transmission filter seal removal 4L60E
Postby chris in b'ham [OP] » April 13th 2012, 3:08am
dropped the tranny pan today to change the filter and install a new cast aluminum deep pan from B&M. all went well even considering the fact that the bright sparks at GM forgot to bless us with a drain plug. stupid!! i pulled the filter and then attempted to remove the seal it seats in. no luck whatsoever. it seems like that should be replaced with the filter ( my van is 2005 w/ 4L60E tranny). is there a trick or special tool to get that thing out. i couldn't budge it, so i left it in, put in the new filter and went about my business. what's up with that?
thanks for any light you can shed on this problem.
best to all, chris
chris in b'ham
Years of Membership: chris in b'ham has been a member for 5 full yearschris in b'ham has been a member for 5 full yearschris in b'ham has been a member for 5 full yearschris in b'ham has been a member for 5 full yearschris in b'ham has been a member for 5 full years
Topics: 13
  • 4L60E into earlier vehicle
    by markmitch » December 16th 2016, 5:57pm in Automatic
  • can any rwd 2000 and up 4L60E be swapped?
    by weather » January 27th 2017, 4:30pm in Automatic
    Last post by dkGarnet96 View the latest post
    January 27th 2017, 6:10pm
    26
    February 26th 2017, 1:58am
Re: transmission filter seal removal 4L60E
Postby chevymaher » April 13th 2012, 3:19am
I use a flat screw driver and hammer. Once it bends a needle nose pliers pulls it right out.
Tap the new one in with a same sized socket. The flat end not the open.
Topics: 81
Year: 1994
Postby paintdrying » April 13th 2012, 12:12pm
Do not even worry about it. Just leave it in.
paintdrying
Topics: 94
Extra Info: 108 000
Postby Lumpy » April 13th 2012, 2:48pm
This is the tool I use to remove mine. Four dollars.
Another four dollars will get you a drain plug that you can install.
Topics: 258
Year: 1989
Postby trapper20 » April 13th 2012, 4:47pm
The 2nd Gen van filter seals are a real pain. If you have not already damaged it, just leave it in. If you have damaged it at all, use chevymaher's technique, just be careful not to damage the surrounding aluminum.
trapper20
Years of Membership: trapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full years
Topics: 25
Images: 3
Extra Info: Lifted 4x4 V8
Postby Lumpy » April 13th 2012, 7:29pm
trapper20 wrote:The 2nd Gen van filter seals are a real pain...
Really? Is it even a different filter between a 700R4 and a 4L60?
Topics: 258
Year: 1989
Postby chris in b'ham [OP] » April 13th 2012, 11:20pm
thanks for the quick replies. now that i have the new aluminum pan complete with a drain plug dropping the pan won't be such a pain in the butt. next time i'm in there i'll try again. how critical is that seal to the operation of the tranny?
thanks again, chris
chris in b'ham
Topics: 13
Postby paintdrying » April 14th 2012, 12:22am
It is critical. But damaging the surrounding aluminum would mean real problems . If the filter feels good going in I would not bother with it.
paintdrying
Topics: 94
Extra Info: 108 000
Postby chris in b'ham [OP] » April 14th 2012, 2:06am
if the seal is compromised what effect would that have on the tranny and it's performance?
thanks, chris
chris in b'ham
Topics: 13
Postby chevymaher » April 14th 2012, 2:16am
Shift horrible. If it suckin enough air it will burn the tranny up.
Topics: 81
Year: 1994
Return to Automatic
It is currently February 26th 2017, 1:58am
Automatic Forum
Moderator: 1297chevastro
dkGarnet96
in Automatic
Date: Jan 27 '17
Time: 6:07pm
stevee
in Automatic
Date: Jan 27 '17
Time: 5:57pm
Attached by: 00awd
00awd
in Automatic
Comments: 20
Date: Jan 11 '17
Time: 9:13pm
Voltsmith
in Automatic
Date: Dec 26 '16
Time: 4:24am
in Automatic
Comments: 20
Date: Dec 09 '16
Time: 4:54pm
Users browsing this forum: Google [Bot] and 1 guest
