my 2000 Safari awd when cold,I shift to reverse it does not move,it after awhile it will roll out of the garage,it slips going forward ,then after some time it will work better. Shifting seems slow ,it does not slip all the time,no codes for the transmission.
The fluid and filter was changed before my trip to New York last summer,the level is not low and there is only less than 6000 miles on this fluid.If it was worn clutches were worn ,would it slip all the time. I am look at replacing the transmission,could a new transmission pump fix the problem?
