Tranny Swap/What year will fit?
Postby kocka80 [OP] » March 28th 2008, 10:47pm
Hello everyone newbe on the forum.
I have a 96 gmc safari and my transmission is giving up on me as well as the rear end . both of them was rebuild already once .
unfortunetly the only thing I can afford now is to get these from a junkyard and do the swap my self (never done that before but Im sure I can handle it)
what year will fit to my van?besides 96 what do I have to watch out for ? and someone please turn the light on for me on these numbers 4l60e,700r4? is that how you identify
transmissions ? same questions would apply for the differential too. I was going thru the old forum but never really got an answer .all tranny swaps was for older
vans then mine . I was also reading that people were using trannys from other Chevys would that work for me to or no? this van is my daily driver so the only thing I am looking for is to get it back on the street , I listen to any input you guys make .
thank you all in advance .
kocka80
kocka80
kocka80
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: kocka80 has been a member for 9 full yearskocka80 has been a member for 9 full yearskocka80 has been a member for 9 full yearskocka80 has been a member for 9 full yearskocka80 has been a member for 9 full yearskocka80 has been a member for 9 full yearskocka80 has been a member for 9 full yearskocka80 has been a member for 9 full yearskocka80 has been a member for 9 full years
  • Will a 2000 tranny work in a 97
    by vwghiarob » September 19th 2016, 12:49am in Automatic
    Last post by vwghiarob View the latest post
    September 19th 2016, 2:15am
    February 26th 2017, 8:43am
Re: Tranny Swap/What year will fit?
Postby kocka80 [OP] » March 29th 2008, 9:17pm
All right people Im just trying to help myself as well as other people with future transmission problems here are some links that can be useful
http://72.19.213.157/files/4L60ERepairs.html
http://www.drivetrain.com/autotranscrossref.html
http://www.novak-adapt.com/knowledge/4l60e.htm
and of course I have turned the light on for myself :biggrin:
kocka80
kocka80
Fueling (3/4 tank)
Fueling (3/4 tank)
Postby gtkane » March 30th 2008, 2:12am
For the tranny, you have a 4L60E transmission. It is basically a modern version of a 700R4.
You will want to get one from a '96 to '98 Astro or Safari. The 2wd and 4wd versions are different, so get the appropriate one.
Do not get one from a pick-up truck, Caprice or Camaro. The torque converter and the clutches are different.
As for the rear diff, I believe the mounts for composite and steel leaf springs are different, but otherwise they are all the same('cept for gear ratio's)
Someone may wanna back me up on that, though...
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby kocka80 [OP] » March 31st 2008, 4:17am
thank you for the response firs of all . I also have done more search on this and this is what I have come up with
these vehicles have the 4L60E trannys
Astro 1993 - Up 4L60E
Astro Van, Safari 1995-06 V6 4.3L 4 Spd RWD/4X4 4L60E
Blazer, Jimmy 1992-06 L4 2.2; V6 4.2L 4.3L 4 Spd RWD/4X4 4L60E
Camaro 1994-02 V6 3.4L 3.8L 4 Spd RWD 4L60E
Camaro 1994-05 V8 5.0L 5.7L/LS1 4 Spd RWD 4L60E/4L65E
Caprice 1994 - Up 4L60E
Caprice, Wagon 1992-96 V6 4.3L; V8 5.0L 5.7L 4 Spd RWD 4L60E
Corvette 1992-05 V8 5.7L 6.0L 4 Spd 4L60E/4L65E
Blazer 1993 - Up 4L60E
Envoy, TrailBlazer 1992-06 L4 2.2L; V6 4.2L 4.3L 4 Spd RWD/4X4 4L60E
Express, Savana 1500-2500 1996-06 V6 4.3L 4 Spd RWD/4X4 4L60E
Impala 1994-96 V8 5.7L 4 Spd RWD 4L60E
Impala SS 1994 -Up 4L60E
S10, S15, Jimmy, Sonoma 1991-04 L4 2.5L; V6 4.3L 4 Spd RWD/4X4 4L60E
Silverado, Sierra,1500-3500 1995-96 V6 4.3L 4 Spd RWD/4X4 4L60E
Suburban - 1/2 ton 1993 - Up 4L60E
UplanderVan - 4 speed 1993 - Up 4L60E
Based on this http://racetransmissions.com/mainpages/ ... -list.html
some of these even have the same size (vortec?) engine
Also find some pictures as well
I have the two piece case on my safari , so in my simple mind any of the two case tranny will fit to my van .OR NOT? OR there is more to it then take off and bolt on. sorry for the questions but junkyard is a quik and cheap solution for me since thats all I can afford right now but at the same time I need my van
thats gonna give some time to save up on a rebuild or get another safari(astro) of course
oh yeah please correct me if Im saying something stupid
kocka80
kocka80
Fueling (3/4 tank)
Fueling (3/4 tank)
Postby lizzard » April 3rd 2008, 1:12am
the 4l60 two part case is the correct trannsmission for your van, just remember 2wd only. the 4x4 trans has a different output set-up
Robert
P.S. the diff is known as a 7.5 gm diff. the ratio is important for your speedo to read accurate.
check tciauto.com for pricing and info on the trannsmission. They were awsom for me when doing the same job.
