on her. I punch it all the time. Lately I've noticed that any attempt to go wot is met with slippage. It doesn't matter if it's from cruise or from a stop. It shifts and accelerates fine under part throttle and gradual increases in throttle. It seems that the torque generated when I hammer it is overpowering the torque converter. Tranny fluid looked good at last drain, filter change, and refill. There was very little clutch material in the pan. That was all done after the first time I noticed this issue. I had already been considering an upgraded converter, but want to make sure it's not time for a rebuild before I blow my dough.
99 rwd 127,000 miles
custom paxton supercharger
magnaflow cat
doug thorley catback dual exhaust
crane hi-6 ignition & race coil
accel billet distributor
electric fan conversion
aluminum dual core radiator
sonnax shift kit & vette servo
ritous1
Years of Membership: ritous1 has been a member for 5 full yearsritous1 has been a member for 5 full yearsritous1 has been a member for 5 full yearsritous1 has been a member for 5 full yearsritous1 has been a member for 5 full years
Topics: 23
Re: Need help diagnosing WOT slippage
Postby redfury » March 2nd 2012, 6:23am
I think the best way to diagnose this would be to watch the transmission with a scanner to see if it's a problem with the converter or the clutch pack. Does it slip in every gear when you punch it?
redfury
Firing on 5 Cylinders (L2)
Years of Membership: redfury has been a member for 2 full yearsredfury has been a member for 2 full years
Topics: 30
Images: 12
Year: 1998
Extra Info: LT 5.7L 4wd
Postby ritous1 [OP] » March 3rd 2012, 4:57am
When I punch it, it will down shift and rev high but wont go. The first time it happened I thought I was spinning the tires, but there was no squeal. Funny thing is you can let off then increase throttle gradually and all is well. The shifts are just as firm as when I first installed the shift kit. That's why I'm thinking it's the converter. Haven't tried anything with a scanner connected.
magnaflow cat
ritous1
Topics: 23
Postby redfury » March 3rd 2012, 5:25am
what about when you manually shift it through the gears? If the slippage is the same through all the gears, then it isn't the clutch packs. It's either the converter or the pump. Might just be one of those times to have a tranny guy diagnose it if you can afford a small fee to have them do it ( if they'll even charge you...who knows ).
redfury
Topics: 30
Images: 12
Year: 1998
Postby ritous1 [OP] » March 4th 2012, 9:28am
are you suggesting I floor it while manually shifting? I'm kinda affraid to try that, seems like it would do more damage.
magnaflow cat
ritous1
Topics: 23
Postby chevymaherchevymaher is online! » March 4th 2012, 2:02pm
Just a quick question.Are you sure your tires squeal when you spin them?Mine I can brake torque them till they smoke and the make no noise.same sound as spinning in water,almost nothing.You should have enough power it spins like that.Have some one follow you and punch it.If it is in the transmission I wouldn't worry about doing more damage.Damage is already done.And wont go away till it taken apart and rebuilt.
Firing on 1 Cylinder (L7)
Topics: 50
Images: 92
Year: 1994
Postby ritous1 [OP] » March 5th 2012, 7:29am
Dont forget I'm running 20x9" wheels with 255/35/20 tires that seem to grip like crazy. The most I've ever gotten out of them are a 2nd and 4th gear chirp. Never tried a brake stand. I guess I'll try what redfury suggests and see what happens.
magnaflow cat
ritous1
Topics: 23
Return to Automatic
It is currently May 22nd 2013, 2:35pm
Automatic Forum
Moderator: 1297chevastro
Attached by: Jasen
in Automatic
Date: May 05 '13
Time: 4:27pm
gollihughj
in Automatic
Date: May 02 '13
Time: 12:21am
gollihughj
in Automatic
Date: Apr 13 '13
Time: 3:22am
Drummernaut
in Automatic
Date: Apr 02 '13
Time: 8:45pm
pcengine92
in Automatic
Date: Mar 18 '13
Time: 10:59pm