Hope this helps
Robert
Team Lizzard Racing
1986 Astro Shorty
1994 Astro LWB
1987 Astro Custom
Proudly sponsered by:
XP Fuels
S&S Custom Paint Works.
lizzard
Years of Membership: lizzard has been a member for 8 full yearslizzard has been a member for 8 full yearslizzard has been a member for 8 full yearslizzard has been a member for 8 full yearslizzard has been a member for 8 full yearslizzard has been a member for 8 full yearslizzard has been a member for 8 full yearslizzard has been a member for 8 full years
Alias (AKA): lizzard
Postby gtkane » April 3rd 2008, 4:48am
Just to split hairs here...
The neutral safety switch on both designs is a bolt-on unit, and will bolt on to either one.
And the "2-piece-case 4L60E" is actually called a 4L65E. It is basically the same mechanically and electrically, with the pump being re-designed for better sealing.
They made it a 2-piece case design because, when installed in a Corvette, the engine is at the front, and the trans is at the rear.
gtkane
Postby kocka80 [OP] » April 4th 2008, 4:00am
thanks for the info I`ll check it out .
I replaced the rear end yesterday , got it out from from a 95 safari , runs great now no noise from the back whatsoever .Have to get used to that :biggrin:
cost me $150 and fits right on . this is gonna give me time on the tranny since I can drive it now .tranny slips first to second gear but I just let go of the gas pedal for a second or two to prevent slipping then step on it again . I may put in a tranny from junk yard as well if I find a front damage one.
kocka80
kocka80
Fueling (3/4 tank)
Fueling (3/4 tank)
Postby gtkane » April 4th 2008, 4:42am
I know what you mean about getting used to a lack of noise!
My diff used to howl real bad, but it got quiet right at 95kph, so that was my cruising speed. When I rebuilt it, I found myself doing 120kph+(on the highway). I had to learn to look at the speedo once in a while!
gtkane
Postby kocka80 [OP] » April 15th 2008, 4:12am
Im not trying to be a smart *** but you maybe incorrect gtkane i have read this on one of the tranny websites
*PLEASE NOTE: If you have a 4.8, 5.3, LS1, 6.0L engine - You have a unique style 4L60E called the 4L65E (found in most all late model applications
does this means that i cannot fit a tranny onto my safari with these engine sizes or what? :confused3:
kocka
kocka80
kocka80
Fueling (3/4 tank)
Fueling (3/4 tank)
Postby gtkane » April 16th 2008, 5:30am
No smart-assedness taken!
It will bolt on to any GM engine with a SBC bellhousing boltpattern built since 1955. And that includes 4.3, 5.7, etc.
And just to let you know, I build GM transmissions for a living! :D
gtkane
Postby kocka80 [OP] » April 19th 2008, 2:33am
KHMMMMM I knew I shouldnt post that but sh...t happens. :blush:
BUT I will remember your last sentence. and thanks again for the help
kocka
kocka80
kocka80
Fueling (3/4 tank)
Fueling (3/4 tank)
Postby gtkane » April 19th 2008, 9:38am
I'm always available for assistance! :biggrin:
gtkane
Postby Nick56289 » June 25th 2008, 1:04am
So do you have to get a tranny from a astro/safari or will ones from different vehicles work?
Nick56289
Years of Membership: Nick56289 has been a member for 8 full yearsNick56289 has been a member for 8 full yearsNick56289 has been a member for 8 full yearsNick56289 has been a member for 8 full yearsNick56289 has been a member for 8 full yearsNick56289 has been a member for 8 full yearsNick56289 has been a member for 8 full yearsNick56289 has been a member for 8 full years
Postby bzmotoninja83 » July 1st 2008, 2:05am
i certanly hope the engine is up fron and the trans in the rear..... does this mean i have a rear engine van? j/k man.......
89' astro-stock except custom front end (thanks to that SOB driving the acura!!!)
02' lancer-exhaust, home-made intake and custom e-bay special m3 mirrors and ninja graphics
96' suzuki katana 600-stuffed with a 91 gsxr 750 purple(EWW) and silver flames
bzmotoninja83
Years of Membership: bzmotoninja83 has been a member for 8 full yearsbzmotoninja83 has been a member for 8 full yearsbzmotoninja83 has been a member for 8 full yearsbzmotoninja83 has been a member for 8 full yearsbzmotoninja83 has been a member for 8 full yearsbzmotoninja83 has been a member for 8 full yearsbzmotoninja83 has been a member for 8 full yearsbzmotoninja83 has been a member for 8 full years
Topics: 7
Alias (AKA): Bill E Z
Postby gtkane » July 1st 2008, 3:45am
Ha,Ha!
OK, to clarify...
On a late model 'vette, the engine is under the hood, while the trans is mounted to the rear diff.
I guess it does look kinda goofy how I wrote it!
gtkane
Postby Zwett » January 26th 2015, 6:25pm
from what I hear if these trannys are not running right replaceing the " servos?" will do allot toward getting them to run like new. I just cleaned one up to put into my 69 G10 van and look forward to years of good driveing from it.
Zwett
Years of Membership: Zwett has been a member for 3 full yearsZwett has been a member for 3 full yearsZwett has been a member for 3 full years
Alias (AKA): Zwett
Year: 1999
Extra Info: 4.3 v6 RWD
Return to Automatic
It is currently February 26th 2017, 8:43am
Automatic Forum
Moderator: 1297chevastro
dkGarnet96
in Automatic
Date: Jan 27 '17
Time: 6:07pm
stevee
in Automatic
Date: Jan 27 '17
Time: 5:57pm
Attached by: 00awd
00awd
in Automatic
Comments: 20
Date: Jan 11 '17
Time: 9:13pm
Voltsmith
in Automatic
Date: Dec 26 '16
Time: 4:24am
in Automatic
Comments: 20
Date: Dec 09 '16
Time: 4:54pm
